Interior Rear View Mirror Dimming Solution
Grab our Forum Feed
+ Reply to Thread
Results 1 to 6 of 6
Thread: Interior Rear View Mirror Dimming Solution
  1. #1
    Join Date
    Oct 2010
    Location
    North OC, CA
    Posts
    520
    Default Interior Rear View Mirror Dimming Solution
    The one annoyance when driving the Volt at night is if the center rear view mirror does not dim properly. Mine has operated about 10% of the time, but when the dome light shines on the mirror's sensor, it is operational and dims.
    After several weeks of frustration, I got the idea to turn the mirror upside down. This is done by moving it to a slight angle so you can turn it 180 degrees and then return it to the normal angle. Since there is an electrical wire inside, be sure to remember the direction you turn it so you can reverse the turn and avoid stressing the wire if returning it to the original position.
    Instead of the sensor at the top, it now is at the bottom. The angled sides of the mirror match the rear window better too. An amazing difference, now the mirror dims almost 100% of the time. Mine may have been manufactured with the sensor slightly off center in a vertical direction, so the light from the cars behind me is not hitting the sensor just right. I do plan on asking for a replacement, but I thought it best to mention the problem on the forum so others would know a possible temporary "fix" if their mirror had a similar problem.
    One other improvement may occur with the mirror upside down. The front sensor moves from the drivers side to the passenger side. The black box just to the right side of the mirror helps shield the front sensor from headlights or other night lighting that may decrease the dimming action.
  2. #2
    Join Date
    Oct 2010
    Location
    Chicagoland VIN:B-01234
    Posts
    3,506
  3. #3
    Join Date
    Sep 2009
    Posts
    134
    Default
    I noticed that my rear view mirror was very close to the top of the ceiling. I moved it down and have had no problems since. I think the sensor was being blocked.
  4.
    Advertisement
  5. #4
    Join Date
    Jul 2008
    Location
    Colorado Front Range
    Posts
    234
    Default
    We had to do this in our Prius years ago. In the Prius, the sensor was being blocked by the split rear window. Same in the volt?
  6. #5
    Join Date
    Nov 2010
    Posts
    8
    Default
    1963 Corvette has split rear window treatment lasted that model for year and 2011 Chevy Volt it makes rear visibility worse then Toyota Prius.
    _____________________
    ATV For Sale Used RVs
  7. #6
    Join Date
    Apr 2011
    Posts
    7
    Default
    Really great solution Mark. Rear view better, works better, looks better. It really should have been designed this way to begin with. I would suggest everyone try it.
Similar Threads
  1. Driver Side Mirror
    By jimcking in forum Volt Ownership Forum
    Last Post: 01-06-2013, 04:21 PM
  2. Rearview mirror dimming disable?
    By Rusty in forum Volt Ownership Forum
    Last Post: 09-28-2012, 07:27 PM
  3. Replies: 6
    Last Post: 01-04-2011, 11:44 AM
  4. Tower Automotive to Supply Stirling SunCatcher Mirror Facets
    By Jason M. Hendler in forum Politics, Finance, and Environment
    Last Post: 09-03-2009, 11:24 AM
  5. NatGeo TV Special on California's Newest and Largest Parabolic Mirror Solar
    By OPEC SUCKS in forum Politics, Finance, and Environment
    Last Post: 07-10-2009, 11:14 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
