2 Questions about Heating the Volt
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
Thread: 2 Questions about Heating the Volt
  1. #1
    Join Date
    May 2012
    Location
    MN
    Posts
    351
    Default 2 Questions about Heating the Volt
    1. How much electricity does the rear window defog use? I'm not talking auto defog or front defog, only what's used when i push the button to defog the back window.
    2. How much electricity is used during a full 10 minute winter pre-conditioning? Obviously there are some factors here including the setting of the interior temp, outside temp, etc. but let's just say if I have it set to comfort and low seventies in the winter. Ballpark how many miles of range do I lose doing a remote start if not plugged in?
    Thanks
    2014 Crystal Red, Pebble Beige
  2. #2
    Join Date
    May 2011
    Location
    Delaware
    Posts
    7,928
    Default
    Quote Originally Posted by realdb2 View Post
    If I remember right, it was around 200W - it might have been 400. It certainly eats much less than the main coolant heater.
    Thanks
    The theoretical maximum is a little over 1 kWh (10% of the usable battery - likely around 3 miles in that kinds of weather) - 6 kW heater (+fans/seat heater/rear defroster, etc.) * 10 minutes
    My usual experience is more like half that, but as you say, it depends on a lot of factors - outside temps as well as settings, and snow on the car will cool things faster and make the heat work harded
    Walter
    2016 Tesla X75D delivered 8/25/16
    Hidden Content
  3. #3
    Join Date
    Jun 2012
    Location
    New Hampshire
    Posts
    2,683
    Default
    2. It is really to highly variable to tell. I have remote started when it's 45F and really not lost any range, but I've also remote started when it's 0 and lost several miles.
    Love My Volt!
    Blue Topaz, Black/Ceramic White Leather, Nav 2012
    New Hampshire
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    May 2012
    Location
    MN
    Posts
    351
    Default
    Quote Originally Posted by saghost View Post
    Thanks for the quick reply! That's less than I thought actually.
    What I'm trying to figure out is if for example I have 15 miles of range left and I have a 10 mile drive home, do I do a remote start or not? Situations like that.
    Thanks
  7. #5
    Join Date
    Jun 2008
    Location
    Tolland, CT
    Posts
    1,391
    Default
    Thanks
    10 miles?! I can do that in sub-zero temperatures with no heat.
    2012 Blue Volt
    Voltstats.net: 2012-16084 (C-6084)
    Hidden Content
    In my garage charging (L1) for the 1st time on 24-Mar-12
    Typical Commute: 34 to 39 miles each way (Charging at Work on L2!)Hidden Content
    All-Time Best....55.4 eMiles on a single charge.
  8. #6
    Join Date
    May 2012
    Location
    MN
    Posts
    351
    Default
    Quote Originally Posted by David B. Kelting View Post
    I didn't say I couldn't do it, just don't want to if I don't have to.
  9. #7
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    15,222
    Default
    Some measurements gathered over the years:
    Rear Defrost - 475 watts
    Climate, Fan Only, Full (Climate Power: 17%) - 270 Watts
    A/C, Eco, LO, Auto (Climate Power: 34%) - 1,535 Watts
    A/C, Comfort, LO, Auto (Climate Power: 59%) - 1,875 Watts
    Front Defrost, 72F, Auto, Comfort - 1,425 Watts
    Heat, HI, Full Fan, Comfort (Climate Power 75%) - 6,250 Watts
    Heated Seat Low: 15 Watts - 33% duty cycle (30SecOn/(30+60))
    Heated Seat Med: 30 Watts - 60% duty cycle (60SecOn/(60+40))
    Heated Seat High: 45 Watts - ??% duty cycle
    Sitting in D with foot on brake (0 MPH) - 0 Watts
    Creeping forward in L - 400 Watts
    Pedal to Floor in Sport Mode for a moment while stopped - 49,405 watts
    The High Voltage Battery heater draws 900W from the HVB
    So Seats (even on High) are way better than Heat, Fan on High is way better than Defrost, Defrost is way better than Heat.
    B3320
    Best All Electric Miles: 54.2
    Lifetime: 84,576 miles, 135 MPG, Remaining Oil Life 74%
    Typical Commute: 60 miles
    30 day Stats: 1366 miles, 125
    MPG, 65% Electric, 33% gas, Saved 48 gal., 27 kW-hr/100 miles
  10. #8
    Join Date
    Jun 2008
    Location
    Tolland, CT
    Posts
    1,391
    Default
    Well, truth be told...we'll get heat from the ICE in sub-zero temperatures whether we want it or not. In my 2012 Volt, when the temps dips to 25*F the engine will start and I'll put the heat on HI & Comfort to take full advantage. In the MY2013/2014 that temp is 35*F or 15*F, depending on you personal settings.
    2012 Blue Volt
    Hidden Content
  11. #9
    Join Date
    Oct 2013
    Location
    Reno, Nevada USA
    Posts
    7
    Default
    Two of my neighbors have started driving Volts. I noticed today, as I was waiting at the stoplight when leaving for work, that one of my Volt driving neighbors was bundled up with a large coat and gloves for his Volt commute. I think he either wants to save a lot of money on fuel costs, or is highly competitive in Volt Stats. It has been dipping down into the low thirties/high twenties here in Reno this week.
  12. Advertisement
  13. #10
    Join Date
    Nov 2011
    Location
    Floyd, Virginia
    Posts
    1,480
    Default
    My dodge is to simply pre-heat the cabin with a foot ceramic warmer for awhile before I leave, then I usually make the trip without discomfort.
    If I was in a "make it or not" situation - 10 mile drive and not much extra charge, I'd run MM till the car warmed up - about .03 gal of gas or so, maybe twice that if it's truly cold. It does show up badly on your mileage, but...it's still really cheap, and the one time you get nearly 100% of the energy in gasoline, as while the engine is running, it's not only giving you the waste heat, but also charging the battery if it's under threshold....and probably heating that too - and that's a good thing. The battery is more efficient when warm.
    Preconditioning rarely works well for me, as I'm off grid solar, and drawing that much power plugged in before the sun has charged the house up isn't good.
    And it can't keep up with that 6kw, even with L2 charging. I don't know just why an 800w lowes heater run off shore power can heat the cabin, when the 6kw one takes longer and takes much more power to do it, but it is what it is. I don't know if the reason is that the built in heater is also heating the battery, could be.
    Volt #5014, White. All off grid solar powered. My sci-tech boards:
    Hidden Content
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Volt Heating/Cooling Systems
    By George S. Bower in forum Mechanical Systems - Chevy Volt
    Last Post: 01-20-2016, 02:02 PM
  2. Heating the Volt cabin a better way
    By montgom626 in forum Generation 1 Volt (2011-2015)
    Last Post: 01-28-2013, 05:09 PM
  3. Engine Assisted Heating and Engine Assisted Heating (Plugged‐In). What does it mean?
    By BlackVolt in forum Chevy Volt Engineering and Design
    Last Post: 06-07-2012, 02:56 PM
  4. Comments and questions about DRL and pre heating the vehicle.
    By silvercorvette in forum Generation 1 Volt (2011-2015)
    Last Post: 11-18-2011, 09:55 PM
  5. Volt uses more energy for AC than heating?
    By Marc Lee in forum Chevy Volt General Discussion, News, and Events
    Last Post: 05-18-2011, 01:25 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
