ICE Starting when preconditioning in extremely cold weather
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: ICE Starting when preconditioning in extremely cold weather
  1. #1
    Join Date
    Nov 2010
    Location
    Dearborn, MI
    Posts
    97
    Default ICE Starting when preconditioning in extremely cold weather
    This is the second day in a row where I've preconditioned and found the engine to be running once I opened my garage. This is with a full charge and the charger still plugged into the wall. There MUST be a temp threshold that allows this to occur. For reference, it was about 10 degrees yesterday and is 1 degree this morning.
  2. #2
    Join Date
    Oct 2010
    Location
    Columbus, Ohio
    Posts
    29
    Default
    Having the engine run in a closed environment is extremely dangerous and can cause carbon monoxide to leak into your house. that just doesn't seem right. Does the owner's manual talk about this?
  3. #3
    Join Date
    Nov 2010
    Location
    Dearborn, MI
    Posts
    97
    Default
    I know, hence my concern. Though, I have a detatched garage that no one enters but myself. That said, If the only way to precondition when that cold is by having the ICE start, I'd like to see an option that would automatically cancel the remote start request rather than have the engine run to prevent Carbon Monoxide issues like this.
  4.
    Advertisement
  5. #4
    Join Date
    Nov 2010
    Location
    Tewksbury, MA
    Posts
    539
    Default
    The owner manual does warn of this. Were you charging on 120V?
    P
  6. #5
    Join Date
    Mar 2010
    Location
    Central NY
    Posts
    1,440
    Default
    This has been discussed a bit in some other threads. When the Volt sees a temperature at or below 26F, the ICE will start. It doesn't matter if the Volt is already being driven, or being remote started.
    It must be that your garage was less than this temperature during these occurrances.
    The good news is it will only run for a few minutes (3?) out of the ten minutes of the remote start cycle.
    Volt Emergency Power Wiring Kit - Provide backup power to essential appliances.
    Leaf Emergency Power Wiring Kit - Provide backup power to essential appliances.
    Commercial Level 1 Charging Station - Low cost solution suitable for Hotels, Employers, Airports, etc.
    Join thE REVolution
    2011 Volt #186, VIN: B-00186, Cyber Gray Metallic - TRADED! 28k miles, 9k engine, 120MPG
    2013 Volt #43404, Blue Topaz Metallic - Love the blue!
    [SIZE="2"]Driving for FREE with Solar PV!
  7. #6
    Join Date
    Nov 2010
    Posts
    309
    Default
    Quote Originally Posted by muv666 View Post
    Yes it does.
    Stilgar
  8. #7
    Join Date
    Jan 2011
    Location
    Rancho Palos Verdes, CA
    Posts
    2,118
    Default
    I read some place several years ago that modern cars, especially those rated PZEV, generate so little carbon monoxide that you can no longer commit suicide by running your car in a closed garage. So from that standpoint it's probably not dangerous. Pretty irritating though, I would imagine.
  9. #8
    Join Date
    Jul 2008
    Location
    Colorado Front Range
    Posts
    234
    Default
    This is really concerning. Why can't the system just warm the battery with wall power?
    Does this happen on 240 as well? Or only on 120?
    Nate
  10. #9
    Join Date
    Mar 2010
    Location
    Central NY
    Posts
    1,440
    Default
    Quote Originally Posted by nater View Post
    Nate
    The amount of electricity required to heat the battery coolant up exceed that available from either 120V or 240V outlets. If I recall correctly, the engine is capable of producing over 50kW of power... The outlets produce less than 10kW
    Join thE REVolution
  11.
    Advertisement
  12. #10
    Join Date
    Jul 2008
    Location
    San Diego
    Posts
    6,259
    Default
    Quote Originally Posted by Noel Park View Post
    Probably just me but if I asked the car to start I wouldn't be shocked if the engine started.
    Completely OT here but do you know when you take delivery of your "hairy-chick magnet"? We're stoked for you.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
