Brake Pedal Feel
Grab our Forum Feed
+ Reply to Thread
Page 1 of 5 1 5 LastLast
Results 1 to 10 of 48
Thread: Brake Pedal Feel
  1. #1
    Default Brake Pedal Feel
    Hi all,
    I have posted before about my issues with the brake pedal and the hydraulic pump. Mine pump seems to activate quite often when my foot is on the brake and i am stopped. My Volt advisor suggested I take the car in so I finally took my Volt into the dealer. The mechanic, very nice guy, did some tests and compared my car to demo car (i had driven that before and noticed it didn't do the pump thing as frequent as my car).
    He was in communication with the main volt engineers, but they left early because of the holiday so no resolution on my issue. I hope to hear back Tuesday to find out why mine seems to pump quite often.
    He showed me an a document #P10307A which is created to deal with the 12 volt battery and the Brake Pedal feel. Just wondering if anyone else has gotten this. He gave me a copy. I can post if you guys want to see it.
    VIN #1849 - LA/Palm Springs, CA
    03/31/2011 - (4800) Rail ramp unload. Vehicle has been unloaded from train.
    04/01/2011 - (5000) Vehicle has been delivered to dealer.
    04/01/2011 - (4200) Shipped (vehicle is shipped to the dealer or interim point of delivery).
    04/02/2011 - (6000) Vehicle delivered to customer or dealer has completed customer paperwork.
  2. #2
    Join Date
    Jan 2011
    Location
    Rancho Palos Verdes, CA
    Posts
    2,118
    Default
    FWIW, I have driven my Volt almost 5K miles and the brake pedal has felt totally normal at all times - indistinguishable from a conventional car. And I don't hear anything that sounds remotely like a hydraulic pump cycling. So something must be going on with #1849. Keep in their faces and please keep us up to date.
    #1756
  3. #3
    Join Date
    Oct 2010
    Location
    Chicagoland VIN:B-01234
    Posts
    3,508
    Default
    Quote Originally Posted by Noel Park View Post
    FWIW, I have driven my Volt almost 5K miles and the brake pedal has felt totally normal at all times - indistinguishable from a conventional car. And I don't hear anything that sounds remotely like a hydraulic pump cycling. So something must be going on with #1849. Keep in their faces and please keep us up to date. #1756
    Ditto for my Volt and brakes. I'm very happy with them but to be honest I use them much less since I drive in (L)ow all the time. Still when I use them they appear normal.
  4.
    Advertisement
  5. #4
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    5,391
    Default
    Like Scott, I use L all the time to regen brake. Have not noticed anything unusual when at a stop light.
    I am getting much better at anticipatory braking, but kick myself when I don't let off the accel soon enough and have to hit the brakes harder. My brother noted that the Volt teaches the driver to drive more efficiently.
    B3320
    Best All Electric Miles: 54.2
    Lifetime: 30,821 miles, 139 MPG, Remaining Oil Life 100%
    Typical Commute: 57-67 miles
    30 day Stats: 1100 miles, 201
    MPG, 82% Electric, 28% gas, Saved 42 gal., 26 kW-hr/100 miles
    VOLT TIPS & SECRETS
  6. #5
    Join Date
    Sep 2008
    Posts
    2,487
    Default
    Quote Originally Posted by dannyrrr View Post
    Hi all,
    Your VA would have advised you to visit your dealer if you had ANY sort of performance concern with your brakes, so that a trained technician can inspect and if warranted validate those concerns. If they sent you off on your way I suspect there's nothing wrong with your brakes.
    FYI The electric pump is supposed to operate whenever you step on the brakes hard enough to demand friction brakes and typcially at all times during lower speeds and stops.(it's replenishing the fluid pressure taken from the accumulator to apply the brakes) Generally it's quite difficult to hear though unless you have EVERYTHING off in the interior (heater/AC/radio etc) OR if you have your window rolled down and are driving close to structures, where the sound reflects back easily. If the motor/pump was excessively noisy they would have just replaced it.
    Pedal feel on the Volt is slightly different than "regular" brakes is essentially it's just a "pedal feel simulation" due to the brake-by-wire nature of the system.If you have no brake warnings and the car stops well, there's likely nothing wrong.
    WOT
    PS> I suspect you actually meant PI0307A which is a "New Product" document for Volt technicians that describes various unique yet NORMAL Volt behavior and details including the somewhat unique brake feel (the 2-mode hybrids are identical).
    There are currrently ZERO service bulletins for any sort of brake issues on the Volt, but here is what that document stated about the Volt's brake system.
    Quote Originally Posted by GM in PI0307A
    Normal Brake Pedal Feel and Brake Pedal Vibration
    • The Volt has a unique brake pedal feel. This is because the hydraulic system is not the lone provider of vehicle deceleration. The electric system blends in regenerative and hydraulic braking forces depending upon vehicle conditions. Over several braking events, the customer may perceive that they are applying a consistent brake force and yet the vehicle may decelerate at slightly different rates. This is a normal operating characteristic to maximize fuel economy.
    • The Volt utilizes a braking system that employs a high-speed electric motor/pump. Pump operation can sometimes be heard and felt in the brake pedal as the system sometimes builds pressure.
    Follow the Chevy Volt on Twitter! @WopOnTour
  7. #6
    Join Date
    Jan 2011
    Location
    Posts
    2,118
    Default
    Quote Originally Posted by scottf200 View Post
    I don't drive in L all the time but I do try to be as gentle as possible on the brakes. I wonder how hard you have to push the pedal to go through the regen and deploy the wheel brakes? I was looking at the brake rotors on the Volt the other day and I noticed 2 things:
    1) They are impressively large.
    2) The have a light haze of sort of oxidation on them. If i didn't know better, I would swear that they had never been used.
  8. #7
    Join Date
    Jan 2011
    Location
    Posts
    2,118
    Default
    Quote Originally Posted by Steverino View Post
    Me too, LOL.
  9. #8
    Default
    hi all, thanks for your input but to clarify, the brakes work fine. the issue is when i am at a full stop, i.e. traffic light, and while i am waiting to go again, i hear the pump go off and on several times before i start back up again. i am not worried about the braking ability, its just the noise is quite annoying and if it is not normal, then i want it fixed.
    thanks
  10. #9
    Join Date
    Dec 2010
    Posts
    120
    Default
    Hi all,
    I had some issues with the brake feel initially, and I thought it was that without the regen (was trying to glide in Neutral to hypermile) that my braking pressure was just a lot different feel. I quit with the N and didn't have trouble, but then I had my master cylinder fail (puddle of fluid on the car mat).
    good that they are checking yours out. how do you know when the hydraulic pump is ON? do you hear it? I had not noticed mine.
  11.
    Advertisement
  12. #10
    Join Date
    Nov 2010
    Location
    Tewksbury, MA
    Posts
    539
    Default
    The only time I hear the pump is when I first back out of the garage, and all is very quiet. If it runs at other times, I have not heard it due to noise, from the radio, or just road noise. The pump in its self is very quiet.
    I have been using L almost all the time, but have been experimenting with using L only when in heavy traffic and long or steep hills. On some of my commute the terrain is small rolling hills and the country road I follow is the same. So I find that allowing the car to maintain momentum via being in D is better then L and seems to give me a few extra miles of battery range.
    Pat
    VIN#...B...01921 - Build completed 03/1/2011 - Picked up my new red Volt at Atlantic Chevrolet on Saturday March 26th, 2011 .
Similar Threads
  1. I feel ill
    By akojim in forum Chevy Volt News and Events
    Last Post: 08-16-2011, 07:00 PM
  2. I feel the need... the need... for more electricity!
    By EngineOffCoasting in forum Suggestions for GM
    Last Post: 05-11-2011, 07:34 AM
  3. Toyota to Fix Gas Pedal on Recalled Cars
    By misslexi in forum Chevy Volt News and Events
    Last Post: 11-27-2009, 12:18 AM
  4. Green wheel turns pedal bike into electric hog
    By misslexi in forum Off-Topic
    Last Post: 02-26-2009, 07:43 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
