OnStar Activation Failure
Page 1 of 3 1 3 LastLast
Results 1 to 10 of 30
Thread: OnStar Activation Failure
    137
    Default OnStar Activation Failure
    So far as i can tell this is an unusual problem with onStar. I'm posting here so that it's recorded for anyone in the future who needs the information.
    On delivery, when pressing my Volt's onStar button to set up the account, the system said "OnStar has not been activated. Press the blue button to connect to onStar." On pressing the button again, "Dialing onStar. Beep...beep...beep...beep...beep. Unable to connect to onStar, try again later." The same symptoms recurred several times in different locations during the week. OnStar technical was unable to contact the car either and said to bring to dealer.
    Dealer had the Volt for two days. The transcript of the service record is:
    Customer states unable to activate onStar at time of purchase and now when attempting to contact system beeps only as if dialing then unable to connect. Customer has contacted OnStar technical support by phone and was advised to take vehicle to dealer. Check and advise.
    Verified customer complaint. Perform base check on vehicle and found both emergency button and blue onStar button both get no connection to onStar errors. Pressing white button gets menu items and will receive commands. No codes I in VCIM. Called TAC case # xxx. Will wait for TAC to return call with OnStar specialist.
    Instructed to continue with PIC4310F. Gathered information as per PIC. Also install EL-49903 into system. Still has same issues with system.
    Disconnected VCIM and let sit 3 minutes. Reconnected system. Attempted to connect to onStar (blue button). Vehicle connects and location of vehicle is given.
    Called TAC for further instructions. Power cycle telematics communication interface control module. Connect to onStar and give location w blue button. System did connect. Performed verification phone call with TAC. Case Closed. Customer will need to setup through blue button and perform digit dial.
    My Volt advisor says that there was a module in the onStar locked up and possibly with a power-related code. So I pick up the car and set up through the blue button. I buy 60 minutes of phone time and the download to my car of those minutes fails. Transfer to onStar tech support. About ten minutes of testing etc, then the minutes download. They were kind enough to give me a free 100 minutes by way of apology for the trouble, which was quite kind.
    I get home, log in to myVolt.com (finally). The web site can't connect to the car. Neither can the iPhone application. I go to the car, can't phone out from the car with onStar.
    Next day, drive to work. I can phone out form the car. I can connect to onStar advisor and tech support. They can't find any issues. iPhone app still not connecting. I delete the iPhone app, re-install it, can now get car info into the iPhone. Connecting at home with myVolt failed, but with iPhone succeeded. Later tonight, myVolt connects correctly.
    So I can't call it quite closed yet, but it's likely that this has been fixed.
    Volt #B1498 -Tuxedo C. Volt
    Fort Lauderdale, FL
    204
    I believe you get 100 free minutes included when you first activate OnStar. We did.
    Volt #951 - 12-Feb-11
    6,293
    Sorry for your problem but this type of stuff happens all the time with electronics. Who knows what the issue was. Seems like it got locked in some weird loop. My guess is you'll never see it again.
    When I first got our car I connected my Nano. It worked great. Yesterday I tried and it wouldn't play. Who knows why. The Volt specialist suggested taking the car to the dealer but I just plugged in a USB drive, which works perfectly. I can have the dealer look at the Nano issue if it's still there when I take the car in to have the tires rotated or for some other reason.
    To follow up on Mark's comment about the 100 minutes, I got the 300 minute package for the same price. As I understand it, the dealer pays for it but my guess is that GM ultimately credits them. IMO that's a good promotion by GM. OnStar is great but while it's on our current car we've never used it. Having used it I know think it's a "must have". As they know in grocery stores, getting people to sample your product can end up selling a lot of it for you.
    137
    5 years of OnStar is in the price, the minutes are not in manufacturers package. Three month of xm and xm traffic in price too.
    6,293
    Quote Originally Posted by OptimizedDesignConcepts View Post
    Comments like "I got the 300 minute package for the same price as 100 minutes" makes me question the dealer's delivery process. How can you get "the 300 minute package for the same price" when it is just included in the MSRP of a Volt"
    Well, when you call to set up the account -- which you have to do so that they have a password and the right phone contact number and so forth -- the OnStar representative asks you if you want either the 100 or 300 minute package of phone minutes. This is the number of mobile minutes you can use when calling using the OnStar system. These minutes are AFAIK NOT included in the OnStar package that comes with the Volt. They are an extra.
    SoCal
    116
    For some reason, I thought I had received 100 free minutes with the delivery of my car, but I noticed a few weeks ago that the MyLink app on my iPhone was showing I had zero minutes. I called OnStar, the lady said that free minutes do not come with the Volt, so I gave her my CC and purchased 100 minutes.
    I am not sure if I will ever need it, since I always travel with my cell phone, but who knows....
    Ken
    # 1228
    5
    Default This is OnStar!
    Sorry to hear you're having problems with OnStar. Want to send me a private message with more info? I work on the PR team here at OnStar.
    Central Texas
    929
    Quote Originally Posted by kmg View Post
    Ken
    # 1228
    I wasn't offered any free minutes either. They did offer me 60 minutes for $4.99, which I took. I never use more than that in my other car. Would have been nice if they offered 100min free.
    #B2380, 2011 Crystal Red. Born 3/18/2011, adopted 4/9/2011
    #B2733, 2011 White Diamond. Born 4/4/2011, foster care 5/2/2011, adopted 11/29/2012
    - The FAQ -- answers to your Frequently Asked Questions about the Volt - Click Here! - maintained by ChrisC
    San Diego, CA. VIN B-95
    2,631
    I too was never offered any free minutes. Granted, back in December when I picked up my Volt, my dealer wasn't 100% up on the OnStar process... I've always been 0 minutes.
    Long Beach, CA
    164
    I was offered free minutes, AFTER I purchased 60 minutes. It was hard to tell if we would have gotten the free minutes if we hadn't purchased the additional minutes, but I certainly rolled my eyes after they tacked on the free minutes as I'll certainly never use all of them by the time they expire in December.
    2011 #130: 23,976 EV miles / 28,424 total miles (and counting)
  1. Onstar eNAV
    By MicroChip in forum Volt Ownership Forum
    Last Post: 03-26-2012, 09:12 PM
  2. Charge Cord Failure
    By Bill R. in forum Volt Ownership Forum
    Last Post: 08-30-2011, 04:16 PM
  3. Fukushima Failure Analysis
    By George S. Bower in forum Politics, Finance, and Environment
    Last Post: 03-28-2011, 07:27 PM
  4. OnStar Smartphone App
    By sgc in forum Engineering and Design
    Last Post: 10-17-2010, 11:39 PM
