Ok, confession time. "My name is Jerry, and I am an Autocrosser."
I have been an Autocrosser for over forty years now, and while my driving skills have lessened as I aged, the fun of driving a car has never diminished. For those of you who may not be familiar with it, Autocross refers to a miniature road race course set up with pylon and chalk lines on a large parking lot, with only one car running at a time against the clock, with dozens of different classes covering every type and size of car, so you would be able to compete against cars of similar size, handling, and power.
Since, as I mentioned, my skills are somewhat diminished, I let a good friend drive the Volt for me. He has beaten me consistantly for many years now, and has experience in many many levels and types of cars. His current personal car is a well set up Nissan 350 Z. He was a little apprehensive about the fact that the traction control can't be turned off on the Volt, as the 350 Z traction control reduces power from the engine and hampers driver control and speed significantly in turns. But he agreed to "try it" anyway.
I showed him how to set the mode to sport and use Low for better de-acceleration and under threat of "a slow and painful death" if he put any pylon marks on the car, he went out for his first lap. Temperature was about 50 degrees and overcast. He came in from that lap with a big grin, and said "This thing is a hoot!" He was very surprised at how well the Volt corners, with only very minimal push, and said the acceleration was quite a bit better than he expected also. He ran four laps with it, and lap times continuously improved as he adapted to the Volt's capabilities. The course was about 1/2 mile in length. He started with about a 51.5, then 50.7, then 50.4, and finally a 49.4 as he got the "hang" of the Stabilitrack traction control. He mentioned that the Volt seems to limit speeds in corners in proportion to the amount you have the steering turned, and so when he made it a point to "unwind" the steering earlier in the corners, there was much better acceleration available to "get going".
I checked the condition of the front tires after this and was surprised to see virtually no scrub over on the outside edge of the tire tread, This is unusual for stock class cars, even with the exta ten pounds of pressure we had in them. The car was set at 35 all around from the dealer, and when I saw that the max pressure labelled on the tire sidewall was 51, I had set them at 45 front and 40 rear, (heavier front end doing most of the hard cornering work) typical settings for a stock class car. Apparently, Chevy has put a better than usual suspension on the Volt. It seemed to have a very stable look and feel, with very little body roll.
All in all, it was a very fun and pleasant experience, and the car received a lot of positive comments. I enjoyed it thoroughly. Might even do it again someday.
Jerry, #536
