High voltage battery manual service disconnect (MSD)
Grab our Forum Feed
+ Reply to Thread
Results 1 to 9 of 9
Thread: High voltage battery manual service disconnect (MSD)
  1. #1
    Join Date
    Jul 2011
    Posts
    2
    Default High voltage battery manual service disconnect (MSD)
    Hi,
    I have pulled out the service plug of the HV battery (MSD).
    After putting the service plug back in the HV battery, the car will not power on...
    ("power off" message appears on the center screen).
    So far, here is what i've tried to do to solve the problem, with no luck yet...:
    - 12V power latch
    - tried to reset errors with basic OBD diagnostic tool but doesn't work...
    - error messages that appear are P1E00 and P0AFA
    - fuse check
    So my question is:
    Is there a specific procedure required to re-arm the HV battery once the MSD plug has been pulled out and back in?
    Any help from Volt specialists appreciated, thanks
    Alex
  2. #2
    Join Date
    Oct 2010
    Location
    Chicagoland VIN:B-01234
    Posts
    3,507
  3. #3
    Join Date
    Jul 2011
    Posts
    2
    Default
    Independant contractor. Any idea of a workaround to this problem?
  4.
    Advertisement
  5. #4
    Join Date
    Sep 2010
    Location
    San Diego, CA. VIN B-95
    Posts
    2,631
    Default
    Quote Originally Posted by Alex92 View Post
    Which to my read is a polite way to answer "Maybe" to the question "Are you working for a competitor".
    Be that as it may, I vaguely recall in the thread on installing a high end sound system (no, I'm not going to look up the thread, 'cause I'm kinda busy) that the subject of the service plug came up. The short answer was "don't do that" as I recall.
    You might want to see if you can dig that one up.
  6. #5
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    5,375
    Default
    This country has had many people with a "I wonder what happens if" sense of adventure and curiosity. Sometimes it leads to a new discovery, sometimes it just bestows "wisdom" (as in, I won't try that again).
    Worst case, you get the Volt flat bedded to a dealer. Just start practicing the answer to, "And why did you do that?" with "I wanted to see what would happen".
    B3320
    Best All Electric Miles: 54.2
    Lifetime: 30,821 miles, 139 MPG, Remaining Oil Life 100%
    Typical Commute: 57-67 miles
    30 day Stats: 1100 miles, 201
    MPG, 82% Electric, 28% gas, Saved 42 gal., 26 kW-hr/100 miles
    VOLT TIPS & SECRETS
  7. #6
    Join Date
    May 2009
    Location
    Virginia
    Posts
    531
    Default Don't start casting stones just yet
    There are many reasons why someone might want to disengage the HV pack. I had a windshield replaced, and the Volt manual recommends disconnecting the pack. I told the Glass Tech this, and he just smiled and said, "don't think that is necessary."
    Marc Lee
    Volt 836!
  8. #7
    Join Date
    Sep 2008
    Posts
    2,487
    Default
    I'll presume you didnt remove the MSD with the car powered up...
    There is of course a detailed process for it's correct removal which is only PART of the HV Disabling process (which also includes disconnecting the 12V battery prior to MSD removal).
    What was the original intent of it's removal??
    With the car OFF (or 12V disconnected) you can generally remove and then reinstall the MSD without issue.(I've done it) But if you tried to power up the car with the plug removed, numerous HV interlock DTCs would have set.
    The DTC P0AFA you indicate is actually related to very low Li-Ion battery voltage. It won't set on it's own from just removing the MSD.
    However certain high voltage battery DTCs cannot be read or cleared with "generic" OBD2 scan tools and are latched in such a fashion that they must be erased using the GM MDI tool via a precise process.
    Someone that isnt at least a "hybridized" automoive technician shouldn't attempt to mess around with the high voltage systems.
    My advice would be to tow it to the closest Volt dealer.
    WopOnTour
    Follow the Chevy Volt on Twitter! @WopOnTour
  9. #8
    Join Date
    May 2011
    Location
    Raleigh, NC
    Posts
    33
    Default
    I read this post when it was originally posted and the reason he can't take it to an authorized volt dealer is bc he said this car was imported to France...tisk tisk tisk...
  10. #9
    Join Date
    Sep 2008
    Posts
    2,487
    Default
    Quote Originally Posted by Vettes980 View Post
    Ahh that makes sense. He must have edited the post after Scottf started asking questions...
    WOT
Similar Threads
  1. Helm Inc delays sale of Chevy Volt Service Manual
    By Raymondjram in forum Engineering and Design
    Last Post: 09-09-2011, 04:13 PM
  2. Voltage Spikes - Lighting Protection
    By foypat in forum Engineering and Design
    Last Post: 02-06-2011, 10:44 AM
  3. Inside Line's disconnect with MPG
    By Marc Lee in forum Chevy Volt News and Events
    Last Post: 02-05-2011, 12:24 PM
  4. Over-voltage protection
    By misslexi in forum Suggestions for GM
    Last Post: 12-10-2009, 03:20 AM
  5. France is at last setting the high speed in battery research
    By Jean-Charles Jacquemin in forum Lithium and Advanced Automotive Batteries and Charging
    Last Post: 09-29-2009, 09:43 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
