Will Igniting Fuel With Lasers Make Spark Plugs Obsolete?
Grab our Forum Feed
+ Reply to Thread
Results 1 to 3 of 3
Thread: Will Igniting Fuel With Lasers Make Spark Plugs Obsolete?
  1. #1
    Join Date
    Feb 2008
    Location
    Indian Harbour Beach, FL
    Posts
    4,085
    Default Will Igniting Fuel With Lasers Make Spark Plugs Obsolete?
    Link
    Interesting possibilities - you could arrange a wave front in the ignition which would push harder against the piston - tuning it for speed / load conditions.
    I still like the HCCI approach better, in which the fuel / air mixture is already critical for ignition, allowing much high compression ratios and more energy conversion.
  2. #2
    Join Date
    Dec 2010
    Location
    West Virginia
    Posts
    766
    Default
    This is a subject, that, if I'm in Charge Depletion mode, I don't care about. In Charge Sustaining mode, I'm not sure it matters very much. I mean, how much difference can this laser powered spark plugs make to the overall oil imports, or the rate that oil fields are depleted? Say, compared to a faster shift to an electrified US car parc?
    WVhybrid
    Red Volt Lifetime gasoline fuel efficiency = 0.901 gallons / 100 miles (231 tablespoons / 100 miles)
  3. #3
    Join Date
    Feb 2008
    Location
    Posts
    4,085
    Default
    Quote Originally Posted by WVhybrid View Post
    WVhybrid
    I think it will be decades before the internal combustion engine is obsoleted, because it is so cheap and effective, so it will continue to be pushed by regulations to get cheaper / better / lower maintenance, so these laser spark plugs could help.
    Additionally, if we simply use hydrogen as the combustion fuel, these types of techs may see some use in the coming decades.
Similar Threads
  1. Albany plugs Electric Cars and Charging Stations
    By Paul Slazas in forum Chevy Volt News and Events
    Last Post: 04-22-2011, 07:22 PM
  2. Spark-EV
    By Kevin K in forum Electric Car Competitors
    Last Post: 12-22-2010, 01:38 AM
  3. Koreans make plastics without fossil fuel chemicals
    By Jim Rowland in forum General Motors and General Automotive Topics
    Last Post: 12-10-2009, 05:25 PM
  4. Cheap labor around the world made obsolete
    By Texas in forum Off-Topic
    Last Post: 10-09-2009, 04:17 PM
  5. Prius is obsolete.
    By Jason M. Hendler in forum Electric Car Competitors
    Last Post: 06-22-2009, 07:16 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
