Can the traction control system reduce regen as it can reduce aceleration?
Grab our Forum Feed
+ Reply to Thread
Results 1 to 3 of 3
Thread: Can the traction control system reduce regen as it can reduce aceleration?
  1. #1
    Join Date
    Jan 2011
    Location
    Hartland, MI
    Posts
    819
    Default Can the traction control system reduce regen as it can reduce aceleration?
    Thinking about driving in "L" in very slipery conditions, if the traction control can not reduce regen this could lead to loss or reduction of control.
  2. #2
    Join Date
    Apr 2011
    Location
    Livonia MI
    Posts
    934
    Default
    The brakes seamlessly blend regen and hydraulic braking as needed, and the ABS modulates braking as needed to keep the wheels rolling and maintain control while avoiding skids. Myself, I would just leave it in D, especially in very slippery conditions (it is front-wheel drive).
  3. #3
    Join Date
    Jan 2011
    Location
    Hartland, MI
    Posts
    819
    Default
    Thinking about it from driving in "D" if braking with greater regen as much or more than "L" .the if the anti lock function is needed it would have ot also momentarly stop regen for the antilock breaking to work correctly.
    And until we know the answer to what the traction control will do in "L" without the break peddel being depressed, I would agree that under slipery conditions the use of "L" should be avoided.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Does the Regen System act as a Fast DC Charging System?
    By Rich Remund in forum Chevy Volt Accessories and Modifications
    Last Post: 03-25-2011, 08:38 PM
  2. Did they reduce the wheel size again? Looks like it.
    By YoSePpI in forum Chevy Volt Engineering and Design
    Last Post: 07-15-2010, 03:47 PM
  3. Reduce tire noise by 50%
    By anvilis in forum Chevy Volt Engineering and Design
    Last Post: 07-20-2009, 12:38 AM
  4. Electric cars as a way to reduce emissions
    By Jean-Charles Jacquemin in forum Politics, Finance, and Environment
    Last Post: 12-19-2008, 10:58 PM
  5. GM to consider reduce range Volts!
    By Glen M in forum Chevy Volt General Discussion, News, and Events
    Last Post: 09-17-2008, 11:48 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
