Resetting the TPMS after tire rotation
Grab our Forum Feed
+ Reply to Thread
Page 2 of 4 FirstFirst 1 2 4 LastLast
Results 11 to 20 of 36
Thread: Resetting the TPMS after tire rotation
  1. #11
    Join Date
    Nov 2010
    Location
    Austin, TX
    Posts
    126
    Default
    To reset one, you have to reset all. And if the reset all procedure fails, the Volt won't get any tire pressure data until you start and complete the reset all procedure.
    -doubledave - Volt owner since Jan 2011 - 2011 Volt # 0724
  2. #12
    Join Date
    Jul 2010
    Location
    Dallastown, PA
    Posts
    167
    Default
    I had my tires rotated at 7500 miles by my dealer on 10/6/11. Shortly thereafter I received a low air pressure alert on the right front tire. When I added air it turned out that it was the right rear tire that was low, i.e. the dealer did not relearn the TPMS after rotating the tires. No problem once I realized this. I've been monitoring a slow leak (2-4 lbs./week) in that tire ever since. Today I finally got the tire repaired. It had a 3/4" #10 screw imbedded below the surface of the tread, which had to be unscrewed to remove. Then plugged the tire.
    Anyway, I had tried the TPMS relearn proceedure with magnets, instead of the relearn tool, with no success. Guess my magnets weren't strong enough. But today I successfully completed the TPMS relearn proceedure by bleeding air from the tires, instead of using the relearn tool.
    ChuckR - VIN: BU100233 - 12/17/10 delivery
  3. #13
    Join Date
    Jul 2010
    Location
    Chicagoland
    Posts
    751
    Default
    Quote Originally Posted by ChuckR View Post
    Do you think the magnets from a hard drive would be strong enough - they're small, but as i believe they're rare earth magnets they seem quite strong?
    Ron C. / Chicago-area
    2012 Crystal Red Tintcoat Volt C8794, acquired 11/08/2011
  4.
    Advertisement
  5. #14
    Join Date
    Jul 2010
    Location
    Dallastown, PA
    Posts
    167
    Default
    Quote Originally Posted by Ron C View Post
    Don't have any experience in how strong the magnets have to be to work, but apparently the parts tray magnet referred to in the link in post #2 worked.
  6. #15
    Join Date
    May 2011
    Posts
    3
    Default
    I tried resetting the TMPS last night with a rare-earth magnet from an old hard drive, and couldn't get it to work. I tried moving the magnet to the sidewall, on the side of the rim, and around the valve stem, but never got the horn chirp.
    I was able to reset the TPMS by letting air out though. Do remember to push the button again after selecting "yes" to start the learning procedure. Then let air out for about 5 seconds and then stop, and you should get a confirming horn beep (although I recall there being some delay - wait for it). Subsequent pushes on the button after each tire didn't seem necessary - for the first tire I pressed the button again before moving on, but for all the others, the horn chirped and I moved on to the next tire without pressing the button.
    After I got through all tires, I didn't go back and experiment to verify I knew exactly what to do, as it was getting late and I didn't want to bug my neighbor with lots of honks. So what I have above is what I recollect. If the reader finds something different, and has the time to keep trying to verify the exact sequence, please post.
    Also, on my Volt the turn signals do NOT indicate which tire to do next. So it was important to know the sequence of driver front, passenger front, passenger rear, driver rear.
  7. #16
    Join Date
    Sep 2011
    Location
    Dallas Texas
    Posts
    1,276
    Default
    If our sensors use a centrifugal or centripetal device a magnet might trigger it . Was told it works on some tires.
    Sorry in advance I always get centrifugal and centripetal forces wrong.
    2012 RED Volt VIN:#C-8860 - Premium Leather Seats Jet Black with Dark Trim, Rear Camera & Park Assist, Nav
    09/29/2011 Ordered -- 11/15/2011 took it home
  8. #17
    Join Date
    Sep 2011
    Location
    Los Angeles, CA
    Posts
    1,973
    Default
    So basically the TPMS tool is just a strong horseshoe magnet that GM sells for $79??? I have magnets. Guess I gotta try a magnet.
    I wonder if this would work???
    http://www.amazon.com/Master-Magneti...rseshoe+magnet
  9. #18
    Join Date
    Aug 2011
    Location
    North East Ohio
    Posts
    203
    Default
    I tried letting out the air on my 2012, and this method would not work for me. The turn signal indicators did light up to tell which tire to work on. I have purchased the tool and it did work for me. I have read that only the 2011 cars can use the remote air procedure.
    Silver Ice #C4722 Oct 1, 2012
  10. #19
    Join Date
    Sep 2011
    Location
    Los Angeles, CA
    Posts
    1,973
    Default
    Quote Originally Posted by DQL View Post
    It may need to see a differential on the magnetic poles. (Not just a single field.) It may need to be a horseshoe magnet.
  11.
    Advertisement
  12. #20
    Join Date
    Sep 2011
    Location
    Dallas Texas
    Posts
    1,276
    Default
Similar Threads
  1. Spare Tire
    By foypat in forum Engineering and Design
    Last Post: 11-10-2011, 06:01 PM
  2. Replies: 7
    Last Post: 06-03-2011, 02:45 PM
  3. Tire pressure?
    By Rusty in forum Volt Ownership Forum
    Last Post: 02-03-2011, 02:15 AM
  4. Spare tire??
    By maynard in forum Volt Ownership Forum
    Last Post: 12-07-2010, 09:57 AM
  5. tire pressure
    By goyogi in forum VOLT Consumer Advisory Board Discussion Forum
    Last Post: 11-17-2010, 12:38 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
