Script to start the Volt
Grab our Forum Feed
+ Reply to Thread
Page 4 of 8 FirstFirst 1 4 8 LastLast
Results 31 to 40 of 79
Thread: Script to start the Volt
  1. #31
    Join Date
    Dec 2010
    Location
    NW suburban Chicago
    Posts
    255
    Default
    Quote Originally Posted by SXBB View Post
    Got it working!
    if you are going to use the weather temp feature, don't forget to fix the script as I mentioned in a recent post.
    VIN # B2365 Chicago suburbs (purchased 4/15/2011 in Austin, Texas)
    240V Leviton Evr-Green 160 Home Charging Station installed 11/4/2011
    DASHDAQ
  2. #32
    Join Date
    Nov 2011
    Location
    Sacramento, CA area
    Posts
    31
    Default
    I downloaded "curl-7.23.1-win64-ssl-sspi.zip". When I run the VBS I get an error window with the title "curl.exe - System Error" and the text "The program can't start because MSVCR100.dll is missing from your computer. Try reinstalling the program to fix this problem."
  3. #33
    Join Date
    Dec 2010
    Location
    NW suburban Chicago
    Posts
    255
    Default
    Quote Originally Posted by UseLessGas View Post
    did you download the libraries that go with it????
    http://curl.haxx.se/docs/libs.html
    DASHDAQ
  4.
    Advertisement
  5. #34
    Join Date
    Nov 2011
    Location
    Sacramento, CA area
    Posts
    31
    Default
    Quote Originally Posted by eplantz View Post
    No ... I am confused by the pages that present the binaries and the OpenSSL project ... and there is no clear set of instructions of exactly what's needed. (Running Win7-64.) Do I need to compile the "curl" package ?? I would rather avoid this. That's why I searched for and found and downloaded only the "curl.exe".
  6. #35
    Join Date
    Dec 2010
    Location
    NW suburban Chicago
    Posts
    255
    Default
    I don't have WIN64 but here is what it looks like you need:
    The CURL program itself:
    http://curl.haxx.se/dlwiz/?type=bin&os=Win64&flav=-
    the second one is SSL if you want that. Just unzip it to a folder like C:\CURL
    OpenSSL lib: http://slproweb.com/products/Win32OpenSSL.html
    scroll down to the WIN64 light version. download and install to C:\CURL as well
    Copy your VBS script to C:\CURL
    edit the VBS script to specify the folder and your OnStar info and WEATHER true/false
    you do not need to compile anything.
    good luck.
    DASHDAQ
  7. #36
    Join Date
    Nov 2011
    Location
    Sacramento, CA area
    Posts
    31
    Default
    Nogo.
    After installing the light package ... same error. I then searched and found the MSVCR100.dll in a Windows\SysWOW64 folder. Copied it to c:\curl. It sort of worked but bombed out later in the script.
    If someone is using Win7-64 successfully, please post a list of all files ( incl. DLLs ) in your C:\CURL folder.
    TIA.
  8. #37
    Join Date
    Sep 2011
    Location
    Dallas Texas
    Posts
    1,322
    Default
    I think i did that early in the thread but here is what i have :
    in my curlssl folder
    curl.exe
    libeay32.dll
    ssleay32.dll
    2012 RED Volt VIN:#C-8860 - Premium Leather Seats Jet Black with Dark Trim, Rear Camera & Park Assist, Nav
    09/29/2011 Ordered -- 11/15/2011 took it home
  9. #38
    Join Date
    Nov 2011
    Location
    Sacramento, CA area
    Posts
    31
    Default
    Quote Originally Posted by Cord View Post
    curl.exe
    libeay32.dll
    ssleay32.dll
    Right ! Your post = #10 in this thread. And again sorry for being "dense" ... but where did you get "libssl.zip" from ?
  10. #39
    Join Date
    Sep 2011
    Location
    Dallas Texas
    Posts
    1,322
    Default
    I did get it from
    There seems to be a newer version.
    lets us know what error you get and I am sure we can help
    I get so much of my video support files from guru3d.com -- I almost posted that link !!!
    My first computer program was for the IBM 1401 - by the time I got to see a 1401 it was being used as a print buffer device for the IBM-360
  11.
    Advertisement
  12. #40
    Join Date
    Oct 2011
    Location
    Henderson, NV
    Posts
    47
    Default
    Can I ask for another feature/script?
    I would like one that will tell the Volt to Charge Now.
    Explanation:
    I signed up for the TOU rates with my local utility company at my house. They rate jumps up from $0.06/kWh to $0.35/kWh from 1pm to 7pm. Because of that I have the Volt set top NOT charge between 1pm - 7pm daily.
    I also get to charge at work on occasion. I noticed that it would stop charging at 1pm (as it should), and I would go into the OnStar app and tell it to start charging again...but if I forget than I come back from lunch and start charging I get like 1 hour of charging, then it sits plugged in and not charging.
    Is it possible to script that? I would love to have one that will start the charge if it's plugged into 120 (I have 240 at home). So I know that it will start at work, but not if I'm at home and the rates are too high.
    Volt #C657 - Henderson, NV
    Check out my Volt Stats.
+ Reply to Thread
Similar Threads
  1. Never had the engine start while plugged into my 240 volt charger!
    By Big Moe in forum Chevy Volt Owners Forum
    Last Post: 12-23-2011, 04:01 PM
  2. Volt Generator- how does it start and stop?
    By Paul Slazas in forum Chevy Volt Engineering and Design
    Last Post: 06-13-2011, 08:55 PM
  3. Does the Volt have a push button start ignition???
    By Hollywoods in forum Chevy Volt Owners Forum
    Last Post: 01-28-2011, 11:57 PM
  4. Does the volt come with a remote start? If not, can you get it as a option???
    By Hollywoods in forum Newcomers to GM-VOLT.COM (See here for FAQs)
    Last Post: 01-27-2011, 01:58 AM
  5. China Volt start July 2011?
    By srschrier in forum General Motors and General Automotive Topics
    Last Post: 10-26-2010, 10:02 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
