Problem with Charge port door
Grab our Forum Feed
+ Reply to Thread
Page 1 of 5 1 5 LastLast
Results 1 to 10 of 41
Thread: Problem with Charge port door
  1. #1
    Join Date
    Mar 2011
    Location
    Delaware
    Posts
    140
    Default Problem with Charge port door
    I'm not sure if this is the right place for this thread, please move as appropriate.
    I have been having some trouble with my charge port door. On at least two occasions I know for certain that I closed it, but then when I went to start the car I got the door open warning. It could just be I wasn't closing it hard enough or it wasn't fully latching I don't know.
    Then yesterday on my drive home, I suddenly got the warning several miles into my drive. So it was closed or at least registered as closed when the vehicle started and the first part of my trip but then came open. I pulled over and sure enough it was wide open and I reclosed it.
    Has anyone else noticed this?
    Unrelated issue I am getting "chafing" on the center console from the top of the seatbelt buckle. Is anyone seeing this and/or is there an easy fix?
    I dream of a better world, where chickens can cross the road without having their motives questioned
  2. #2
    Join Date
    Nov 2010
    Location
    Tewksbury, MA
    Posts
    539
    Default
    Only time I have had the warning is when I did not shut the door. Never had any other incedents. I do make sure to push it intill I feel it positively latch.
    Pat
    VIN#...B...01921 - Build completed 03/1/2011 - Picked up my new red Volt at Atlantic Chevrolet on Saturday March 26th, 2011 .
  3. #3
    Join Date
    Aug 2010
    Location
    Detroit, MI
    Posts
    2,002
    Default
    Press the door in the center to close. You may have to push a little harder to ensure the door is latch. The door has a harder time closing at the rear edge of the door.
    Volt Advisor Trevor
    Chevrolet Volt Advisor Team
  4.
    Advertisement
  5. #4
    Join Date
    Feb 2011
    Posts
    17
    Default
    I had the same issue several times until I realized this door requires a harder push than what you would normally assume.
    After I started pushing harder the problem disappeared.
  6. #5
    Join Date
    Dec 2010
    Posts
    803
    Default
    I had an issue early on where my charge door wouldn't even latch most of the time. Turned out the locking pin was getting restricted by friction. Some lube at the dealership cured it, and it continues to be fine. Something to check, make sure the locking pin can fully deploy with no noticeable friction.
  7. #6
    Join Date
    Oct 2010
    Location
    Chicagoland VIN:B-01234
    Posts
    3,509
    Default
    Quote Originally Posted by Chevrolet Customer Svc View Post
    Volt Advisor Trevor
    Interesting test video. The charge port door test starts about 0:49
  8. #7
    Join Date
    Nov 2010
    Location
    Austin, TX
    Posts
    126
    Default
    Same thing happened to me the other day; only happened once unless some of those other times I assumed I simply didn't close the door I actually closed it too lightly.
    The other day, I remember closing it before I left (too lightly though), and almost 2 miles into the trip it popped open. Didn't have an opportunity to close it until a red light where I was almost at my destination 5 miles away. I felt embarrassed having to jump out of the car at a red light to close the charge door while the driver of a Prius to my left watched.
    I can almost imaging what was going through their head . . . 'stupid plug in Volt driver forgot to close his charge door'
    -doubledave - Volt owner since Jan 2011 - 2011 Volt # 0724
  9. #8
    Join Date
    Jul 2010
    Location
    Bayamon, Puerto Rico
    Posts
    1,331
    Default
    I have seen many vehicles with the gas filler door open while traveling on highways at high speeds (60 to 65 MPH). Some of those cars have a manual release system operated from inside the cabin, so I believe that they were at full service stations and never left their seats to fill up, but the attendant left the doors open. If you fill up yourself, you are more conscious to put the filler cap on and close the door. These same opened filler door vehicles may have no locking filler cap, so they can also loose the cap if the attendant didn't tighten it, and lose fuel due to evaporation (also may become a fire hazard).
    I strongly recommend that everyone check their gas caps and filler doors every time they approach their vehicles, and be sure that the gas caps are on tight and the doors are well closed.
    Join Date
    Oct 2010
    Location
    Posts
    3,509
    Default
    Quote Originally Posted by Raymondjram View Post
    <snip> be sure that the gas caps are on tight and the doors are well closed. Raymond
    Because the gas tank is pressurized you can bet they have sensors on the pressure. I think the car would let you know!
  11.
    Advertisement
  12. #10
    Join Date
    Jan 2011
    Location
    Rancho Palos Verdes, CA
    Posts
    2,118
    Default
    Yeah, you really do have to push it like you mean it to get it to latch. Thanks for the good tip volt11.
Similar Threads
  1. "Open Door" ding happens when I shut the door, and then also when I lock it.
    By ssj4vegita2002 in forum Error messages/ health monitoring/ DTC's
    Last Post: 03-27-2011, 10:51 AM
  2. Make the charge port door manual
    By voltage692 in forum Suggestions for GM
    Last Post: 03-09-2011, 08:30 AM
  3. charge door
    By doubledave in forum Volt Ownership Forum
    Last Post: 02-05-2011, 09:01 PM
  4. Charge Port Complaint
    By barry252 in forum Volt Ownership Forum
    Last Post: 02-01-2011, 12:19 AM
  5. Charge Door Comments
    By Mark Z in forum VOLT Consumer Advisory Board Discussion Forum
    Last Post: 12-01-2010, 02:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
