Anyone know how soon additional mobile charger cords will be available?
I would consider the charger that comes with the car, and located in below the trunk floor panel, mobile enough. What do you mean "mobile"?
Yea, I had ordered an extra 120v charge unit, as I have one set up permanently at the house. I wanted one to keep in the car. My dealer said it hadn't come in yet.
BLACK VOLT #218 - "PESTILENCE"
Actually the charger unit is mounted in the RH front corner of the car, in behind the RH headlamp assembly. I think you may have been referring to the Auxullary Power Module (DC-DC converter) that charges the 12V battery while driving.
Also people who might be interested in a portable 240V EVSE might want to check out the unit SPx plans to sell
http://gm-volt.com/forum/showthread....rging-stations
OT
Actually, I'm pretty sure that both Michael and sgc are referring to the 120V EVSE that comes with the Volt in the "trunk." And what the original question was "how to buy an additional one," so you can have one in the car and leave one in the garage. As in buy one from the parts department at a Chevy dealer or from the accessories page at Chevy dot com.
No cords at http://www.gmaccessorieszone.com/Chevrolet/2011/Volt/ . . . yet.
MichaelH
my local volt parts department (salinas, CA) said "something like $400", but it's not available until all the initial Volt owners get their cable.
seems a bit high for an extension cord with a small circuit.
I ordered the SPX voltec 220 to have that capability and was going to put a 14-50 nema plug and an appropriate breaker onto it, in the hopes of finding a way to use the existing avcons in my area. I have read that they will be mostly converted over to J1772 in the future in California, with the legacy Avcon vehicles using an adapter back from J1772 to avcon.
I will post again after I get things checked out with an electrician and wired up.
if I were more patient, the mobile charging unit by SPX looks good, and it is probably already fused. it looks a lot like the one tesla sells for $1500
The one for the LEAF should work also, check with Nissan.
