Problem with Versicharge
Grab our Forum Feed
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: Problem with Versicharge
  1. #1
    Join Date
    Jun 2013
    Location
    Madison, WI
    Posts
    95
    Default Problem with Versicharge
    Hi Siemens,
    Sorry to say, I'm having some trouble with my Versicharge and with technical support. I'm hoping that you can help. What happens is that about once a week (twice this week), when my Volt starts charging, the charger will have a fault (red light) and my Volt starts honking. To resolve the issue I go out to the garage and press the pause button twice, then it works fine, every time.
    I use the schedule charging on my Volt. I originally had it set to start charging at 9pm. I decided to try 10pm instead to see if it was a load related issue, but that hasn't changed anything. It just happened again tonight. I was sitting in my living room and my Volt started honking in the garage at 10pm sharp. I went out, pushed pause twice, and now it's charging happily. When this happened the only things using electricity in my house were my lights (mostly LED) and one ceiling fan. No appliances were running at the time.
    On a side note, when I called for support, I was given the number of a man who was apparently the only person in America who can support the Versicharge chargers. He was very nice, but said that he would talk to his engineer about it that day, but I haven't heard back in three weeks, despite giving him a call back and sending an email. You might need to hire some additional support if he is that backed up.
    Please help me resolve this problem.
    Thanks!
    John Hansen
  2. #2
    Join Date
    Aug 2009
    Location
    Texas - DFW
    Posts
    4,433
    Default
    If it goes off every day at 10 and you have to go out there anyway, why not just do an immediate charge at 10?
    Also, you can turn off that annoying honking in the Volt's settings.
    Driving a show car. Every day! Hidden Content
    2014 Crystal Red ELR (REDD) code R w/Cashmere interior
    L2 - GE WattStation
    iOS 10.3 on iPhone 6. MyCadillac App version 3.5.0
    Hidden Content
    Hidden Content
  3. #3
    Join Date
    Jun 2013
    Location
    Madison, WI
    Posts
    95
    Default
    Quote Originally Posted by Loboc View Post
    Hi Loboc, it doesn't do it every night, just once a week (or so). As annoying as the honking is, I prefer that over my car not getting charged. It doesn't start charging by itself after it happens.
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    15,280
    Default
    4.3 Faults
    The VersiCharge will automatically disconnect power in the event of a fault.
    • If a fault occurs during charging, the VersiCharge will disconnect power from the vehicle, with an audible click, and change to the ‘Fault’ state. The VersiCharge will automatically self-recover when all faults clear, with the exception of grounding faults.
    • For grounding faults, after 15 minutes, the VersiCharge will attempt to continue charging, and if no faults are present, will return to the ‘Charging’ state. During this 15 minute delay, the ‘2 Hour Delay’ indicator is illuminated.
    • If a fault is still present immediately after the VersiCharge re-enters the ‘Charging’ state, the VersiCharge will return to the ‘Fault’ state, and remain in that state until it is manually reset.
    Rather than manually resetting the unit, I'd wait to see if the unit recovers as described in the owners manual above.
    B3320
    Best All Electric Miles: 54.2
    Lifetime: 85,558 miles, 125 MPG, Remaining Oil Life 38%
    Typical Commute: 60 miles
    30 day Stats: 966 miles, 108
    MPG, 62% Electric, 38% gas, Saved 33 gal., 31 kW-hr/100 miles
  7. #5
    Join Date
    Jun 2013
    Location
    Madison, WI
    Posts
    95
    Default
    Quote Originally Posted by Steverino View Post
    4.3 Faults
    Thanks for the suggestion Steve. I'll give that a shot and see what happens.
  8. #6
    Join Date
    Jan 2013
    Location
    Norcross, GA
    Posts
    23
    Default
    John you should have been contacted directly. If not or if there is anything more I can do to help, please let me know.
    For a free whitepaper on selecting a Level 2 EVSE, please visit Hidden Content
    For support related to Siemens products, please call 1-800-241-4453
  9. #7
    Join Date
    Nov 2013
    Location
    CA
    Posts
    1
    Default
    Hi John,
    I was wondering if the problem with your VersiCharge was resolved and what the solution was?
    I started having the same issue with my Volt and VersiCharge about 2 weeks ago. I contacted Siemens support earlier this week via email at versicharge.industry@siemens.com (apparently they don't do phone support for VersiCharge) but haven't had a response.
    Thanks!
  10. #8
    Join Date
    Jun 2013
    Location
    Madison, WI
    Posts
    95
    Default
    Hi IAm, my problem was resolved when Siemens offered a full refund, no questions asked. I believe they even paid for the return shipping. It was a nice unit, but I think Siemens is pulling out of the market. I replaced it with a Clipper Creek LCS-25 and haven't had a problem since. Good luck with yours. It took Siemens a while to get back to me, but once they did they settled it quickly.
  11. #9
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    15,280
    Default
    Quote Originally Posted by hansenjw View Post
    Thanks for the update, glad you got it worked out. Mine is going strong and will be hitting 1 year in a few months. No issues.
    I see Siemens ads here every day. What do you base your "pulling out" claim on?
    B3320
  12. Advertisement
  13. #10
    Join Date
    Jun 2013
    Location
    Madison, WI
    Posts
    95
    Default
    This: http://insideevs.com/siemens-exits-t...o-weak-demand/
    Did I read that wrong? It didn't specifically say residential evses, but I assumed they were included.
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Question for Siemens VersiCharge users
    By LarryM in forum Li-Ion Battery, Charging, & Battery Managment System - Chevy Volt
    Last Post: 08-13-2013, 02:36 PM
  2. My Siemens VersiCharge Video Review on Amazon
    By Joekc in forum Generation 1 Volt (2011-2015)
    Last Post: 03-08-2013, 02:05 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
