Back up light
Grab our Forum Feed
+ Reply to Thread
Page 1 of 5 1 5 LastLast
Results 1 to 10 of 44
Thread: Back up light
  1. #1
    Join Date
    Nov 2010
    Location
    Grosse Pointe, (Detroit) Michigan
    Posts
    507
    Default Back up light
    That center mounted backup light on our Volts is both ugly and not very effective. When backing up at night it does a poor job of illuminating the area behind the car. I also think that it looks ugly although others may not feel that way.
    VOLT # B-1276
  2. #2
    Join Date
    Dec 2010
    Posts
    803
    Default
    Quote Originally Posted by maynard View Post
    I think it looks great and works well, even though it was lifted from the Saturn Sky. In particular, its low mounting really helps the usefulness of the back-up camera at night.
  3. #3
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    5,397
    Default
    I'm fine with it's look and styling. Not having ever had a backup light/camera, it's the best one I have ever had! :-)
    B3320
    Best All Electric Miles: 54.2
    Lifetime: 30,821 miles, 139 MPG, Remaining Oil Life 100%
    Typical Commute: 57-67 miles
    30 day Stats: 1100 miles, 201
    MPG, 82% Electric, 28% gas, Saved 42 gal., 26 kW-hr/100 miles
    VOLT TIPS & SECRETS
  4.
    Advertisement
  5. #4
    Join Date
    Jan 2011
    Location
    Rancho Palos Verdes, CA
    Posts
    2,118
    Default
    Quote Originally Posted by Steverino View Post
    I agree. Works for me. +1
  6. #5
    Join Date
    May 2009
    Location
    Virginia
    Posts
    531
    Default Criticisms Not Welcome
    Maynard I am with you. Although I don't mind the aesthetics of the backup light, in fact, I think it fits with the futuristic, "make it so number one" theme they have going on. I mean if that dash isn't straight off of Jean Luc Picard's Bridge then I don't know my STTNG.
    However, the single light does NOT provide adequate lighting when backing up. I understand they went with a solo light to meet EU standards, but it needed to be a stronger light than that.
    And as usual criticism of the Volt, or as I like to think of it, "how to make the Volt better" is met with all the enthusiasm of a "Mounds" bar in the punch bowl. :-)
    Marc Lee
    Volt 836!
  7. #6
    Join Date
    Nov 2010
    Location
    Posts
    507
    Default
    I guess our problem with the lack of illumination is because we don't have the backup camera option. It may be OK when you have that camera.
    VOLT # B-1276
  8. #7
    Join Date
    Mar 2011
    Location
    Erin,ON
    Posts
    822
    Default
    What about trying a brighter LED bulb in place of what ever is in there? When backing up I'm usually in a lit parking lot or backing into my garage that has the light on when I open the door. But more vision is better for sure! I don't know how good or bad these guys are but I found them advertising on this site...
    http://www.superbrightleds.com/vehic...t/volt/11/1131
    Might be worth a try for that one that has 45 diodes on it!
  9. #8
    Join Date
    Dec 2010
    Location
    Houston, TX
    Posts
    1,481
    Default
    Yea, just put in a brighter bulb yourself and call it the day. I am sure GM has better things to work on.
    Volt #947 Delivered on 2/25/11 -- Sold!
    240V Blink Installed 10/28/11 -- Returned!
  10. #9
    Join Date
    Aug 2010
    Location
    Berwyn, PA
    Posts
    1,141
    Default
    This thread shows pics of a nice upgrade to the Volt's backup camera lighting: http://gm-volt.com/forum/showthread....ghlight=backup
  11.
    Advertisement
  12. #10
    Join Date
    Sep 2010
    Location
    San Diego, CA. VIN B-95
    Posts
    2,631
    Default
    Quote Originally Posted by Slapshot28 View Post
    I got the V-LEDs rear LED license frame for my birthday recently. It needs some more tweaking, but that's a little more difficult when it doesn't get dark 'till after 8:00. I masked off the center two LEDs as described (I'm just using electrical tape for now) and they certainly through a lot more light out the back end!
Similar Threads
  1. LED light bar for back bumper reflective strips
    By Xzlon in forum Chevy Volt Accessories, Modifications, and Hacks
    Last Post: 02-21-2011, 01:56 AM
  2. Found this on my car when I got back
    By rtmey2000 in forum Volt Ownership Forum
    Last Post: 02-20-2011, 02:17 PM
  3. Hi gang, I'm back
    By misslexi in forum Newcomers
    Last Post: 11-20-2010, 11:44 AM
  4. Bring back the EV1
    By Desertstraw in forum Electric Car Competitors
    Last Post: 09-18-2010, 06:11 PM
  5. 3th seat in the back
    By filiep in forum Suggestions for GM
    Last Post: 11-17-2009, 04:05 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
