Can Volt's Bluetooth Access iPhone Contacts?
Grab our Forum Feed
+ Reply to Thread
Results 1 to 5 of 5
Thread: Can Volt's Bluetooth Access iPhone Contacts?
  1. #1
    Join Date
    Nov 2010
    Location
    San Diego, CA
    Posts
    305
    Default Can Volt's Bluetooth Access iPhone Contacts?
    My Garmin GPS will display my iPhone's contacts so I can select an iPhone contact for Navigation guidance using the Garmin. Can the Volt's navigation system select an iPhone contact via Bluetooth?
  2. #2
    Join Date
    Jul 2008
    Location
    Rancho Mirage CA
    Posts
    123
    Default
    Quote Originally Posted by Frankman View Post
    Short answer --NO-- It can use the i-Phone contacts for calling but not a destination in the Nav system
  3. #3
    Join Date
    Nov 2010
    Location
    San Diego, CA
    Posts
    305
    Default
    Quote Originally Posted by RDO CA View Post
    Where do the iPhone's contact phone numbers display on the Volt LCD screen to select a contact to call using Bluetooth? I noticed that the Volt seems to have an internal phone book that you can program phone number into. Do the iPhone contact phone numbers display there, or is there a separate area? Also, do you know if you can scroll through the iPhone's contact phone numbers on the Volt LCD screen and select while driving? Thanks.
  4.
    Advertisement
  5. #4
    Join Date
    Jan 2011
    Location
    Syracuse, NY
    Posts
    254
    Default
    The contact list shows up on the screen, picture attached. You press the phone button then select your paired iphone from the list.
    Black Volt # 613 Lifetime MPG 111 total miles 27613
    Red Volt # 3699 Lifetime MPG 155 total miles 23116
    RIP [Red Volt # 1247 Lifetime MPG 99 total miles 3239]
    http://www.communityenergyinc.com/
  6. #5
    Join Date
    Jul 2008
    Location
    Rancho Mirage CA
    Posts
    123
    Default
    You can put in 30 numbers in the voice activated address book but you can't see them on the screen. If you forget you can ask for "directory" and the voice will read them out in 5 number groups and keep asking if you want more read till you get to the one you want.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
