Playing music from android phone through volt audio system
Grab our Forum Feed
+ Reply to Thread
Results 1 to 7 of 7
Thread: Playing music from android phone through volt audio system
  1. #1
    Default Playing music from android phone through volt audio system
    Hi - I just switched from an iPhone to a Motorola Atrix with Android 2.2 (Froyo) and I am trying to figure out how to play music through the volt audio system (if it's even possible). I couldn't find documentation and nothing in a search of the threads so was wondering if anybody knew how or could point me in the right direction. I can plug the phone into the USB port and it charges fine but wasn't sure how to play music and, if you can, if you had to control the music through the phone or you could control it through the car radio like the iphone. Thanks in advance for any guidance.
  2. #2
    Join Date
    Dec 2010
    Location
    Houston, TX
    Posts
    1,481
    Default
    At a bare minimum, you can plug your phone into the 3.5mm aux port in the arm rest console.
    Even if you have an iphone, like I do, you still need that 3.5mm port for playing any audio that is not in your ipod app, so don't feel too bad if you can't find a better solution.
    Volt #947 Delivered on 2/25/11 -- Sold!
    240V Blink Installed 10/28/11 -- Returned!
  3. #3
    Join Date
    Dec 2010
    Location
    Fort Worth,TX #1258
    Posts
    384
    Default
    We have Android phones as well and will be getting new ones likely next month. Still sticking with Android of course, but would love if someone can figure out any way other than the 3.5mm port for access. It states hard drive hooked up when plugged in via USB, but can't do anything with it but charge. playing music comes out a data static sounds. Likely just can't read the format and we are stuck with 3.5mm port. Not a big deal given the harddrive in the Volt. Not going to run out of music, but wouldn't mind free internet radio vs. paying for XM. Wish they included HD Radio.
    Paul (Cari's husband)
    02/10/2011 - (4000) Vehicle available to ship.
    02/18/2011 - (4200) Shipped
    03/17/2011 - (5000) Vehicle has been delivered to dealer
    03/18/2011 - Picked up and drove 4 1/2 hours home...
    #1258 has now been adopted and has been placed in a safe/happy home!
    03/18/2012 - Happy Volt B-day! 12,000+ miles of pure joy!
  4.
    Advertisement
  5. #4
    Join Date
    Dec 2010
    Location
    La Verne, CA
    Posts
    215
    Default
    Quote Originally Posted by Cari View Post
    No support for the Android, in fact I can't even figure out how to play music on the Android from a PC via USB.
    I plugged in my new HTC Thunderbolt and the Volt screen came up "Can't Read Media" or something like that. I tried my both my Sony digital Walkman an and old Creative Zen via USB and the Volt could not read them. I transferred all of the music files from the Walkman to a USB flash drive stick and the Volt could see all of the directories, artist, album, and song information. It works great! I am now transferring from the USB stick to the Volt hard drive. Just select USB, touch “Record” on the center stack, then select “All Songs” from the screen menu.
    VIN 1220, Delivered 3/4/2011
  6. #5
    Default
    The simplest method is a 3.5mm stereo cable.
    The second option is to add a AD2P streaming. See http://gm-volt.com/forum/showthread....2197#post52197 . I have personally used this method, and it has worked well for streaming internet radio to my Volt. Unfortunately, It is only good for extended trips. It does take a minute or two to setup. Phone calls come through fine on the regular Volt BT system.
    The other suggestion is to try to connect the Android device as a USB mass storage device.
    If using pre-Froyo (2.2) then you just pull down the shade on the android device, and select "Turn on USB Storage"
    Then plug it into your computer and see if you MP3 files are visible. If they are, unmount the phone from your computer and the Volt should be able to see them when you plug in the USB connector. It may simply be that your phone is not acting like a mass storage device.
    In Froyo or newer phones - it is a little easier, A popup will ask you if you want to turn on Usb Storage.
    Not sure if it will help - but worth a try.
    Good luck.
  7. #6
    Join Date
    Dec 2010
    Location
    Houston, TX
    Posts
    1,481
    Default
    I wouldn't hold your breadth for playing free Internet radio through the USB on your Android.
    The Volt favors the iPhone/iPod, clearly, and you can't even do that with an iPhone/iPod.
    The sound is good out of the 3.5mm so I don't know why you are so bent out of shape using it.
  8. #7
    Join Date
    Dec 2010
    Location
    Fort Worth,TX #1258
    Posts
    384
    Default
    Quote Originally Posted by voltage692 View Post
    I am not bent out of shape??!!! Perhaps you were referring to some other post? I stated not a big deal and likely wasn't even going to try again or waste any more brain power on it. In fact, I usually don't even turn on bluetooth on my current phone because of battery life, so don't see streaming music as important unless it is just really easy to do. Any out of shape feeling I have would be over something like having to take the key out of my pocket to press a button to enter the car. Given the cheaper cars out there with push button that allow you to just keep the key in your pocket/purse, no reason for this not the be the case with the Volt. The 30gig harddrive is a nice feature and we are still loading cds on the drive every time we drive the Volt. Just past the 1k mile mark tonight.
Similar Threads
  1. android bluetooth
    By jilowite in forum Software/programming/code
    Last Post: 11-24-2012, 06:08 PM
  2. Volt HDD Music System Now Almost Usable... But not quite.
    By silyman1 in forum Software/programming/code
    Last Post: 07-17-2012, 03:51 PM
  3. Volt Music Playlist
    By gwmort in forum Off-Topic
    Last Post: 03-14-2011, 01:29 PM
  4. What is the Volt Advisor Phone Number?
    By adamsocb in forum Volt Ownership Forum
    Last Post: 01-07-2011, 04:13 PM
  5. iPhone/Android App pretty impressive!
    By travelguy2500 in forum Volt Ownership Forum
    Last Post: 12-18-2010, 06:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
