VOLT Pickup
Grab our Forum Feed
+ Reply to Thread
Results 1 to 6 of 6
Thread: VOLT Pickup
  1. #1
    Join Date
    Dec 2010
    Location
    Ortonville, MI
    Posts
    27
    Default VOLT Pickup
    I would really like a small pickup 4X4 version of the VOLT.
    Thanks
    Joe
    VOLT# 1398
  2. #2
    Join Date
    Jul 2010
    Location
    Bayamon, Puerto Rico
    Posts
    4,335
    Default
    I know that GM may have done a prototype somewhere, probably using the Chevy Colorado as a test mule. Now it is anyone's guess what would be its name, foe example: a "Chevy Watt"? Maybe a Chevy Conductor?
    Join Date
    Dec 2010
    Location
    Ortonville, MI
    Posts
    27
    Default VOLT Pickup
    Quote Originally Posted by Raymondjram View Post
    A Colorado based VOLT would work really good. It has a full frame and can carry a larger battery pack. Many have converted S-10's and they do very well. In fact GM built some S-10's using the same technology in the EV1. You can find them for sale every now and then.
    Thanks
    Joe
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Red face
    Quote Originally Posted by joeboston View Post
    Thanks
    Joe
    VOLT# 1398
    It's good to want things.
    A lot of people on the blog have expressed this desire. The consensus seems to be that GM will wait until the larger batteries required to produce this much power get cheaper. Also, any true truck will need to be capable of towing. It seems likely that such a vehicle will operate with a much weaker serial mode than the Volt, and have a much larger engine. Also, either the front or rear set of wheels will probably lack a direct connection to the engine; requiring new engineering (adding a front-to-rear shaft will raise the floor; a definite no-no for a vehicle which needs good aerodynamics: another consideration working against the traditional pickup shape, of any size).
    Bottom line: It is probably too expensive for GM to build now; when it does appear, it will be much more expensive than a Volt of the same era.
  7. #5
    Default
    In days gone by I had suggested the Volterado... ;-)
  8. #6
    Default
    Where's the AMP?
    After several articles then nothing.
    The AMP would be the Voltec I want. CUV with rear seats that come out. Heavy duty suspenstion to deal with rough roads around here.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
