Mountain Mode to save battery State of Charge
Grab our Forum Feed
+ Reply to Thread
Page 3 of 4 FirstFirst 1 3 4 LastLast
Results 21 to 30 of 36
Thread: Mountain Mode to save battery State of Charge
  1. #21
    Join Date
    Sep 2008
    Location
    Sierra Foothills, Northern CA
    Posts
    315
    Default
    My goal is to arrive at home in CS mode to extract all the charge from the battery and minimize gas usage. Since the last 23 miles to my home is a 2250 ft elevation climb I can do that on most trips out.
    VIN 483 Took Delivery 01/12/11
    (Xzlon = Lives in the forest)
  2. #22
    Join Date
    Feb 2011
    Location
    San Francisco Bay Area
    Posts
    136
    Default
    I used MM as a sort of Hold Mode surrogate, as discussed here, on a recent long unrecharged trip. For the low-speed driving in the middle of the trip (an out-and-back) was in Normal Mode, drawing on the reserved battery charge maintained in MM. Once back on the freeway, I switched back to MM until just within EV range of home (based on a quick switch from MM to NM to check the NM battery range).
    Worked great.
    What I don't know is whether this actually does save gasoline. It seems logical that (and according to the laws of thermodynamics), even with good use of regenerative braking, stopping and then accelerating back to speed (even if that's 30 mph) is less efficient than just maintaining that steady 30 mph. Tony, my GM Volt Advisor, called to introduce himself this evening; I posed this question to him, and he said he'd bring it up with the Volt engineering team.
    - Alan
    2011 Volt, #1238, "Pavia"
  3. #23
    Join Date
    Oct 2009
    Location
    Pine, Arizona
    Posts
    1,936
    Default
    Mountain Mode would be perfect in the following situation. Let's say you have a 60 mile round trip to work and you can't charge at work. The first part of the trip is a steep climb. Without mountain mode you will use up all your battery climbing the hill. Then CS mode for the drive home. You are then using the ICE at a low load condition where it's SFC is not the best. Using the ICE at the front part of trip going uphill at a high load is better., so you use mountain mode up the hill then switch out of MM. You would have to figure out exactly how long to go in MM before switching out. the object would be to get home w/ 1 mile of EV range left and the ICE does not come on.
    2012 Silver Ice Volt w/ leather and polished aluminum wheels
    lease over in May 2015
    new vehicle TBD
    2012 Gray Model S
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #24
    Join Date
    Jun 2008
    Location
    New Mexico
    Posts
    658
    Default
    Your scenario would work if the Volt had the "Hold Mode," which it does not. In Mountain Mode, what would happen is the Volt would operate in EV until is depleted to the set point (~40% SOC, ~13 miles range left, but it would say 0 miles). Then the ICE would come on until you changed back to Normal Mode, at which time it would say somethinglike 13 miles range left.
  7. #25
    Join Date
    Sep 2008
    Location
    Posts
    315
    Default
    [QUOTE=Shams;58584]Has anybody tried Mountain Mode (MM) while State of Charge (SOC) of battery is high (over 45%) in EV mode?
    It is known that if you shift to MM in Charge Sustain (CS) mode engine would top the battery up to 45% SOC as well as providing enough power for current driving power demand.]
    STUDY OF FORCED MOUNTAIN MODE VS NORMAL MODE
    I have a route I take often that is right at 100 miles, with several steep uphill and downhill grades. The results of hypermiling and select use of MM is suprising and shows that GM has done about as good a job as possible to achieve best efficiencies.
    Trip 1: 100.1 miles 58.1 CD miles 42 CS miles 1.59 gallons 12.92 KWHR Cost(gas + Elec) $10.594
    Trip 2 : 98 Miles 43 CD miles 55 CS miles 1.55 gallons 13.22 KWHR $10.50
    Trip 3: 99.4 miles 61 CD miles 38.4 CS miles 1.59 gallons 12.89 KWHR $10.575
    The difference in trip lengths is the selection of the restaurant
    So I conclude that at the current price of gas and electricity here any trade off between runing entirely in Normal vs trying to use MM to improve effeciency is at best a push. So I guess I will run in Normal for these trips.
  8. #26
    Join Date
    Aug 2010
    Location
    Southern California
    Posts
    272
    Default
    I spoke with a GM employee who said that when they take Volts to publicly show the car and want to be able to have enough charge for the public to experience the battery only operation, they drive in MM to the event to preserve charge. He said it will save about 5 miles of charge to allow the public to experience the car in CD. So yes, it works, but not so as to completely preserve or hold the charge.
  9. #27
    Join Date
    Sep 2010
    Location
    San Diego, CA. VIN B-95
    Posts
    2,632
    Default
    Quote Originally Posted by sgc View Post
    Which tells you how hard people thrash the Volt during demos :-)
    I don't generally drive mine gently (though getting to be more gentle than my last gasser) and I usually have 11 miles from a full MM SOC. But the car learns over time what to expect.
  10. #28
    Join Date
    Aug 2010
    Location
    Southern California
    Posts
    272
    Default
    My challenge has been to learn to drive with electricity efficiency in mind. When I'm alone I play that game. When I'm with others and we need to go somewhere by a certain time, then I can't. Hard to adjust to "gentle & efficient" driving habits.
  11. #29
    Join Date
    Feb 2011
    Location
    Posts
    136
    Default
    Hauling out this thread, dormant for a while.
    When in CS mode last night, in some rolling hills on the San Francisco Peninsula (I-280, for you fellow Bay Area folks), it seemed to me that the ICE's speed did not directly correlate with the car's speed. There were times when I was accelerating and the ICE sounded as though it was not going any faster, but without a direct tach readout, I could not be certain. At the end of the trip, when in CS and Normal Mode, I think the ICE shut down at a traffic light: no wasted gasoline idling at the light.
    WOT, Scott, Rusty, etc.: can you confirm this? (It makes sense to me: the battery is a big buffer, and the ICE is running just to maintain SOC. If the SOC is in good shape, you won't need to draw hard on the ICE until the SOC drops a tad.)
    How does this relate to MM? We've discussed using MM to maintain SOC, with a goal of reverting to Normal Mode for in-town driving in the middle of the trip (but beyond CD-only range). Is this, in fact, net more efficient? In a conventional ICE-powered car, in-town stop-and-go driving with idling in traffic or at traffic lights is very hard on fuel economy. Is this the case with the Voltec powertrain?
    - Alan
  12. Advertisement
  13. #30
    Join Date
    Aug 2010
    Location
    Berwyn, PA
    Posts
    1,966
    Default
    I have been using MM a bit more lately on longer outings, primarilly because I wanted to be in stealth mode during certain portions (like when driving up the driveway to my son's girlfriend's house... okay, ego matters).
    A couple thoughts now have occured to me:
    1) MM must be very powerful at battery charging. It takes minutes, not hours, to raise the battery SOC (amazing).
    2) As long as I arrive home at the end of the outing with the battery fully depleted, I've succeeded (no wasted gas).
    3) MM efficiency may be relatively high (no extra heat loss), so it's a zero-sum game (MM is okay for managing SOC).
    I'd be happy to hear confirmations or contradictions.
    Chris
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
