Originally Posted by
Farmedb
I wanted to see if anyone else has observed the kwh not going down. When I go down a hill, I usually see the kwh number go down by one tenth, but no more. I tried heading up the mountain about 10 miles in mm. I turned around and switched to normal mode. The ev range showed 14 miles remaining as I went down the hill, never going up or down. Once I got back to the flats, the kwh eventually started going up, and the range started going down. I am tempted to try again going further up the hill.
I can consistently get 0.2kwh back when stopping from 55-0mph providing I have ample stopping distance, and no one behind me. In normal everyday driving I can at least get 0.1kwh put back even from speeds as low as 40-45mph. Again it just takes a good roll out to do so. It does put power back in the battery, but unfortunately once you have crossed that threshold in to CS mode it will not revert back to EV mode once you have depleted the charge. Even if you go down a huge mountain I do not think it would go back to EV mode until it is plugged in again, and all will be logged as CS miles.
2012 Nissan Leaf SL #16790
2012 Chevy Volt #2395
