Adapting the Mountain Mode for MY2012 Volt to function like the Hold Mode
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
Thread: Adapting the Mountain Mode for MY2012 Volt to function like the Hold Mode
  1. #1
    Join Date
    Jul 2012
    Location
    Stanley NC
    Posts
    10
    Default Adapting the Mountain Mode for MY2012 Volt to function like the Hold Mode
    In the continual quest to find an answer for the MY2012 Volt owners who have the misfortune of being left out on the Hold Mode, I was wondering if anyone might know how to adjust the Mountain Mode to act like a form of Hold Mode? I have no need of the Mountain Mode and if I ever do, I can accept it coming on at 90% vs 40%. This way I am hoping to get the good out of ICE in winter months and highway driving.
    Thanks in advance
  2. #2
    Join Date
    Nov 2011
    Location
    Floyd, Virginia
    Posts
    1,480
    Default
    I've been wanting this myself. I'm not a car electronics hacker, testing on my own car, though. We have one here that might try something, it can't be super-hard, but it's not in the ECM, it's elsewhere.
    One thing I've thought of is cheating the ERDLT sensor, which is inside the right wheel well somewhere (or just behind it). It's an NTC thermocouple, so adding some series resistance there (the specs are elsewhere here) would make the car think it's colder than it is and run the ICE. Somewhere between 25k and 100k ohms ought to do for most weather, and I've thought that if I do, I'll simply put in a potentiometer and switch, inside the cabin to enable that.
    I have no idea what would happen if the resistance measured there was totally "out of spec" for example, so being able to adjust it might be important.
    Other experiments, like forcing the ICE on by popping the hood have shown me that yes, with it running, it does what it would do normally...charge the batttery if not already full and so on. But that dodge doesn't work past about 10 mph (with the hood still held by the safety latch).
    I've also been known to not quite fully charge the car (say, to 90% only), then pop the hood and let it warm up before leaving, while also charging the battery the rest of the way up - the engine runs under more load that way - more efficient overall. For that one, you have to pay attention to the charge level, as there's no set-and-forget method available. For the rest of the trip (asuuming a short one) the heater then needs to draw less power to keep something already warm still warm. I use recirculate to keep from having to heat cold outdoor air for that one.
    Edit: I'm totally off-grid solar, and when I need these tricks, I don't have the "shore power" to simply pre-condition.
    Volt #5014, White. All off grid solar powered. My sci-tech boards:
    Hidden Content
  3. #3
    Join Date
    Nov 2012
    Location
    SLC, Utah
    Posts
    1,859
    Default
    Quote Originally Posted by DCFusor View Post
    If forcing the ICE to engage is your endgame, simply removing this ambient air temperature sensor and the open circuit the K114A Hybrid/EV powertrain control module 2 detects will accomplish this.
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    15,394
    Default
    Quote Originally Posted by somms View Post
    See this thread http://gm-volt.com/forum/showthread....-in-the-winter
    B3320
    Best All Electric Miles: 54.2
    Lifetime: 85,558 miles, 125 MPG, Remaining Oil Life 38%
    Typical Commute: 60 miles
    30 day Stats: 966 miles, 108
    MPG, 62% Electric, 38% gas, Saved 33 gal., 31 kW-hr/100 miles
  7. #5
    Join Date
    Mar 2010
    Location
    Central NY
    Posts
    4,379
    Default
    Who is the guy on here that has modified the software to do other things? i.e. faster acceleration times, DVD playback when in motion, etc.
    Seems like a switch from 40% threshold to 90% threshold would be easy for him.
    Hidden Content - Provide backup power to essential appliances.
    Hidden Content - Keep yourself from getting unplugged!
    Join thE REVolution
    2011 Volt #186, VIN: B-00186, Cyber Gray Metallic - TRADED! 28k miles, 9k engine, 120MPG
    2013 Volt #43404, Blue Topaz Metallic
    Driving for FREE with Solar PV!
  8. #6
    Join Date
    Jan 2011
    Location
    SE PA
    Posts
    5,239
    Default
    Keep it in MM and don't charge overnight... . I did that last night. For long highway drives, I just enter MM at the start and come out of it with 14 miles to go.
    VIN: B-2672 Crystal Red - Light Neutral Leather (4-years owned on July 5, 2016 @ 69,000 miles) Current Hidden Content
    USA-made 8.16KW Solar PV - SolarWorld + PowerOne Aurora ** Hidden Content -- 47 MWh since 12/12/2012
    Thank you to Hidden Content for a great purchasing experience. Hidden Content
  9. #7
    Join Date
    Jan 2012
    Location
    Pinellas FL
    Posts
    3,405
    Default
    Quote Originally Posted by ClarksonCote View Post
    A talker that never once proved he did anything .. like many on the interent looking for attention
    2013 Crystal Red Volt #39239 - New off the lot 8/28/2014
    Make Your Stock charger 240V for 30 bucks! Hidden Content
  10. #8
    Join Date
    Sep 2013
    Location
    Montreal, QC
    Posts
    12
    Question Is it bad for the battery to keep it in MM and don't charge during the winter?
    Quote Originally Posted by bonaire View Post
    I don't have the Hold Mode with my 2012 too. Since my electric utility rate is 5 times more when outside temperature is below 10 deg F, I would like to run on gasoline when outside temperature is below 10 deg F. My house is heated by oil instead of electric when outside temp is below 10 deg F and would like that my Volt run only gasoline too below 10 deg F. I was thinking at that strategy with Mountain Mode. I'm wandering if it can stress the battery or other car components to leave the car unplugged during the coldest weeks of the year. At least, the battery stay near the recommended range for long storage if we switch to Mountain Mode at each startup.
    I know that under a certain battery temperature, we can get an error message showing that the car need to be plugged in to start the ICE. Do we know which outside temp can cause that?
  11. #9
    Join Date
    Mar 2010
    Location
    Central NY
    Posts
    4,379
    Default
    Quote Originally Posted by Henry_FL View Post
    Actually, the one I'm thinking about had a (somewhat poorly filmed) YouTube video showing a real fast 0-60 time on his Volt, though it was accompanied by a Check Engine light each time.
    Join thE REVolution
  12. Advertisement
  13. #10
    Join Date
    May 2011
    Location
    Delaware
    Posts
    8,023
    Default
    I've never been satisfied with any of the videos - there seem to be issues with each which "happen" to keep us from seeing the real results clearly (the most recent set had serious problems with the rolling shutter interacting with the LED? display on the display.)
    Walter
    2016 Tesla X75D delivered 8/25/16
    Hidden Content
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Is Mountain mode equivalent to Hold mode if the battery is at 50%?
    By Darren Donovan in forum Generation 1 Volt (2011-2015)
    Last Post: 10-27-2015, 11:38 AM
  2. Hold Drive vs Mountain Mode
    By aopalenik in forum Generation 1 Volt (2011-2015)
    Last Post: 03-21-2013, 10:01 PM
  3. allow reprogramming of Mountain Mode to EV Hold Mode and I'd buy a Volt now
    By jimltz in forum Suggestions for GM - Chevy Volt
    Last Post: 02-13-2013, 01:00 PM
  4. Difference between using Mountain mode and Hold?
    By dgold in forum Generation 1 Volt (2011-2015)
    Last Post: 11-03-2012, 06:11 PM
  5. Hold Drive vs Mountain Mode Call to Action
    Last Post: 06-12-2012, 11:50 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
