Climate control problems
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: Climate control problems
  1. #1
    Join Date
    Nov 2010
    Location
    La Mirada, CA
    Posts
    78
    Smile Climate control problems
    I have two climate problems I can not find how to set:
    1. How do you save your settings. They always revert the next time I start.
    2. How do you change the degrees indicated in the temperature setting display?
    Les
  2. #2
    Join Date
    Sep 2010
    Location
    NY
    Posts
    30
    Default
    For #2 - to adjust the temp all you need to do is hit the red and blue arrows in the upper left - top row - of the console (just below the display).
    As far as #1 goes... not sure about that. Are there particular settings that reset - like just the temp, or does everything reset?
  3. #3
    Default
    1 is not correct.
    The setting stay as they are. I have placed the fan speed on auto , the temp to 73, and the vents to facing the driver/passenger.
    They have not reset in the two weeks since I last touched those settings. The only times they reset, is when I accidentally touched the auto button.
  4.
    Advertisement
  5. #4
    Join Date
    Nov 2010
    Location
    La Mirada, CA
    Posts
    78
    Default
    Thanks BxHBxH,
    I forgot about the red blue buttons.
    On 1. I guess I will try being careful and recheck it again. It tends to always come up auto.
    Lest
  6. #5
    Join Date
    Sep 2010
    Location
    San Diego, CA. VIN B-95
    Posts
    2,631
    Default
    Quote Originally Posted by Lest View Post
    It's really Really *REALLY* easy to accidentally touch the auto button, often without realizing you've done it. When I first got my car I did it ALL the time, and it really ticked me off. With practice I've gotten better at keeping accidental spare fingers away from it. But I still mess it up occasionally.
    I wish they'd put something more benign in that button spot, or made that particular button less sensitive.
  7. #6
    Join Date
    Nov 2010
    Location
    La Mirada, CA
    Posts
    78
    Default
    Thanks rtmey2000 & Rusty, I guess it is me. I will pay special attention now.
    Lest
  8. #7
    Join Date
    Nov 2010
    Location
    La Mirada, CA
    Posts
    78
    Default
    r
    Rusty & rtmey2000,
    I am still having problem with the Climate selections:
    I set it like this: photo
    Then when I turn off . Then start and look and is like this: Photo2 It adds auto which I do not think I want.
  9. #8
    Join Date
    Sep 2010
    Location
    Posts
    2,631
    Default
    Oh yeah, that. That's a personalization menu choice. Press Config -> Vehicle -> Climate and Air Quality -> Auto Heated Seats
    You should be able to set them to off. This is from page 5-54 to 5-55 (or there abouts) in the owners manual.
  10. #9
    Join Date
    Nov 2010
    Location
    La Mirada, CA
    Posts
    78
    Default
    thanks Rusty, I'll try that.
    Lest
  11.
    Advertisement
  12. #10
    Join Date
    Sep 2008
    Posts
    2,493
    Default
    FYI
    There is now an update available for issues relating to the climate control system (VINS prior to BU100954)
    Your complaint isnt specifically called out by the update though, but it recommends it be updated for "heated seat and/or blower operational issues"
    I would still suggest you visit your dealer outlining your concern and they will very likely install the new software which could very likely remedy your concern as well.
    GL
    WOT
Similar Threads
  1. Voltec 240V EVSE Problems
    By ?'smyvolt in forum Volt Ownership Forum
    Last Post: 10-24-2012, 10:09 PM
  2. Day 2 Climate control issue. FOUND A FIX
    By bjhorton2005 in forum Volt Ownership Forum
    Last Post: 02-01-2011, 12:29 PM
  3. Can't get climate control to produce hot air
    By tjc79 in forum Volt Ownership Forum
    Last Post: 01-16-2011, 11:02 PM
  4. Climate Control Granularity
    By ClarksonCote in forum Suggestions for GM
    Last Post: 01-04-2011, 02:48 PM
  5. Climate Control: Eco vs Comfort
    By MicroChip in forum Volt Ownership Forum
    Last Post: 12-23-2010, 12:06 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
