Charging a volt in outside without a garage
Grab our Forum Feed
+ Reply to Thread
Page 1 of 3 1 3 LastLast
Results 1 to 10 of 21
Thread: Charging a volt in outside without a garage
  1. #1
    Default Charging a volt in outside without a garage
    For those of you who do not have a covered garage how do you charge your volt? What do you use to protect the charging case from the weather? Is there anything you can buy to cover the charging case to protect it from rain, snow etc?
    2012 Volt/Summit White ordered 7/30/11
    Black leather/white stitching/Ceramic accents
    Bose upgrade/Navagation
    Backup camera
    Polished chrome wheels
    All options/Fully loaded
  2. #2
    Join Date
    Sep 2010
    Location
    San Diego, CA. VIN B-95
    Posts
    2,631
    Default
    Quote Originally Posted by Hollywoods View Post
    Caveats: I have a covered garage (it's the thing that all the crap^h^h^h^hstuff is stored in so the Volt can't park there). And Southern California never gets any weather.
    Normally my EVSE is plugged into a plug in the garage so the controller stays indoors. But for those times I can't do that I run my EVSE as I posted in this posting.
    Basically I bought a boot box from the Container Store and put the EVSE controller in there. The control box is reasonably weather rated by itself, but I didn't want to just leave it laying on the ground. An advantage of this size box is it fits under the car, even with as low as the Volt is to the ground.
    YMMV in snow...
    P.S. I never leave my EVSE laying around without locking it up to something...
  3. #3
    Join Date
    Jan 2011
    Location
    Rancho Palos Verdes, CA
    Posts
    2,171
    Default
    I charge my Volt outside at work. The 120v controller is hung on the wall outside next to the outdoor socket. It stays there all the time. I fabricated a little aluminum sort of eyebrow to hang off the wall and deflect the worst of the rain. It has been there since March, and there were some pretty significant rains in late March. It's working fine. It is rated to be outside, and I think it's fine to use it that way. There have been photos here from time to time of even 240v controllers mounted outside, some of them with boxes around them and some not. if you search the old threads on the forums you can probably find something which will help.
    I share Rusty's concern about theft. Fortunately, my controller is behind a locked gate. We made a hole in the fence and pass the plug out to the parking lot each AM, LOL.
  4.
    Advertisement
  5. #4
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    5,837
    Default
    My roof overhang keeps it pretty well protected and I plug into a covered GFI outlet. If you dont have an overhang, you could make a two sided box with a shed roof that encloses the charger and the outlet. A simple weekend project using 1x6 sides and a 1x12" roof. Plywood, pine, or cedar would work. If you want to get fancy add a simple door. I could find nothing on the unit or install instructions relating to exterior use.
    I use the GFI test button to test the system daily, after I unplug the car. So it acts as an Off switch as well.
    B3320
    Best All Electric Miles: 54.2
    Lifetime: 32,109 miles, 143 MPG, Remaining Oil Life 98%
    Typical Commute: 57-67 miles
    30 day Stats: 1288 miles, 250+
    MPG, 87% Electric, 13% gas, Saved 52 gal., 24 kW-hr/100 miles
    VOLT TIPS & SECRETS
  6. #5
    Join Date
    Aug 2008
    Location
    Carlsbad, CA
    Posts
    783
    Default
    I just purchased a Voltec 240 VAC charger, The installations directions state "The Charge Station may be installed outside and can be mounted on a beam and wired through the conduit on the bottom of the Charge Station."
  7. #6
    Default
    I hook my charger up at work and have to use an extension cord to reach the outlet. The cord lays on the sidewalk. It's been out in heavy rains, hot sun, with no problems so far.
    Volt # 2262, picked up on Earth Day 2011. GO VOLT! LOVE THIS CAR!
  8. #7
    Join Date
    Jul 2011
    Location
    Melbourne, Victoria, Australia
    Posts
    152
    Default
    Quote Originally Posted by HOUSTONVOLTAGE View Post
    I would not recommend using an extension cord to charge the Volt. On Chatper 9, Page 55 of the owners manual it states,
    An extension cord should not
    be used to charge the vehicle.
    Use of an extension cord may
    increase the risk of electric
    shock or other hazards.
    If an extension cord is used
    because of limited access
    to 120V AC power, use the
    following safeguards:
    The 120V AC outlet should be
    GFCI protected.
    The extension cord should be:
    . GFCI protected.
    . 12 or 14 gage, 3 conductor.
    . Rated for outdoor.
    But I guess if you follow those instructions you will be fine.
  9. #8
    Join Date
    Apr 2011
    Location
    Livonia MI
    Posts
    773
    Default
    I charge my Volt outside in the rain occasionally when I plug in the 120 volt charge cord while stopped at a location that allows me to plug in. Just keep the box connected to the short cord off the ground and out of water. The components are protected from the weather. Checking the Volt's owner's manual, I see no cautions about charging in the rain or snow (but it does warn against using extension cords).
    Interestingly, on page CH-2 of the 2011 Nissan Leaf Owner's manual (shared via a link through this forum earlier), it warns "Do not plug in or unplug the plug with wet hands and do not stand in water, liquid or snow. This may cause an electric shock which may result in serious personal injury or death." They also have dire warnings against getting inside the Leaf (or opening the rear hatch) when it is charging if you have a pacemaker. They also warn to make sure there is no water in the charge port and to check that it is not damaged by rust.
    My understanding is that the Volt has sufficient internal GFCI protection and charger intelligence to shut down the charge if there's any current leakage. Of course, electrical outlets and charger installations may vary, so it is a good idea not to assume there is GFCI protection on the outdoor electrical outlet, particularly if you touch the prongs that go into the 120V electrical outlet.
  10. #9
    Join Date
    Sep 2010
    Location
    Lyndhurst, NJ
    Posts
    377
    Default
    BLACK VOLT #218 - "PESTILENCE"
  11.
    Advertisement
  12. #10
    Join Date
    Jul 2008
    Location
    San Diego
    Posts
    6,476
    Default
    Quote Originally Posted by ssj4vegita2002 View Post
    This seems like the most elegant 120v solution for outdoor charging posted so far.
+ Reply to Thread
Similar Threads
  1. Condo Parking Garage - Obtaining a 120V 15A outlet for charging
    By mike1 in forum Chevy Volt Owners Forum
    Last Post: 07-05-2011, 07:52 PM
  2. garage mod
    By goyogi in forum Chevy Volt Accessories and Modifications
    Last Post: 01-26-2011, 01:24 AM
  3. My Volt in my New York City garage
    By travelguy2500 in forum Chevy Volt Owners Forum
    Last Post: 12-18-2010, 09:59 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
