HOW TO ORDER YOUR HOME CHARGING STATION
Grab our Forum Feed
+ Reply to Thread
Results 1 to 9 of 9
Thread: HOW TO ORDER YOUR HOME CHARGING STATION
  1. #1
    Default HOW TO ORDER YOUR HOME CHARGING STATION
    For All Those Who Know And For All Those That Don't Know.......Visit..https://...www.homecharging.spx.com/volt/...To RegisterTo Order Your Home Charging Station..
    For Those Who Pay Lipa...There is a 500.00 Rebate...
    Happy Volting
  2. #2
    Join Date
    Jul 2010
    Location
    Bayamon, Puerto Rico
    Posts
    1,335
    Default
    How much does it cost if it has a $500 rebate? I can install it myself and save the labor.
    Join Date
    Oct 2010
    Location
    Chicagoland VIN:B-01234
    Posts
    3,509
    Default
    Quote Originally Posted by Raymondjram View Post
    How much does it cost if it has a $500 rebate? I can install it myself and save the labor.Raymond
    The link above did not work. Here is a better one: https://www.homecharging.spx.com/vol...x?id=7&menu=14
    Voltec™ Charge Station
    The Voltec™ Charge Station is a reliable, safe and easy to use Level II home charging solution. Designed with the consumer in mind, the Voltec provides the consumer with a fast charging system for their home charging needs. Indoor and outdoor rated, the Voltec’s flexible design allows it to placed in a variety of locations within a consumers residence.
    Combining an ergonomic design with advanced technologies, the Voltec Charge Station performs continuous diagnostics while the vehicle is being charged..
    Self diagnostics and status indicators
    Safety features to protect customer and vehicle
    Continuous ground monitoring
    Charge current interrupting device (CCID) provides automatic self check and reclosure
    Outdoor rated
    Built in vehicle plug flashlight
    To order Call: 1-877-805-EVSE(3873)
    $490.00*
    *Hardware only. Does not include installation.
    Only available to Volt owners and customers with orders confirmed for vehicle production.
  4.
    Advertisement
  5. #4
    Join Date
    Sep 2008
    Location
    Orange County, CA
    Posts
    194
    Default
    Some owners have gone with other vendors than SPX, I believe. I'd like to hear their stories and experiences as well.
  6. #5
    Join Date
    Apr 2010
    Location
    Central Long Island, NY
    Posts
    304
    Default
    LIPA (Long Island Power Authority) has a $500 rebate program...almost ready. They have not finished making the application forms yet. If you call 800-692-2626 (use option #2) and give them your name, address and phone, they will contact you when they're ready.
  7. #6
    Join Date
    Nov 2010
    Location
    Austin, TX
    Posts
    126
    Default
    I went to the SPX website and clicked where it said "Recommended Charging Products" and it shows 4 types of chargers: Voltec, Coulomb ChargePoint CT500, Blink (Ecotality), and SPX Charge Station.
    I can order the Voltec for $490. It's datasheet says it is a level 2 charger that delivers 3.3kW, 15A max, 208/240v and should use a 20A breaker.
    By living in the Austin metropolitan area, I can get the ChargePoint charger for free but I think I have to pay a huge amount for installation. (I want to install it myself if possible). It's datasheet says it is a level 2 charger that delivers 7.2 kW, 30A, 208/240v, and should use a 40A circuit breaker.
    I don't think I can get the Blink (Ecotality) or SPX Charge Station.
    I thought level 1 charging is either 8 or 12A, 120v, and level 2 is 16A at 240v for the Chevy Volt. Since the Voltec only delivers 15A, would the Coulomb charge the Volt slightly faster at 16A, or maybe much faster at 30A?
    I assume I would actually need a different EV to take advantage of higher than 16A charging, but wouldn't that be considered level 3 charging? The datasheet of the Coulomb station calls itself a level 2 charger, not level 3.
    The datasheets are available at the SPX link above.
    -doubledave - Volt owner since Jan 2011 - 2011 Volt # 0724
  8. #7
    Join Date
    Nov 2010
    Location
    Tewksbury, MA
    Posts
    539
    Default SPX Charger
    The Volt is designed with a specific charging rate for 240V chargers. It will not charge any faster with the other higher rated chargers. So get the SPX as it is the most cost affective and easiest to install. One thing should be noted that in some if not all states require a local cut off near the charger. Which could be a enclosed cutoff switch or a sub panel with the 20 amp dual pole breaker. In my case I am installing and exiting 40 amp 240V circuit to a Sub Panel in my garage, this will give me the 20A 240 volt breaker to the Voltec charger and also give me 2 120v 20 amp outlets for my compressor and other tools.
  9. #8
    Join Date
    Oct 2010
    Location
    North OC, CA
    Posts
    520
    Default ChargePoint charge station
    The CT500 ChargePoint charge station by Coulomb has a couple of interesting quirks to mention.
    1. The 30 amp relay inside makes a loud snap when activated and it hums. Depending on where it is mounted, you might hear the hum in your home. I loosened the mounting bolts to decrease the pressure of the charge station on the drywall to lower the transmission of hum into the house.
    2. If you are charging and press the STOP button, the Volt will not resume a charge schedule until the charge handle is removed from the Volt and reinserted. The OnStar MyLink iPhone app does get fooled and you may think timed charging will restart later, but it will not.
  10. #9
    Default
    Here is the Link to the LIPA Rebate...................................http://www.lipower.org/electricvehicle/
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
