Need to turn on the genset for a state car inspection.
Grab our Forum Feed
+ Reply to Thread
Page 1 of 3 1 3 LastLast
Results 1 to 10 of 22
Thread: Need to turn on the genset for a state car inspection.
  1. #1
    Join Date
    Mar 2008
    Location
    Arlington, Virginia
    Posts
    1,781
    Default Need to turn on the genset for a state car inspection.
    How do I minimize the gas use?
    The inspector needs the engine turning over so they can check the exhaust, or so I believe. Tried to contact the DMV, they told me via a message that they are busy and I should call back another day. :-(
    Would it be easiest to let the battery go down to 8 miles of AER and then hit mountain mode? So I would only have 3 or 4 minutes of gas use, instead of running the battery all the way down and actually driving there on the genset?
  2. #2
    Join Date
    Oct 2010
    Location
    So. Texas
    Posts
    1,265
    Default
    With the car powered on and in Park, open the hood.
    Doug
    2013 CMax Energi Red (His)
    2015 Subaru Outback w/EyeSight (hers)
    2012 Jet Black Volt (sold)
  3. #3
    Join Date
    Mar 2012
    Location
    Southern Illinois
    Posts
    5,602
    Default
    Quote Originally Posted by fotomoto View Post
    And I would try and run the ICE prior to the inspection to get it up to operating temps. That's important for the cats.
    Tom
    Tom aka Accidental Electronaut
    USAF Retired
    My garage
    2017 GMC Acadia Denali
    2017 Volt Premier
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Mar 2010
    Location
    Central NY
    Posts
    4,330
    Default
    It's my understanding that the car should have emissions data within it from the last time you ran the engine that they can read.
    As others have pointed out, opening the hood while the car is on will force an engine start.
    Hidden Content - Provide backup power to essential appliances.
    Hidden Content - Keep yourself from getting unplugged!
    Join thE REVolution
    2011 Volt #186, VIN: B-00186, Cyber Gray Metallic - TRADED! 28k miles, 9k engine, 120MPG
    2013 Volt #43404, Blue Topaz Metallic
    Driving for FREE with Solar PV!
  7. #5
    Join Date
    Mar 2008
    Location
    Fort Worth, TX
    Posts
    1,790
    Default
    yeah, this makes no sense. I'm not sure about Virginia, but here in Texas we only do emissions testing if the vehicle is older than 1996 (pre OBD-II) because any car 1996 or newer essentially tests itself and keeps that data stored in the computer. So usually the emissions test is done just by plugging into the OBD-II port. This should be no different with the Volt.
    2014 BMW i3 REx (White)
    2017 Chevy Volt (Iridescent Pearl)
  8. #6
    Join Date
    Aug 2012
    Location
    US
    Posts
    562
    Default
    Quote Originally Posted by Ziv View Post
    Time isn't the only factor... mountain mode runs the engine pretty hard, and will consume gas at a higher rate than typical driving.
    Do you have enough gas miles to actually pass the inspection? Apparently, if the car's systems don't have enough data from when the engine was running, it can fail the inspection. Gas-only cars too, if the battery was disconnected/replaced shortly before the inspection, without enough running time. If not, you might need to go driving around for a bit and have the inspection done again.
  9. #7
    Join Date
    Jul 2008
    Location
    San Diego
    Posts
    12,294
    Default
    Good memory! I do recollect a problem of not having run the engine enough to have the data. I think that was in MA. Can't remember the resolution.
    I'd try and call the DMV again and see if the test is necessary. Even CA doesn't require the Volt to have an emissions test.
  10. #8
    Join Date
    Oct 2010
    Location
    So. Texas
    Posts
    1,265
    Default
    The OP said nothing about emissions. He said the inspector need to check the exhaust which could mean: "This thing got a muffler? Well then I need to hear it."
    Case in point: in Texas, a motorcycle isn't required to have turn signals but if they are on the bike then they have to work.
    Doug
  11. #9
    Join Date
    Sep 2011
    Location
    Los Angeles, CA
    Posts
    5,187
    Default
    OPEN THE HOOD. THE ENGINE WILL START.
  12. Advertisement
  13. #10
    Join Date
    Mar 2008
    Location
    Arlington, Virginia
    Posts
    1,781
    Default
    I completely forgot about the open the hood idea, so that is a good point.
    I have 100+ miles on the genset, almost half of which were on the car when I got it. Criswell kept the car with around 5 miles of battery miles so that every potential buyer would be able to feel the transition to using the gas genset. They had me drive 5 miles until the battery emptied and then drive back on the genset.
    Anyway, I will keep trying to talk to someone at the DMV, or I will drive by the place I use to get my cars inspected, hopefully they will tell me there is not emissions inspection for a new Volt.
    I really don't want to use any more gas unless I have to.
    On edit: I just realized that I cannot remember if the last place I saw them put the tube in the exhaust was when I lived in Maryland, so I really need to get in touch with the DMV, I may be worrying about a test that isn't even done here in Virginia. But thanks for the reminders about the 'open the hood' trick.
    But the Virginia DMV does have a list of cars that are exempt from the emissions test...
    _ Vehicles exclusively powered by clean fuel, including compressed or liquified natural gas, electricity, or solar energy _
    Not what I had hoped for.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Volt "Rejected" for Emissions on MA State Inspection
    By bronco7TX in forum Generation 1 Volt (2011-2015)
    Last Post: 04-19-2016, 10:32 AM
  2. Failed MA State Inspection
    By FrankIII in forum Generation 1 Volt (2011-2015)
    Last Post: 09-06-2013, 07:14 AM
  3. Michigan State of State Address, guess what the only car mentioned was...
    By kubel in forum Chevy Volt General Discussion, News, and Events
    Last Post: 02-04-2009, 03:58 AM
  4. Human powered genset and 60 mph car?
    By JoeReal in forum Hybrid and Electric Vehicle Competitors
    Last Post: 10-14-2008, 03:42 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
