clicking gas pedal
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
Thread: clicking gas pedal
  1. #1
    Join Date
    Jul 2011
    Location
    Bay Area, CA
    Posts
    95
    Default clicking gas pedal
    ive noticed that the gas/electric pedal switch clicks at top position. does anyone else notice this? i find it annoying that pulse and gliding which I do alot has this clicking feel in the pedal.
  2. #2
    Join Date
    Sep 2010
    Location
    San Diego, CA. VIN B-95
    Posts
    2,631
    Default
    Quote Originally Posted by AllenL View Post
    My brake pedal does that sometimes too, and you're right it can be annoying.
    Why are you pulse and gliding a Volt?
  3. #3
    Join Date
    Apr 2011
    Location
    Texas
    Posts
    316
    Default
    I've not noticed any "clicking" or noise in either pedal. 7,600 miles worth.
    Volt #2243
  4.
    Advertisement
  5. #4
    Join Date
    Apr 2011
    Location
    Central Texas
    Posts
    949
    Default
    I notice a clicking-like noise when I pull into the parking garage at work. There I'm just feathering the pedal to pull into a parking spot; since everything is so quiet, I can feel and hear something, but not sure what it is. It's been that way since I got it.
    #B2380, 2011 Crystal Red. Born 3/18/2011, adopted 4/9/2011
    #B2733, 2011 White Diamond. Born 4/4/2011, foster care 5/2/2011, adopted 11/29/2012
    - The FAQ -- answers to your Frequently Asked Questions about the Volt - Click Here! - maintained by ChrisC
  6. #5
    Join Date
    Sep 2010
    Location
    Posts
    2,631
    Default
    Quote Originally Posted by fishhawk View Post
    Hmmmm.... I don't think the parking brake cares what the main brake is doing at that point. And while the parking brake whirs, I don't think it's supposed to click. There's been occasional reports of the parking brake cable linkage binding up and clicking (or thunking), and it's a bad thing (or can be, in the long run).
    Next time you're in the shop (which for a lot of people isn't very often in a Volt) you might want them to take a listen to it to see if there's an issue.
  7. #6
    Join Date
    Aug 2011
    Location
    Belmont, CA
    Posts
    110
    Default
    I do hear the clicking when I am pulling into my garage and inching it forward so it is perfectly aligned (as in the side door won't hit the car when it is opened and it won't get too close to the wall to obstruct the walking path in front). I thought this was just the electric motor engaging and disengaging due to the discrete pedal pushes.
    -Venky
    B3490, 2011 Viridian Joule, Leased 7/5/11, 1100 miles (988 EV)
  8. #7
    Join Date
    Aug 2011
    Location
    Belmont, CA
    Posts
    110
    Default
    I guess I am one of the few whose Volt has already spent quality time at the service shop :-)
    I had to make several trips to get the Hood Release Latch to be attached to the wall.
    After reading Bob_Livonia's post about the intermittent buzz, I realized that I've been hearing it too and been assuming that it was part of normal operation since it sounded more like a motor rather than any loose component. But after reading the post, I started hearing it more and more and then I switched the radio off and I kept hearing it all the time. So I dropped it off at the shop yesterday (the VA ensured that I got a loaner car from the dealership). The service advisor is still awaiting word from the GM engineer so the Volt had to spend the night away from my garage. Missing it and desperate to have it back. Should be a few hours. Wondering if I should call them and have them install the software update!
    -Venky
  9. #8
    Join Date
    Aug 2010
    Location
    Berwyn, PA
    Posts
    1,167
    Default
    I took my Volt out for a spin this evening, rolled down the windows, turned off the radio and the fan, and listened as hard as I could for any clicking noise. I stopped, started, slowly, quickly, you name it. My hearing mus be pretty bad, because I could not hear a thing other than a Volt's electric motor whirring...
    Chris
    Volt #541
    8,913 miles
    57% EV, 80 MPG lifetime
  10. #9
    Join Date
    Aug 2011
    Location
    Belmont, CA
    Posts
    110
    Default
    It is getting mysterious. The service advisor called me and reported that he will need to keep the car over the weekend since they haven't figured it out yet. He confirmed that there does seem to be a problem but admitted that he doesn't know enough to explain whether it is a major/minor thing. He could not even commit if he could let me have it Monday morning. So I called the VA line and urged them to support the service advisor over the weekend. What else could I do?
    It is funny, the car was running fine except for the buzzing noise. Of course, I could not have ignored it. But now I am Volt-less and driving a gasoline car. With no idea when I'll get the Volt back. Not fun.
    -Venky
    VIN number of rental car (who cares?)
  11.
    Advertisement
  12. #10
    Join Date
    Jul 2011
    Location
    Bay Area, CA
    Posts
    95
    Default
    Umm, can we not sidetrack this thread?
    The clicking is a switch for the gas pedal. If you "feather" the pedal, you'll feel and not hear the 'click'. Its annoying because if you release the pedal but keep your foot on it and depress the pedal again, you'll feel this click.
    I use this method most of the time while on the highway because I'm trying to conserve battery and let it regen or coast but I dont always take my foot off.
    The pedal travel should be smooth. The switch clicking under the pedals should have been designed out of the normal travel range.
+ Reply to Thread
Similar Threads
  1. Brake Pedal Feel
    By dannyrrr in forum Mechanical Systems - Chevy Volt
    Last Post: 03-02-2012, 06:16 PM
  2. Clicking on VIN# at http://www.chevroletconnects.com
    By scottf200 in forum Chevy Volt Owners Forum
    Last Post: 02-08-2011, 01:40 PM
  3. Toyota to Fix Gas Pedal on Recalled Cars
    By misslexi in forum Chevy Volt General Discussion, News, and Events
    Last Post: 11-27-2009, 12:18 AM
  4. Green wheel turns pedal bike into electric hog
    By misslexi in forum Totally Off-Topic
    Last Post: 02-26-2009, 07:43 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
