There's no way a tie rod coming off could have caused the car to fall down on it's tire -- beyond the normal level of wheel travel as shown in Faz's pics. The tire is bulging out the fender!
The tie rod just controls left/right movement of the wheel, not up and down. How could it control up and down while being such a weak looking rod that is horizontal not vertical?
It's got to be something with the strut bolts. Where's the rest of the diagram for the front suspension?
Originally Posted by
Well I'm still a little bit "shaky" concerning the details of this failure, as from what I can see from the photos about the only "fastener" that could have failed to permit the LF wheel to swing out as shown would be a tie rod end, which doesnt have a replaceable "bolt" at all as it's "fixed" within the end-fitting's socket. (see pic)
Yes, the tie-rod NUT (labled #1 in the photo) NOT a bolt is supposed to be replaced if ever removed (as it's not castellated but an interference self-locking design)
But WHY would have that nut been removed in the first place?
What exactly was done to this car previously?
As IIRC you had an electrical issue (bad ground?) that was triggering a lock-up during the the "Initializing" message.
Did they end up replacing your transaxle??
Volt #947 Delivered on 2/25/11 -- Sold!
240V Blink Installed 10/28/11 -- Returned!
