Highest Displayed Total Range? (Electric + Gas) - Displayed On Cluster
Grab our Forum Feed
+ Reply to Thread
Results 1 to 3 of 3
Thread: Highest Displayed Total Range? (Electric + Gas) - Displayed On Cluster
  1. #1
    Join Date
    May 2011
    Location
    Michigan
    Posts
    570
    Default Highest Displayed Total Range? (Electric + Gas) - Displayed On Cluster
    I previously posted a similar posting but I did not indicate the "displayed" Total Range so some thought I ran the VOLT depleted and dry. So will try this again, looking for what VOLT owners are seeing as to their maximum Total Range displayed on the instrument cluster.
    Just curious as to what the maximum Total Range (Electric + Fuel) you have seen on your VOLT? My personal experience has been 402 and 408 miles.
    Now, unlike a conventional car there are fewer opportunities to observe a maximum range displayed since with the VOLT one does not "fill-up" the fuel tank on a regular basis as in a conventional car. In my case I have only "filled-up" less than 10 times in its life. I usually drive with less than 2 gallons anymore, often more like less than 1-1/2 gallons. But on occasion I have filled up as in during a cross state trip.
    I currently have about 8,600 miles on my VOLT. Just adding that for the non-VOLT owner so they get an idea of how few "fill-ups" we really have.
    2011, My Zen-like Car, and Driving Experience #3187
  2. #2
    Join Date
    Nov 2010
    Location
    Woodbridge, VA
    Posts
    297
    Default
    I had a 415 or a 417 just a little while ago right after I filled up the gas tank and had a full EV charge with a range of 45 or so. The reason mine may have been higher is because I get extremely good CS mode gas mileage. The last I looked I think it was around 44 MPG or so and so that may be included in the calculation to get me up to 415.
  3. #3
    Join Date
    May 2011
    Location
    Michigan
    Posts
    570
    Default
    Kup, Good job on mileage. Your high CS did make a difference. Just shows what the VOLT can do in real life.
Similar Threads
  1. Highest Total Range? (Electric + Fuel)
    By 2BeLivingGreen in forum Volt Ownership Forum
    Last Post: 09-24-2011, 11:44 AM
  2. Highest Electric Miles Available
    By honoreitiscom in forum Volt Ownership Forum
    Last Post: 05-26-2011, 10:35 AM
  3. Follow-up on Instrument Cluster problem
    By gjm3 in forum Volt Ownership Forum
    Last Post: 04-25-2011, 10:02 AM
  4. N4180 - Instrument Cluster Replacement
    By mark4090 in forum Error messages/ health monitoring/ DTC's
    Last Post: 03-08-2011, 04:50 PM
  5. VIN Number Displayed on Start-Up Screen - Is this correct?
    By travelguy2500 in forum Volt Ownership Forum
    Last Post: 12-18-2010, 06:27 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
