Loss of propulsion system
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
Thread: Loss of propulsion system
  1. #1
    Join Date
    Jul 2011
    Posts
    132
    Default Propulsion system died while driving
    Yesterday while driving on a very windy back road that had a speed limit of 35mph my Volt died. There was a fairly loud band that seemed to come from under the shift lever. I think that is when the propulsion system shut down. I managed to coast two thirds of the way off the road, put the car in park and tried a restart. It did start with the check engine light on. OnStar told me I had a error code that said there was a problem with my propulsion system, and I should take the car into the dealer within seven days.
    My question is this, if I was traveling at 70 mph and the propulsion system quit could I shift into neutral and restart the car?
  2. #2
    Join Date
    May 2011
    Location
    Delaware
    Posts
    7,876
    Default
    I don't know enough about your failure to know if it'd work.
    In general, yes. If you turn the car off while driving (double press on the power button,) you can switch to neutral and restart the car while it's still moving.
    Whether that would restore operation would depends on what caused the car to stop in the first place...
    Walter
    2016 Tesla X75D delivered 8/25/16
    Hidden Content
  3. #3
    Join Date
    Aug 2012
    Location
    Seminole, Fl.
    Posts
    216
    Default
    Actually, Probably Not. Most of the systems need to see a cycle into and out of Park by the "shift" lever to reset. Good luck trying that without coming to a stop first..
    And as an aside - my 2013 will Not restart and continue onward without going in/out of park if I "kill" it by hitting the power button twice while driving. I've tried it, just to see what happens and to be ready if I should do it by mistake. You can wake the Displays back up without the park sequence, but it won't "go"..
    2015, Brownstone/Pebble/Premium, purchase 6/15/2015
    2013 #01800, Silver, purchase on 8/3/2012
    As an Engineer - what's not to like?
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Jun 2013
    Location
    Nashville TN
    Posts
    231
    Default
    After reading the discussion about accidently turni8ng it off, I did some testing (MY 2013) on a wide open local road. It actually took me a couple tries to successfully turn it off with the double hit. (You have to pause long enough between the hits.) The first time I turned it off, it took me two tries to turn it back on. The second time I was able to restart on the first try. Neither time required a full stop and 'Park'.
    Of course, in the circumstances of the OP, the 'Park' cycle may be required to deal with the event that caused the error.
    2013 Volt Crystal Red / Pebble Beige, Premium trim, Polished wheels, Nav/Bose, ESP 1/2 (Replaced '08 TCH) Hidden Content
    2012 Suburban K1500 LTZ (Replaced '95 Suburban C1500)
  7. #5
    Join Date
    Jul 2011
    Posts
    132
    Default Loss of propulsion system
    We were driving on a very windy back road that has a speed limit of 35 mph. I heard a loud clump that seemed to come from below the shift lever. I think that was caused by the complete loss of power. I was able to cost partially off the road, put the car in park and tried to restart it. It did start with the check engine light on. I called OnStar they ran diagnostics and said I had a propulsion system problem and should take it to the dealer within the next 7 days.
    My question is if this happened at 70 mph could you shift into neutral and restart the Volt?
  8. #6
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    15,117
    Default
    Quote Originally Posted by Rons2013 View Post
    Maybe you aren't doing it correctly, Rons2013?
    2013 Owners Manual, 9-18
    Restarting Procedure
    If the vehicle must be restarted
    while it is still moving, move the shift
    lever to N (Neutral) and press the
    POWER O button twice without
    pressing the brake pedal. The
    propulsion system will not restart in
    any other position.
    B3320
    Best All Electric Miles: 54.2
    Lifetime: 84,576 miles, 135 MPG, Remaining Oil Life 74%
    Typical Commute: 60 miles
    30 day Stats: 1366 miles, 125
    MPG, 65% Electric, 33% gas, Saved 48 gal., 27 kW-hr/100 miles
  9. #7
    Join Date
    Nov 2011
    Location
    Montreal
    Posts
    1,094
    Default
    What is the DTC code number?
    Would you call back OnStar so they can run a remote diagnostic and provide you
    with the error codes?
    Does your Volt run normally, now, or the problem and troublecode is still present?
    Francois
    B2653
  10. #8
    Join Date
    Jul 2011
    Posts
    132
    Default
    The check engine light is no longer on. The car has performed normally since the incident. I will take it in Tuesday, and will update the forum when I get it back.
  11. #9
    Join Date
    Sep 2011
    Location
    Dallas Texas
    Posts
    2,811
    Default
    make a small label and put it by the onstar call button.
    "ASK for the ERROR CODE"
    or as my Aggie roommate said way too many times.
    "I can't help you with out a soil sample" :-)
    some question to the forum may require the year of the Volt to answer.
    do try a volt re-start in a save area- First time I did a test at NIGHT I had to manual turn back on the headlights.
    2012 RED Volt VIN:#C-8860 - Premium Leather Seats Jet Black with Dark Trim, Rear Camera & Park Assist, Nav
    09/29/2011 Ordered -- 11/15/2011 took it home
  12. Advertisement
  13. #10
    Join Date
    Aug 2012
    Location
    Seminole, Fl.
    Posts
    216
    Default
    any other position.
    Well, RTFM would apply, right. Actually I was Probably trying to make it restart by pressing the power button Once, not Twice. Guess I need to experiment with this again and figure it out. Might be handy to know, someday..
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Problem with e-propulsion system and battery charger control
    By pavers123 in forum Generation 1 Volt (2011-2015)
    Last Post: 02-10-2016, 11:14 AM
  2. Weird Thing with the battery/charge/propulsion system
    By Sam56n in forum Li-Ion Battery, Charging, & Battery Managment System - Chevy Volt
    Last Post: 10-25-2012, 11:46 AM
  3. Voltec Propulsion System Named 2012 Best New Technology
    By WopOnTour in forum Chevy Volt General Discussion, News, and Events
    Last Post: 02-17-2012, 04:35 PM
  4. Volt Propulsion System Named a 'Ward's 10 Best Engine'
    By scottf200 in forum Chevy Volt General Discussion, News, and Events
    Last Post: 12-07-2010, 02:18 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
