Volume non-functional.
Grab our Forum Feed
+ Reply to Thread
Results 1 to 4 of 4
Thread: Volume non-functional.
  1. #1
    Join Date
    Apr 2011
    Location
    Ottawa, Ontario, Canada
    Posts
    359
    Default Volume non-functional.
    On vacation using phone, so hard to search forum, but wanted to throw out this question.
    On way to airport volume was stuck in one position. Several car restarts did not help. GM dealer days they have no record of this as a known issue. Anyone else had this? Is there a fix?
    03/04/2010 - Put down a $500 deposit to hold my #1 position.
    ....Bunch of stuff in between......
    09/08/2011 - Vehicle Delivered. Yippeeee!
    VIN# 847 (MY2012)
  2. #2
    Join Date
    Mar 2011
    Location
    South Jersey
    Posts
    338
    Default
    Quote Originally Posted by maestro77 View Post
    This happened to me the other day. Actually, what happened is that the volume control would only change the "Audio Cue Volume", and the HDD/Radio was stuck at a low volume. I just 'rebooted' (shut-down and re-started) at a red light, and it all worked fine after that. Bummer that a re-start didn't fix if for you, but let us know what you find out. If it were me, I might try going into to the configuration, and 'reset to factory settings'. You can do this from the touch-screen.
  3. #3
    Join Date
    Oct 2010
    Location
    Chicagoland VIN:B-01234
    Posts
    3,509
    Default
    Quote Originally Posted by Room_A113 View Post
    There have been a couple instanced of the Audio Cue being in 'control'. You can go to that specific config option and change it's volume level then hit the lower left (I think) "test volume" button. That will reset the issue. This doesn't sound like what happen to in the OPs case tho.
  4.
    Advertisement
  5. #4
    Join Date
    Apr 2011
    Location
    Posts
    359
    Default
    Returned from vacation and fired up the Volt.....volume was again adjustable....but...noticed instantly that the Audio Cue had gone back to the very loud default! Stupid overly loud boot up sound on Volt start nearly blew out my ear drums. ;-)
    So the issue does in fact seem to relate to Audio Cue somehow. But I don't know if that above suggestion to alter Audio Cue would/will reset the issue should it occur again in the future.
    VIN# 847 (MY2012)
Similar Threads
  1. Replies: 10
    Last Post: 01-08-2012, 12:42 AM
  2. Context sensitive vol control stuck on Audio Cue Volume
    By scottf200 in forum Volt Ownership Forum
    Last Post: 11-30-2011, 09:36 AM
  3. Stuck in Audio Cue Volume Mode?
    By Number719 in forum Error messages/ health monitoring/ DTC's
    Last Post: 02-22-2011, 10:30 PM
  4. Renault and Better Place Commit to Volume of 100.000 Fluence ZE
    By Texas in forum Electric Car Competitors
    Last Post: 09-16-2009, 09:21 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
