Updating Gracenote Database and MyLink Car/Phone Connectivity in 2012 MY
Grab our Forum Feed
+ Reply to Thread
Results 1 to 9 of 9
Thread: Updating Gracenote Database and MyLink Car/Phone Connectivity in 2012 MY
  1. #1
    Join Date
    Sep 2011
    Location
    Orlando, FL
    Posts
    16
    Default Updating Gracenote Database and MyLink Car/Phone Connectivity in 2012 MY
    Hey everyone! This is my first car with a hard drive that I can record CD's to, and I've been having a ball copying my CD's to it. But today, I popped in a CD (Gorillaz - The Fall) that wasn't in my Gracenote database and after I recorded it, I noticed there weren't any options to edit the meta data (which was just the date and track numbers). Wondering how I might update my Gracenote database, I searched around for a while and saw some interesting articles about Gracenote and MyLink in the 2012 MY (which I have) and how you'd be able to see album art and use your smartphone to connect your car online (and presumably update your Gracenote db?). But my manual doesn't mention anything about it (and I haven't received the Nav/Map manual yet) so I'm wondering if anyone knows anything about this? Was this feature delayed, or am I just missing something? I've looked through every option I can find in the car and plugged my iPhone in via USB etc, and just can't figure out how to connect via "MyLink". I even tried running the RemoteLink app while connected, and still nothing. Originally I was just looking for a way to update my album info, but now that I see the album art in the feature list, I want that too!
    Also, I haven't figured out how to stream music over bluetooth to the car. I can control the iPod music on my phone over USB (again, no album artwork) and while I can play Pandora over USB, I can't control the app from the car (but my buddy can stream and control Pandora over bluetooth to his Mazda from his Android, so one can hope...).
  2. #2
    Join Date
    May 2009
    Location
    Raleigh, NC VIN:#C-8909
    Posts
    2,637
    Default
    Until MyLink is available for the Volt, you will not have Gracenote, Stitcher, Pandora or Bluetooth streaming. There is still no more info on when it will be available. Most people on this website are assuming that if you don't order it as an option, you will not be able to add it later (hardware & software).
    2012 Blue Topaz Volt - 11/18/11 to 11/17/14 - 36,806 EV miles. Now waiting for the B̶o̶l̶t̶/Model 3!
  3. #3
    Join Date
    Sep 2011
    Location
    Orlando, FL
    Posts
    16
    Default
    I hope it is just a software update, and not some additional hardware that will become an option at some point during the 2012 run. It looks like the current Gracenote db is bundled with the Nav Disc (see here: http://www.gmnavdisc.com/default.asp?lang=en). I'm guessing MyLink would allow you to do over the air updates rather then have to update from a Nav Disc every year or so (especially since you'd probably download the album artwork that way, vs. cramming every album cover on the Nav Disc). One would hope the Nav updates would be delivered that way too (but that might be closing off a revenue stream for GM?).
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Feb 2008
    Posts
    480
    Default
    I already asked my Volt advisor about the possibility of adding Chevy MyLink to the standard radio option as a field upgrade. I was told it will not be available as an upgrade.
    I was also told not to expect to see MyLink until late spring of 2012.
    So I changed my order to the Bose radio with nav. I do not expect to see Chevy MyLink added to that sound system either.
    And I am not sure, but you may be confusing the Onstar MyLink phone app with the Chevy MyLink sound system. You are not the only one to have done that. So Onstar recently changed the name of their product to Remote Link.
    No good news, but I hope it clears up some of the confusion....
    My TPW is only Two Days Away!!!!!
  7. #5
    Join Date
    Aug 2011
    Location
    Northern CA
    Posts
    123
    Default
    GM is now claiming the MyLink radio will be available early spring. They also plan to offer the Cyber Gray by the end of the calendar year.
    VM
    #C0429
    White Diamond Tricoat with Black Leather
    Navigation & Bose - BackUp Camera
    Volt Windshield Cover-Volt Car Cove
    r
  8. #6
    Join Date
    Aug 2011
    Posts
    288
    Default
    Quote Originally Posted by BillyB View Post
    Be aware that everything you're copying is being converted to MP3, so its not really any better than just copying MP3's onto a USB thumb drive, which will read tags (not perfectly though).
  9. #7
    Join Date
    May 2009
    Location
    Posts
    2,637
    Default
    Quote Originally Posted by rubley View Post
    What bit rate does the Volt convert CD music to MP3s on the hard drive? I would copy 320Kbps MP3 files from a USB thumb drive. I find that 320Kbps is a good compromise between sound quality and space. And since I'm over 40, I can't hear above 16khz anyway.
    For those not familiar with bit rate try the test at this link:
    http://www.noiseaddicts.com/2009/03/...-test-128-320/
    http://www.lincomatic.com/mp3/mp3quality.html
  10. #8
    Join Date
    Apr 2011
    Location
    Livonia MI
    Posts
    934
    Default
    Has anyone figured out how to have an MP3 album (several MP3's in a folder) play in the order of the original album instead of alphabetical order? (I guess MP3 doesn't retain that information). I've gone to putting a sequence number before the song title or copying direct from the CD.
  11. #9
    Join Date
    Sep 2010
    Location
    Long Beach, CA
    Posts
    167
    Default
    Quote Originally Posted by Bob_Livonia View Post
    There was a thread on this a while back. Seems the best work around is to just retag everything:
    http://gm-volt.com/forum/showthread....2639#post52639
    Not pretty, but it does work.
    2011 #130: 31,050 EV miles / 35,746 total miles (turned in 12/21/13)
    2014: 10,863 EV miles / 11,130 total miles
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Any idea when we will be able to places 2012 volt orders with MYLINK?
    By black88mx6 in forum Buying, Leasing & Selling - Chevy Volt
    Last Post: 10-17-2011, 09:05 AM
  2. Nav Database version - coverage egg?
    By scottf200 in forum Chevy Volt Accessories and Modifications
    Last Post: 05-20-2011, 12:41 PM
  3. Trip Meter - Updating MPG
    By highhandicapper in forum Generation 1 Volt (2011-2015)
    Last Post: 04-21-2011, 02:11 PM
  4. myvolt.com not updating
    By rphooper in forum Software & Programming/Code Discussions - Chevy Volt
    Last Post: 04-11-2011, 11:23 PM
  5. WiFi Connectivity
    By ClarksonCote in forum Suggestions for GM - Chevy Volt
    Last Post: 01-24-2011, 10:29 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
