The Electricity in Gasoline
Grab our Forum Feed
+ Reply to Thread
Results 1 to 8 of 8
Thread: The Electricity in Gasoline
  1. #1
    Join Date
    Mar 2010
    Location
    Central NY
    Posts
    1,440
    Default The Electricity in Gasoline
    http://plugsandcars.blogspot.com/201...-gasoline.html
    I thought this highlighted a pretty interesting statistic: US Refineries in 2007 used 49,000,000,000 kWh of electricity. Assuming 36 kWh per 100 miles (Volt EPA label), that is enough electricity to drive 11 MILLION Chevrolet Volt's 12,000 miles per year!
    Volt Emergency Power Wiring Kit - Provide backup power to essential appliances.
    Leaf Emergency Power Wiring Kit - Provide backup power to essential appliances.
    Commercial Level 1 Charging Station - Low cost solution suitable for Hotels, Employers, Airports, etc.
    Join thE REVolution
    2011 Volt #186, VIN: B-00186, Cyber Gray Metallic - TRADED! 28k miles, 9k engine, 120MPG
    2013 Volt #43404, Blue Topaz Metallic - Love the blue!
    [SIZE="2"]Driving for FREE with Solar PV!
  2. #2
    Join Date
    Jul 2010
    Location
    Bayamon, Puerto Rico
    Posts
    1,344
    Default
    That fact would be useful if someone could calculate how much electrical power is needed to refine one gallon of gasoline. Then throw that fact at the ICE supporters, and tell them that power may come from other sources, such as coal. So coal is needed to refine gasoline.
    EVs eliminate the middle conversion (gasoline to mechanical power) and just need coal to electricity , then convert electricity to mechanical power. This saves on the import of petroleum and waste less energy. By the time Mr. Fusion arrives on the market, we can convert coal (and any type of fuel) locally to electricity, and so on..
  3. #3
    Join Date
    Oct 2010
    Location
    Iowa
    Posts
    135
    Default
    According to this link
    http://gatewayev.org/how-much-electr...on-of-gasoline
    About 4 - 7.5 kWh per gallon of Gas.
    2.77 miles per kWh for an EV (based on 36kWh per 100mi) Refining a single gallon of gas could move an EV 11 miles (assuming 4 kWh and 19 miles assuming 7kWh). This does not take into account how much energy was used to:
    -Search for the Oil
    -Drill for the Oil
    -Transport the Oil
    -Transport the Gasoline
    -The engergy contained in the fuel itself.
    That adds a whole other aspect to the arguement of coal power vs. gasoline...
  4.
    Advertisement
  5. #4
    Join Date
    Sep 2008
    Location
    Wynantskill, NY
    Posts
    62
    Default
    The above figures also don't take into account the hundreds of billions of dollars it costs the taxpayer to secure access to oil supplies around the world...
  6. #5
    Join Date
    Feb 2011
    Posts
    142
    Default
    EPA says refining and distribution costs of oil -> petrol consumes 17% of the original energy.
    I've misplaced the link, but the number can be found by googling how CAFE is calculated.
    Addendum: Here it is, courtesy of SAE.
  7. #6
    Join Date
    Sep 2008
    Posts
    990
    Default
    I wonder how much electricity is in electricity?
  8. #7
    Join Date
    Sep 2008
    Location
    Wynantskill, NY
    Posts
    62
    Default
    >>I wonder how much electricity is in electricity? <<
    I think I read somewhere it's about 1000 watts per 1 kilo watt. Does that sound about right?
  9. #8
    Default
    ...and how much gasoline there is in electricity. Diesel to power the train that moves the coal to the power plant, etc...
    #469
    Personal best: 72.9 miles (One charge only, no Mountain Mode, no gas, no significant elevation change.)
Similar Threads
  1. What do you pay for electricity?
    By honoreitiscom in forum Volt Ownership Forum
    Last Post: 11-22-2010, 07:34 PM
  2. European electricity
    By tonan666 in forum Newcomers
    Last Post: 11-11-2010, 10:38 PM
  3. Air To Generate Electricity
    By NGV in forum Suggestions for GM
    Last Post: 07-01-2009, 01:43 AM
  4. Supply vs. Demand as Gasoline vs. Electricity
    By fredevad in forum General Motors and General Automotive Topics
    Last Post: 02-09-2009, 11:45 PM
  5. Replies: 0
    Last Post: 06-12-2008, 10:29 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
