Safety Warning: Remote Start of Gas Engine MUST be a config option
Grab our Forum Feed
+ Reply to Thread
Page 3 of 6 FirstFirst 1 3 6 LastLast
Results 21 to 30 of 51
Thread: Safety Warning: Remote Start of Gas Engine MUST be a config option
  1. #21
    Join Date
    Sep 2008
    Posts
    2,582
    Default
    Quote Originally Posted by scottf200 View Post
    As an aside certainly everyone noticed that the catalytic converter is right next to the exhaust manifold so it is going to heat up quick. This picture shows it well but the oxygen sensor wire running to it is not shows. I think I seeing/reading this right. More smart engineering!
    Attachment 2705
    Not only is the TWC and the exhaust stream "close-coupled", but the HO2S is actually a new "quick-lightoff" design in order to get it active and into closed loop fuel delivery as quickly as possible.
    But even given that (and over 35 working in and around active automotive exhaust systems) I too do not believe this to be something that could ever create a seriously unsafe scenario with respect to CO concentrations (given the 2 x 10 minute run time maximum) except in a well sealed, non-ventilated space.
    BUT STILL it appears GM will be responding to end-user requests for some level of personalization. :applause:
    (see my previous post for more info)
    WOT
    Follow the Chevy Volt on Twitter! @WopOnTour
  2. #22
    Join Date
    Aug 2010
    Location
    Northern Virginia
    Posts
    418
    Default
    Quote Originally Posted by WopOnTour View Post
    tbault,
    For the 2012 model year General Motors IS apparently planning on adding some personalization features for the engine start-up in cold temperatures when using the remote start feature. These features are loosely described in the 2012 Owner's Manual.I am attempting to clarify all of the details before I provide a detailed post, but essentially there IS or WILL BE a method for the engine start-up to be disabled by the owner when using RVS, but ONLY when plugged in. There will also the ability to select the temperature extreme (Cold or Very Cold) in wich the start up would occur if enabled (or if UN-plugged when it will ALWAYS be enabled)
    What I am also attempting to ascertain if this software revision can potentially be retrofit into the 2011 models with the most recent (perhaps someone here in the forums can check? ) or some future update.
    According to the Owner's Manual the ability to alter these settings on the 2012s is located in the: "Config">"Vehicle Settings" > "Climate and Air Quality"
    HTH
    WopOnTour
    Hi WOT - -
    Thanks for all you do!
    Did you ever get an answer for whether or not GM can make a firmware update that addresses this in the 2011? I for one would LOVE to disable the feature when the car is plugged in!
    Regards,
    # 565
  3. #23
    Join Date
    Oct 2011
    Location
    Durand, IL
    Posts
    76
    Default
    Quote Originally Posted by ?'smyvolt View Post
    Hi WOT - -
    Regards,
    # 565
    I'll second this question WOT. Have you been able to confirm if/when this new feature will be implemented? Thanks for all of your expertise!
    Regards,
    Dan
    2012 Volt
    Fully loaded Crystal Red Tintcoat w/ Lt. Neutral Int.
    Produced on 11/11/11
    #10091
    Delivered to the dealer on 11/21/22!!
    Arrived home on 11/26/11!!!!! Proud owner status
  4.
    Advertisement
  5. #24
    Join Date
    Aug 2011
    Posts
    183
    Default
    Please block this a**hole and get rid of his spam
    Red 2012 Loaded
  6. #25
    Join Date
    Sep 2008
    Posts
    2,582
    Default
    Quote Originally Posted by dj dannis View Post
    Regards,
    Dan
    NOT implemented as of yet AFAIK (although in the 2012 OM)
    Working on a timeline commitment
    Stay Tuned!
    WOT
    PS> Thanks for taking out the trash VoltMama!
  7. #26
    Join Date
    Aug 2010
    Location
    Northern Virginia
    Posts
    418
    Default
    NOT implemented as of yet AFAIK (although in the 21012 OM)
    Stay Tuned!
    WOT
    Thanks for the feedback Super WOT!
    # 565 @ 14,384 miles, lifetime MPG 161
  8. #27
    Join Date
    Aug 2011
    Location
    Burlington, Ontario
    Posts
    109
    Default
    I wish I would have known that it hasn't been implemented. After reading the owners manual for my 2012 volt and finding that I didn't have those config options I talked to my volt advisor to find out if there was a software update and she didn't know anything about
    the config options for remote start and ice heat assist settings. She told me to contact my dealer so I went there and they had my car for 2 hours to find out that there is no update. They told me it must only be available in the U.S. Lol! at least they gave me free coffee and breakfast.
    Hopefully this update comes soon. Thanks WOT!
  9. #28
    Join Date
    Oct 2011
    Location
    Durand, IL
    Posts
    76
    Default
    Stay Tuned!
    WOT
    Sweet, looking forward to the update WOT! Thanks again...
    -Dan
    2012 Volt
    #10091
  10. #29
    Join Date
    Jul 2009
    Location
    S. California
    Posts
    968
    Default
    tbault,
    HTH
    WopOnTour
    Just a wild guess, but since the 120 V plug option does not provide enough power to fully maintain battery condition, preheat the cabin and complete the charging cycle without ICE assistance, I'll guess that the above will be true only with 220-240 V power.
  11.
    Advertisement
  12. #30
    Join Date
    Jul 2009
    Location
    S. California
    Posts
    968
    Default
    Stay Tuned!
    WOT
    (although in the 21012 OM) - This truly demonstrates a long term commitment to the progress, health, and welfare of the platform.
+ Reply to Thread
Similar Threads
  1. Never had the engine start while plugged into my 240 volt charger!
    By Big Moe in forum Chevy Volt Owners Forum
    Last Post: 12-23-2011, 04:01 PM
  2. Replies: 17
    Last Post: 01-28-2011, 03:49 AM
  3. Does the volt come with a remote start? If not, can you get it as a option???
    By Hollywoods in forum Newcomers to GM-VOLT.COM (See here for FAQs)
    Last Post: 01-27-2011, 01:58 AM
  4. Remote Start Best Practice
    By diverdon in forum Chevy Volt Owners Forum
    Last Post: 01-20-2011, 08:24 AM
  5. Remote Start?
    By baltimore17 in forum VOLT Consumer Advisory Board (CAB) Archive Only
    Last Post: 11-23-2010, 03:01 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
