Acronym Guide: What do they mean?
Page 3 of 4 FirstFirst 1 3 4 LastLast
Results 21 to 30 of 32
Thread: Acronym Guide: What do they mean?
    15,380
    48 Hybrid and Electric Car Acronyms. We'll have a test tomorrow, haha :-)
    (ABS) Antilock Brake System
    (AER) All-electric range mode. The vehicle is driven with motor only (with the combustion engine off), range is the total miles driven electrically before the engine turns on for the first time.
    (AGM) Absorbed Glass Mat battery (the 12 volt battery), sometimes called a gel battery. See VRLA battery: http://en.wikipedia.org/wiki/VRLA_battery
    (APM) Advanced Power Module
    (AT-PZEV) Advanced Technology Partial Zero Emission Vehicle (California HOV. Also many upper east coast states adopt CA standards)
    (BEV) Battery Electric Vehicle (What the Nissan Leaf is.)
    (BURPING) After a full battery charge, disconnecting and reconnecting the charge cord for a bit of extra charging.
    (CAVUTO) An idiot. As in, “Look at that CAVUTO with his gasoline powered teleprompter”. See http://mediamatters.org/blog/201108230004
    (CD) Charge Depleting Mode. An operating mode in which the energy storage state-of-charge (SOC) may fluctuate but, on average, decreases while the vehicle is driven.
    (CDH) Blended or charge-depleting hybrid mode. An operating mode in which the energy storage SOC decreases, on average, while the vehicle is driven; the engine is used occasionally to support power requests.
    (CS) Charge-sustaining mode. An operating mode in which the energy storage SOC may fluctuate but, on average, is maintained at a certain level while the vehicle is driven. This is the common operating mode of commercial HEVs.
    (DIC) Driver Information Center (Instrument cluster example where you see your current MPH.)
    (DOD) Depth of Discharge - "the amount of usable battery available to drive the car" : http://nissan-leaf.net/2010/08/04/le...-of-discharge/
    (DRL) Daytime Running Lamps
    (DTC) Diagnostic Trouble Code. A fault code, usually stored in a control unit in the car.
    (EDR) Event Data Recorder
    (EMM) Engine Maintenance Mode (Runs the engine to keep it in good working condition after approximately six weeks of no or very limited engine operation.)
    (ERDTLT) or ERDTCT: Engine Running Due To Low/Cold Temperature
    (EREV) Extended Range Electric Vehicle (What the Volt is.)
    (ESC) Electronic Stability Control
    (EV) Electric Vehicle
    (EVER) Electric Vehicle with Extended Range. Fisker's rearrangement of EREV to distinguish its Karma from the Chevy Volt.
    (EVSE) Electric Vehicle Supply Equipment. It is the charging interface—not the charger—because the charger is inside the car.
    (FMM) Fuel Maintenance Mode (FMM will run the engine to use up the old fuel.)
    (FOX) Fake Outragious Xanthopsia. See http://en.wikipedia.org/wiki/Yellow_journalism
    (GPS) Global Positioning System
    (HEV) Hybrid Electric Vehicle (example Prius)
    (ICE) Internal Combustion Engine
    (kW) kiloWatt - unit of power - Power is the rate at which energy is generated or used
    (kWh) kiloWatt hour - unit of energy - Energy is a measure of how much fuel is contained within something, or used by something over a specific period of time - Volt as 16kWh battery and uses roughly 65% or 10.5 kWh of it. http://www.energylens.co m/articles/kw-and-kwh (kWh vs kW. Compared to the water pump, kWh is the same type of measurement as gallons, which measure total volume, where as kW relates to gallons per minute, which measures a rate of flow.other good articles?)
    (LATCH) Lower Anchors and Tethers for Children
    (MIL) Malfunction Indicator Light
    (MM) Mountain Mode (This mode maintains a reserve electrical charge of the high voltage battery to provide better grade climbing performance.)
    (PDI) Pre Delivery Inspection. PDF here: http://gm-volt.com/forum/attachment....4&d=1316287262
    (PHEV) Plug-in Hybrid Electric Vehicle. An HEV with the ability to plug-in its energy storage system to get recharged with electricity from the grid.
    (PZEV) Partial Zero Emission Vehicle
    (RAP) Retained Accessory Power (State the car is in when you turn it off but have not open the door yet.)
    (RKE) Remote Keyless Entry
    (RVC) Rear Vision Camera
    (SOC) State Of Charge
    (TCS) Traction Control System
    (TMS) Thermal Management System to monitor and maintain the battery pack temperature for optimum performance
    (TPMS) Tire Pressure Monitor System
    (TPW) Targeted/Tentative Production Week (General Motors)
    (UFRPA) Ultrasonic Front and Rear Parking Assist
    (VIN) Vehicle Identification Number
    (ZEV) Zero-emission vehicle range. The same as AER; there are no tailpipe emissions when the vehicle is in electric vehicle mode.
    2011 Cyber Gray, Std Wheels, Black Leather/White Console, Bose, Nav, Htd Seats, Park Assist. Picked up May 2011
    Lifetime: 85,558 miles, 125 MPG, Remaining Oil Life 38%
    Typical Commute: 60 miles
    30 day Stats: 966 miles, 108
    MPG, 62% Electric, 38% gas, Saved 33 gal., 31 kW-hr/100 miles
    Hidden Content Free Volt Manual here: Hidden Content
    Aug 2011
    22
    Thanks for updateing the list. I was going to come back in and update and clean it up. But guess you all beat me to it. And Yeah i now know what CS and CD is.
    Steven.
    Volt # unknown as I don't have one yet.
    Jeep TJ as a toy.
    Aug 2011
    22
    (SFC) Specific Fuel Consumption
    Steven.
    Jeep TJ as a toy.
  6. #24
    Nov 2012
    Fresno, California
    1,062
    Anyone maintaining this list? People keep throwing out new acronyms:
    ERDTLT or ERDTCT: Engine Running Due To Low/Cold Temperature
    TMS - Thermal Management System to monitor and maintain the battery pack temperature for optimum performance
    APM Advanced Power Module
    AGM Absorbed Glass Mat battery (the 12 volt battery), sometimes called a gel battery.
    _____ See VRLA battery: http://en.wikipedia.org/wiki/VRLA_battery
    2013 Volt 21Nov2012, Silver Topaz Metallic___2014 Spark EV 31Jan2014, Electric Blue___Fresno, CA
    Hidden Content ___ Hidden Content ___ Hidden Content
  7. #25
    15,380
    Default Current Acronym List
    52 Hybrid and Electric Car Acronyms.
    1. ABS - Antilock Brake System
    2. AER - All-electric range mode. The vehicle is driven with motor only (with the combustion engine off), range is the total miles driven electrically before the engine turns on for the first time.
    3. AGM - Absorbed Glass Mat battery (the 12 volt battery), sometimes called a gel battery. See VRLA battery: http://en.wikipedia.org/wiki/VRLA_battery
    4. Ah - Amp Hours. The measure of battery capacity as in "1800 mAh".
    5. APM - Advanced Power Module
    6. AT-PZEV - Advanced Technology Partial Zero Emission Vehicle (California HOV. Also many upper east coast states adopt CA standards)
    7. BEV - Battery Electric Vehicle (What the Nissan Leaf is.)
    8. BMS - Battery Management System. Monitors the battery voltages, temps, charging etc.
    9. CAVUTO - An idiot. As in, “Look at that CAVUTO with his gasoline powered teleprompter”. See http://mediamatters.org/blog/201108230004
    10. CD - Charge Depleting Mode. An operating mode in which the energy storage state-of-charge (SOC) may fluctuate but, on average, decreases while the vehicle is driven.
    11. CDH - Blended or charge-depleting hybrid mode. An operating mode in which the energy storage SOC decreases, on average, while the vehicle is driven; the engine is used occasionally to support power requests.
    12. CS - Charge-sustaining mode. An operating mode in which the energy storage SOC may fluctuate but, on average, is maintained at a certain level while the vehicle is driven. This is the common operating mode of commercial HEVs.
    13. DIC - Driver Information Center (Instrument cluster example where you see your current MPH.)
    14. DOD - Depth of Discharge - "the amount of usable battery available to drive the car" : http://nissan-leaf.net/2010/08/04/le...-of-discharge/
    15. DRL - Daytime Running Lamps
    16. DTC - Diagnostic Trouble Code. A fault code, usually stored in a control unit in the car.
    17. EDR - Event Data Recorder
    18. EMM - Engine Maintenance Mode (Runs the engine to keep it in good working condition after approximately six weeks of no or very limited engine operation.)
    19. ERDTCT - Engine Running Due To Cold Temperature
    20. ERDTLT - Engine Running Due To Low Temperature
    21. EREV - Extended Range Electric Vehicle (What the Volt is.)
    22. ESC - Electronic Stability Control
    23. EV - Electric Vehicle
    24. EVER - Electric Vehicle with Extended Range. Fisker's rearrangement of EREV to distinguish its Karma from the Chevy Volt.
    25. EVSE - Electric Vehicle Supply Equipment. It is the charging interface—not the charger—because the charger is inside the car.
    26. FMM - Fuel Maintenance Mode (FMM will run the engine to use up the old fuel.)
    27. FOX - Fake Outragious Xanthopsia. See http://en.wikipedia.org/wiki/Yellow_journalism
    28. GPS - Global Positioning System
    29. HEV - Hybrid Electric Vehicle (example Prius)
    30. ICE - Internal Combustion Engine
    31. kW - kiloWatt - unit of power - Power is the rate at which energy is generated or used
    32. kWh - kiloWatt hour - unit of energy - Energy is a measure of how much fuel is contained within something, or used by something over a specific period of time - Volt as 16kWh battery and uses roughly 65% or 10.5 kWh of it. http://www.energylens.co m/articles/kw-and-kwh (kWh vs kW. Compared to the water pump, kWh is the same type of measurement as gallons, which measure total volume, where as kW relates to gallons per minute, which measures a rate of flow.other good articles?)
    33. LATCH - Lower Anchors and Tethers for Children
    34. MIL - Malfunction Indicator Light
    35. MM - Mountain Mode (This mode maintains a reserve electrical charge of the high voltage battery to provide better grade climbing performance.)
    36. PDI - Pre Delivery Inspection. PDF here: http://gm-volt.com/forum/attachment....4&d=1316287262
    37. PHEV - Plug-in Hybrid Electric Vehicle. An HEV with the ability to plug-in its energy storage system to get recharged with electricity from the grid.
    38. PZEV - Partial Zero Emission Vehicle
    39. RAP - Retained Accessory Power (State the car is in when you turn it off but have not open the door yet.)
    40. RKE - Remote Keyless Entry
    41. RVC - Rear Vision Camera
    42. SFC - Specific Fuel Consumption
    43. SOC - State Of Charge
    44. SOH - Battery State of Health or temperature corrected estimated capacity. Measured in Ah's
    45. TCS - Traction Control System
    46. TMS - Thermal Management System to monitor and maintain the battery pack temperature for optimum performance
    47. TPMS - Tire Pressure Monitor System
    48. TPW - Targeted/Tentative Production Week (General Motors)
    49. UFRPA - Ultrasonic Front and Rear Parking Assist
    50. VIN - Vehicle Identification Number
    51. YMMV. Your Mileage May Vary. Shorthand for, you may disagree, or your experience may be different than mine
    52. ZEV - Zero-emission vehicle range. The same as AER; there are no tailpipe emissions when the vehicle is in electric vehicle mode.
  8. #26
    Aug 2012
    Lost State of Franklin
    1,415
    SOH battery state of health or temperature corrected estimated capacity in Ah's.
    Ah amp hours measure of battery capacity as in 1800 mAh.
    BMS battery management system that monitors the battery voltages, temps, charging etc.
    2012 White Diamond
    2014 White Diamond ..daughters
    Hydro Powered
    (By TVA)
  9. #27
    15,380
    Default Acronym Guide: What do they mean?
    Volt, Electric, and Hybrid Car Acronyms.
    1. ABS - Antilock Brake System. Prevents the wheels from locking up (ceasing rotation) when a driver steps hard on the brakes and avoids uncontrolled skidding.
    2. AER - All-Electric Range mode. The vehicle is driven with motor only (with the combustion engine off), range is the total miles driven electrically before the engine turns on for the first time.
    5. APM - Advanced Power Module. A 12V DC-DC converter.
    6. AT-PZEV - Advanced Technology Partial Zero Emission Vehicle. For California HOV. Also many upper east coast states adopt CA standards.
    7. BEV - Battery Electric Vehicle. Example: the Nissan Leaf. No backup power supply, when the battery is empty, the car stops.
    9. BURPING - After a full battery charge, disconnecting and reconnecting the charge cord for a bit of extra charging.
    10. CARB - California Air Research Board
    11. CAVUTO - An idiot. As in, “Look at that CAVUTO with his gasoline powered teleprompter”. See http://mediamatters.org/blog/201108230004
    12. CD - Charge Depleting mode. An operating mode in which the energy storage state-of-charge (SOC) may fluctuate but, on average, decreases while the vehicle is driven.
    13. CDH - Blended or Charge-Depleting Hybrid mode. An operating mode in which the energy storage SOC decreases, on average, while the vehicle is driven; the engine is used occasionally to support power requests.
    14. CEL - Check Engine Light. A malfunction indicator light, a.k.a. MIL.
    15. CS - Charge-Sustaining mode. An operating mode in which the energy storage State of Charge may fluctuate but, on average, is maintained at a certain level while the vehicle is driven. This is the common operating mode of commercial Hybrid Electric Vehicles.
    16. DIC - Driver Information Center (Instrument cluster example where you see your current MPH.)
    17. DOD - Depth of Discharge. The amount of usable battery available to drive the car : http://nissan-leaf.net/2010/08/04/le...-of-discharge/Also see SOC.
    18. DRL - Daytime Running Lamps.
    19. DTC - Diagnostic Trouble Code. A fault code, usually stored in a control unit in the car. If you have a problem with the Volt, press the OnStar button, ask them for the DTC, write them down. This document will tell you what is wrong: http://service.gm.com/gmspo/mode6/pd...iagnostics.pdf
    20. EDR - Event Data Recorder. A device in some automobiles used to record information related to vehicle crashes or accidents.
    21. EMM - Engine Maintenance Mode. Runs the engine to keep it in good working condition after approximately six weeks of no or very limited engine operation.
    22. ERDTCT - Engine Running Due To Cold Temperature. Pretty self explanatory.
    23. ERDTLT - Engine Running Due To Low Temperature.
    24. EREV - Extended Range Electric Vehicle. An electric vehicle that can continue traveling after the battery is depleted. Example: the Volt.
    25. ESC - Electronic Stability Control. A computerized sytem to detect and reduce loss of tire traction (skidding).
    26. EV - Electric Vehicle. A vehicle that is moved by electric motors. The Volt is an EV.
    27. EVER - Electric Vehicle with Extended Range. Fisker's rearrangement of EREV to distinguish its Karma from the Chevy Volt. A distinction without much of a difference.
    28. EVSE - Electric Vehicle Supply Equipment. It is the cord handle and related electrical equipment that is plugged into the Volt. Sometimes incorrectly called, "the charger". It is the charging interface between the electrical grid and the car. The battery charger is actually inside the car.
    29. FCEV - Fuel Cell Electric Vehicle. A type of hydrogen vehicle which uses a fuel cell to produce electricity.
    30. FMM - Fuel Maintenance Mode. FMM will run the Volt engine to use up the old fuel.
    31. FOX - Fake Outragious Xanthopsia. See http://en.wikipedia.org/wiki/Yellow_journalism
    32. GPS - Global Positioning System. Used to determine your location, or that of a destination.
    33. HEV - Hybrid Electric Vehicle. Example: Prius. A gas engined car that gets an occasional acceleration assist from a small electric battery.
    34. HOV Lane - High Occupancy Vehicle lane.
    35. ICE - Internal Combustion Engine. Usually accompanied by Vroooom, vrooooom.
    36. kW - kiloWatt. A unit of power. Power is the rate at which energy is generated or used.
    37. kWh - kiloWatt hour. A unit of energy. Energy is a measure of how much fuel is contained within something, or used by something over a specific period of time. The 2011-2012 Volt has a 16kWh battery and uses roughly 65% or 10.5 kWh of it. http://www.energylens.co m/articles/kw-and-kwh (kWh vs kW. Compared to the water pump, kWh is the same type of measurement as gallons, which measure total volume, where as kW relates to gallons per minute, which measures a rate of flow.)
    38. LATCH - Lower Anchors and Tethers for Children. Not the same as strapping a dog to the car roof. That's a MITT.
    39. LION - Lithium Ion. A type of rechargeable battery. Used in the Chevy Volt.
    40. MIL - Malfunction Indicator Light. Also see CEL
    41. MM - Mountain Mode. This mode maintains a reserve electrical charge of the high voltage battery to provide better grade climbing performance.
    42. NiCd - Nickel Cadmium. A type of rechargeable battery.
    43. NiMH - Nickel Metal Hydride. A type of rechargeable battery. It is very similar to the nickel–cadmium cell.
    44. NiZn - Nickel Zinc. A type of rechargeable battery. Often used in cordless tools.
    45. OTA - Over The Air. Some Volt software updates are downloaded and installed via the OnStar antenna. Otherwise, the car must be taken to the dealer for the update.
    46. PbA - Lead Acid. A type of rechargeable battery. Invented in 1859, they are the oldest type of rechargeable battery.
    47. PDI - Pre-Delivery Inspection. PDF here: http://gm-volt.com/forum/attachment....4&d=1316287262
    48. PHEV - Plug-in Hybrid Electric Vehicle. An HEV with the ability to plug-in its energy storage system to get recharged with electricity from the grid.
    49. PM - Permanent magnet. Produces a high magnetic field with a low mass, and is stable against the influences which would demagnetize it.
    50. PV - Photovoltaic. A method of generating electrical power by converting solar radiation into direct current electricity.
    51. PZEV - Partial Zero Emission Vehicle.
    52. RAP - Retained Accessory Power. The state the car is in when you turn it off but have not yet opened the door.
    53. REGEN - Regenerative. Refers to brakes that put electricity back into the battery as the car slows.
    54. RKE - Remote Keyless Entry. A proximity sensor will unlock the car when you get near with the key.
    55. RVC - Rear Vision Camera. A camera in the rear, with the image displaying in the center console.
    56. SFC - Specific Fuel Consumption. The ratio of fuel used by an engine to produce a certain force.
    57. SOC - State Of Charge. Measures how much useable electricity is left in the battery.
    58. SOH - Battery State of Health or temperature corrected estimated capacity. Measured in Ah's.
    59. TCS - Traction Control System. Helps prevent tires from slipping.
    60. TMS - Thermal Management System. Monitors and maintains the battery pack temperature for optimum performance.
    61. TPMS - Tire Pressure Monitor System. Displays tire pressure on the DIC.
    62. TPW - Targeted/Tentative Production Week (General Motors).
    63. UFRPA - Ultrasonic Front and Rear Parking Assist. Provides audible beeps as the car gets closer to an obstacle.
    64. ULEV - Ultra Low Emission Vehicle. 50 percent cleaner emissions than the current average year's models.
    65. VIN - Vehicle Identification Number. Your car's manufacturing number.
    66. Wh - Watt Hour. A unit of energy equivalent to one watt (1 W) of power expended for one hour (1 h) of time.
      3,600 joules.
    67. YMMV - Your Mileage May Vary. Shorthand for, you may disagree, or your experience may be different than mine
    68. ZEV - Zero-emission vehicle range. The same as AER; there are no tailpipe emissions when the vehicle is in electric vehicle mode.
  10. #28
    Bakersfield, California
    771
    MITT = Mutt in Top Transit?
    2013 Black Volt #43046
  11. #29
    Streamwood, IL
    134
    this is going to be a long list
  13. #30
    Oct 2014
    Akron, OH
    139
  1. Holiday Gift Guide.
    By carid in forum CARiD.com
    Last Post: 12-11-2012, 08:47 AM
  2. Backup camera guide lines?
    By schectermarc in forum Mechanical Systems - Chevy Volt
    Last Post: 11-10-2012, 01:02 PM
  3. PECEV, do we need yet another acronym?
    By misslexi in forum Totally Off-Topic
    Last Post: 06-24-2009, 10:45 AM
  4. The Fall of GM: A Visual Guide
    By zhackwyatt in forum Politics, Finance, and Environment
    Last Post: 04-02-2009, 03:40 PM
