Originally Posted by
Rusty
Got to the pharmacy with 2 EV miles indicated remaining today. When I started back up again it showed 0 miles and switched over to the gas tank gauge.
I then drove the 3/4 mile drive home at 25-35 MPH speeds and watched the power flow screen. The engine never turned on, it was EV all the way BUT...
Attachment 1664
the miles got recorded as being driven in CS mode (note the 0.00 gallons of gas). There's about a 70' overall drop from the store to my house, which helped. But still...
I believe this is by design. You were in CS mode, just not burning gas. Being in CS mode results in various changes to how the car thinks and is prepared to supply power, as we all know there are plenty of times in CS mode where we are regenning or the gas engine is otherwise not running. It correctly noted you did not burn gas, so your mileage numbers will not be effected but I am sure you were technically in "CS" mode.
I dream of a better world, where chickens can cross the road without having their motives questioned
