OnStar MyLink Android App updated to OnStar RemoteLink
Grab our Forum Feed
+ Reply to Thread
Page 1 of 3 1 3 LastLast
Results 1 to 10 of 24
Thread: OnStar MyLink Android App updated to OnStar RemoteLink
  1. #1
    Join Date
    Sep 2010
    Location
    Lyndhurst, NJ
    Posts
    377
    Default OnStar MyLink Android App updated to OnStar RemoteLink
    The android app updated this morning. Aside from the name change [apparently to stop confusion with the new MyLink software bundle that will be in the newer Chevy's] they added in an actual number fuel indicator for the Volt remaining. Mine now gives the % left as well as gallons left and range.
    https://market.android.com/details?i....mobile.mylink
    BLACK VOLT #218 - "PESTILENCE"
  2. #2
    Join Date
    Dec 2010
    Location
    Houston, TX
    Posts
    1,481
    Default
    Just downloaded the iPhone version. The old version already had those features you were missing, so there's almost no difference for our phone other than the name.
    I did test a remote start and it only took about 12 seconds versus the normal 60+ seconds. Although, I don't trust that will last because the last iPhone update of the OnStar app worked faster for a short while before it went back to minute plus for commands to complete.
    Volt #947 Delivered on 2/25/11 -- Sold!
    240V Blink Installed 10/28/11 -- Returned!
  3. #3
    Join Date
    Sep 2010
    Location
    Lyndhurst, NJ
    Posts
    377
    Default
    I didn't remember it giving an actual fuel level, just the %. Either way I hope they keep updating it. What I'm really looking forward to is those efficiency graphs on the MyVolt website.
  4.
    Advertisement
  5. #4
    Join Date
    Apr 2011
    Location
    Wickenburg, AZ
    Posts
    418
    Default
    Quote Originally Posted by ssj4vegita2002 View Post
    I'm not sure you have to install a new version. When I launched the old MyLink on my Android phone I could see all of the info you are talking about (%, gallons, & range).
    VIN # 0985
  6. #5
    Join Date
    Dec 2010
    Posts
    21
    Default
    The only thing besides the name that changed is the icon for the oil remaining.
  7. #6
    Join Date
    Aug 2010
    Location
    Berwyn, PA
    Posts
    1,146
    Default
    Quote Originally Posted by voltage692 View Post
    My impression is that communication between the OnStar app and the Volt is via SMS text messaging. Text-message delays vary quite a bit, usually from a few seconds to a minute or more. Also, this communication may involve a handshake (say, for security), so two or three messsages may have to go back and forth. I think this also explains why it takes quite a few seconds to retrieve up-to-date status information from the Volt, either to a smartphone or to the website.
  8. #7
    Join Date
    Sep 2010
    Location
    San Diego, CA. VIN B-95
    Posts
    2,631
    Default
    Quote Originally Posted by Slapshot28 View Post
    My bet is for an SMS "ET phone home" message, with the bulk of the security and data retrieval done via an IP data connection. I'd sure hate to do a Diffie-Hellman over SMS. And DH over a connectionless interface would require an HMAC bigger than an SMS message would enjoy.
    At least I hope there's data security and integrity in the GM message protocol...
    I'd sure love to find a USB connection to the OnStar device. But for that matter, anyone with a Verizon phone and appropriate diagnostic software (such as QXDM) could monitor the paging channel for messages to the car. You'd just need to know the IMSI.
  9. #8
    Join Date
    Oct 2010
    Location
    Chicagoland VIN:B-01234
    Posts
    3,514
    Default
    Mike could probably tell you --- from his page http://crichton.sacknet.org/volt/
    I've written some code to interface with the OnStar webservice interface used for the iPhone/android apps.
    In the thread about his tool he mentioned they may be changing their method for security and the API (he meet with OnStar folks) "Yeah, most likely a system where an app developer can redirect you to an onstar server for authentication, then onstar can pass the developer back a token without the developer having to see the credentials."
    UPDATE: Excellent point by Rusty in the next thread.
  10. #9
    Join Date
    Sep 2010
    Location
    Posts
    2,631
    Default
    I presume the iPhone/iPad/Android apps never talk directly to the car, and only talk to the car through the application servers. So Scott I think we're talking two different security realms (user app to server, and server to car).
    I presume the user app to server interfaces are reasonably zippy enough (they should at least not be significantly communications limited). I'm presuming the OnStar server to car interface is the limited one I'm talking about here.
  11.
    Advertisement
  12. #10
    Join Date
    Apr 2011
    Location
    Livonia MI
    Posts
    771
    Default
    Not sure about the Volt, but past versions of OnStar had a delay, even after the advisor on the phone said they would unlock the doors for you. The reason is that OnStar "goes to sleep" when the vehicle is parked so it doesn't run down the (small) 12 volt battery (needed to power the electronics, so the Volt can start). Doesn't seem like much, but think of a car parked for weeks at the airport, or not driven in the winter. With the car parked, the contactors are open, so the high-voltage battery is not charging the 12 V battery via the DC/DC converter. So the onboard OnStar module would power up briefly every minute or 2 - think of turning your cell phone to airplane mode than back to receive calls again. The OnStar server keeps trying until the vehicle's OnStar wakes up every minute or two. In the past, the longer the vehicle sat, the less frequently it would wake up the phone connection.
Similar Threads
  1. OnStar Issues?
    By tfford in forum Volt Ownership Forum
    Last Post: 11-01-2012, 10:27 AM
  2. OnStar MyLink Sluggish
    By ocryan in forum Volt Ownership Forum
    Last Post: 11-26-2011, 04:01 PM
  3. OnStar MyLink app was crashing for me
    By ChrisC in forum Volt Ownership Forum
    Last Post: 04-19-2011, 06:21 PM
  4. Blackberry App for Onstar Mylink?
    By adamsocb in forum Chevy Volt Accessories, Modifications, and Hacks
    Last Post: 01-13-2011, 08:57 PM
  5. Onstar MyLink
    By Michael in forum Chevy Volt News and Events
    Last Post: 10-29-2010, 12:21 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
