Volt Stats Website / Source Code
Grab our Forum Feed
+ Reply to Thread
Page 25 of 27 FirstFirst 1 15 25 27 LastLast
Results 241 to 250 of 267
Thread: Volt Stats Website / Source Code
  1. #241
    Join Date
    Jul 2010
    Location
    Atlanta GA
    Posts
    1,140
    Default
    Mike -
    Question for you: have you seen GallonsOfGas values below 1.0?
    After 9 months on the same tank, I'll be running out of gas tomorrow. I'm purposely running it dry to test out "limp mode" behavior. Tonight, while I still have a bit of gas left, my downloaded data set is telling me that GallonsOfGas is 0. Not 0.5 or something, a perfect zero. I'm wondering if this "0" behavior in the data is tied to the "Low" indication on the dash when the tank is close to empty.
    Hmmm, no, actually now that I think of it, the Volt was displaying "Low" on the dash for the last week or so but my data feed said GallonsOfGas = 1.17 . It was only today after I burned most of that remaining gas (but NOT all of it) that it reads 0.
    Have you seen all values between 0 and 1, or do they cut off at some low value? Of course it's possible that I'm literally right on the edge of running out, between the bottom two resolution points of the fuel gauge in the tank-- or below it!
    And does that number come straight from OnStar, or do you have to reverse engineer it?
    2011 Volt #284, ordered 30-Jul-2010, built 30-Nov-2010, shipped 15-Dec-2010, delivery 22-Dec-2010, www.FirstVoltInGeorgia.com
    - The FAQ -- answers to your Frequently Asked Questions about the Volt
    - how to track your Volt order, meaning of status codes, railcar tracking
    - do not miss these other great sites: CarStations.com and recargo.com for charger mapping and VoltStats for performance tracking and comparison
  2. #242
    Join Date
    Jul 2009
    Location
    Colorado Springs, Colorado
    Posts
    2,853
    Default
    Quote Originally Posted by ChrisC View Post
    Mike -
    I'll let mike answer but I can say I've had multiple days below 1.0 though 0.986 is the smallest I've seen, other than zero. But I've had it bounce to 0 then back to over a gallon..
  3. #243
    Join Date
    Jul 2010
    Location
    Atlanta GA
    Posts
    1,140
    Default
    Looking at my history, I also saw a few readings at 0.986 last summer, but nothing between that and flat zero.
    It occurred to me to look at my OnStar mobile app, since that shows the gas remaining in yet another way (0-100%), but it now says Low/Low/Low across the board for percent/gals/miles .
  4.
    Advertisement
  5. #244
    Join Date
    Jan 2011
    Posts
    189
    Default
    Yup, there's values in the database between 1 and 0. One thing to keep in mind is that the GallonsOfGas sensor seems to be a bit wobbly, but I'd think 0 would read 0 no matter what.
    Volt #2163 in Kaukauna, WI
    Check out the Volt Stats Page!
  6. #245
    Join Date
    Jul 2010
    Location
    Atlanta GA
    Posts
    1,140
    Default
    Well, something is weird there then. I just got back from my "run the tank dry" session, and it turns out there was about 0.4 gallons in the tank, overnight during the readings where my VoltStats download was saying "0". I know this from the car's efficiency screen that told me how much gas I had consumed. I started off (Saturday) with 1.17 gals indicated per VoltStats download, consumed 0.8 gals yesterday, and today after I ran the car dry I had consumed 1.19 gals total since Saturday morning. 1.17 and 1.19 are very close
    So my experience here this weekend indicates that A) the tank level gauge is extremely accurate (no 0 offset) and B) very low values get reported to you (VoltStats) as 0, but they're not actually 0. Maybe the cutoff is 0.5 or something, and below that they tell you 0? Either that or the tank level sensor just doesn't read well below 1 gallon, although it's very accurate down to the 1 gal level, and the fuel consumed measurement (not tank level) is very accurate.
  7. #246
    Join Date
    Apr 2012
    Location
    New Hampshire
    Posts
    109
    Default
    Any updates on the whole source availability thing with GM? I'd hate to burn a weekend setting up the proxies and running the scenarios I need to reverse it myself only to have GM allow you to re-release your code a week or two later and ending up wasting that effort.
    (Although, I'm not sure I believe they'll ever let that happen -- the CES announcements make it sound like they're probably charging for API access to a limited set of developers.)
    Alternately, has anyone com across any documentation elsewhere on the 'net on the existing APIs?
  8. #247
    Join Date
    Oct 2010
    Location
    Chicagoland VIN:B-01234
    Posts
    3,510
    Default
    Quote Originally Posted by GeorgeH View Post
    <snip>the CES announcements make it sound like they're probably charging for API access to a limited set of developers.)<snip>
    Mentioned in this video as well. Lot of cool things that OnStar is doing.
    OnStar-s-Nick-Pudar-talks-smart-grids-at-CTIA-2012-(video)
    http://gm-volt.com/forum/showthread....IA-2012-(video)
  9. #248
    Join Date
    Jan 2011
    Posts
    189
    Default
    Sorry, no news, and probably not going to be any. I haven't heard a peep from Onstar in months.
  10. #249
    Join Date
    Apr 2012
    Location
    New Hampshire
    Posts
    109
    Default
    Quote Originally Posted by mrosack View Post
    Unfortunately, that doesn't surprise me. As I said in my reply, I suspect they asked you to take the code down with the intention of selling access to the APIs to a limited set of developers. And, as far as I can tell, you're the only person who has reverse engineered them and published anything about them. If anyone else has been doing it, they're either describing them in a way that is making them hard to find, or are being deliberately quiet about it.
    Which is a shame -- either they're just being short-sighted, or there's flaws with the model they don't want public. In either case, I guess I'll just redo the work myself.
  11.
    Advertisement
  12. #250
    Join Date
    May 2012
    Location
    Montreal, Québec
    Posts
    79
    Default
    Any development on the metric stats? I love you site but i really hate MPG....i made a excel sheet to convert everything but it's anoying.
Similar Threads
  1. Testing 10 million lines of code used in Volt
    By JohnK in forum Engineering and Design
    Last Post: 07-19-2012, 12:50 AM
  2. MyVolt Stats
    By ssj4vegita2002 in forum Volt Ownership Forum
    Last Post: 02-28-2012, 12:07 AM
  3. Volt Stats Website
    By mrosack in forum Software/programming/code
    Last Post: 04-22-2011, 01:28 PM
  4. Where is Volt code/operating system located?
    By Lest in forum Software/programming/code
    Last Post: 04-18-2011, 11:53 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
