Leave the port door open so someone can plug you in? Useless
Grab our Forum Feed
+ Reply to Thread
Page 1 of 3 1 3 LastLast
Results 1 to 10 of 25
Thread: Leave the port door open so someone can plug you in? Useless
  1. #1
    Join Date
    Sep 2012
    Location
    PA
    Posts
    332
    Question Leave the port door open so someone can plug you in? Useless
    So here's the deal. GF and I both have Volts and we share a Ge Wattstation. I intend to hook up a second charger for TMS reasons and preheating in the winter but for the time being we've been running into an issue.
    At times she will leave in the afternoon and plug my car in so my TMS can run or I can preheat/cool without also having to go out first to plug the car in (we have a detached garage). Every time we do this the cars -doesn't matter which one- sends a text stating charging has been interrupted. Is there a setting we're missing in the configuration screen somewhere?
    It would seem also that if anyone were to leave their Volt parked with the charge port door open near another EV that is charging, in the hopes that person would plug them in when they leave, that the car would just send a text and not start charging. It seems like the car needs to be unlocked or the key needs to be in proximity to the car for the car to start charging?
    -=Steve & Naomi=- Twin 2013 Diamond White Volts Hidden Content 15.68kW Solar powered
  2. #2
    Join Date
    Jun 2008
    Location
    Tolland, CT
    Posts
    1,391
    Default
    Quote Originally Posted by TwistnShift View Post
    I didn't know the answer, so I performed a test. My 2012 Volt was charging at work and was not yet fully charged. Went to it and unlocked it and removed the EVSE (L2) and then re-locked the car. Walked away and left my fob in my office and then returned to my locked Volt and plugged in. Got the soft and short horn beep and my Volt is once again charging. I can't test with my L1, as it is hanging in my garage.
    Very cool that both you and your GF have Volts!
    EDIT: Oh, I have one of those problematic Voltec L2 Charging Stations by SPX (no problems yet *finger crossed*).
    EDITx2: Also, my setting is set to Immediate Charging.
    2012 Blue Volt
    Voltstats.net: 2012-16084 (C-6084)
    Hidden Content
    In my garage charging (L1) for the 1st time on 24-Mar-12
    Typical Commute: 34 to 39 miles each way (Charging at Work on L2!)Hidden Content
    All-Time Best....55.4 eMiles on a single charge.
  3. #3
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    15,107
    Default
    Is delayed charge set?
    B3320
    Best All Electric Miles: 54.2
    Lifetime: 84,576 miles, 135 MPG, Remaining Oil Life 74%
    Typical Commute: 60 miles
    30 day Stats: 1366 miles, 125
    MPG, 65% Electric, 33% gas, Saved 48 gal., 27 kW-hr/100 miles
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Sep 2012
    Location
    PA
    Posts
    332
    Default
    Quote Originally Posted by Steverino View Post
    No, both cars are set to immediate charge and both cars exhibit this behavior. If I leave my port open so she doesn't have to mess with my keys or anything and leave the car, when she moves the L2 from her car to mine my car immediately sends a text stating a charging error has occurred and the car never starts charging. No horn honk, no light, nothing. Same thing happens if I move the plug from my car to hers with her leaving her charge port open. If I go out to the car and unlock it then the car charges with no issues.
  7. #5
    Join Date
    Aug 2009
    Location
    Texas - DFW
    Posts
    4,366
    Default
    This might seem strange, but, try doing it without bringing any Volt keys with you. My theory is that the other Volt is seeing the key and locking itself out from charging with the wrong key.
    In other words, the issue has something to do with there being two Volts in close proximity.
    Driving a show car. Every day!
    Don't Pokemon and drive!
    2014 Crystal Red ELR (REDD) code R w/Cashmere interior
    L2 - GE WattStation
    iOS 10.2.1 on iPhone 6. MyCadillac App version 3.5.0
    Hidden Content
    Hidden Content
  8. #6
    Join Date
    Oct 2012
    Location
    USA
    Posts
    3,802
    Default
    Quote Originally Posted by Loboc View Post
    This seems reasonable...
  9. #7
    Join Date
    Feb 2012
    Location
    No. Virginia
    Posts
    1,575
    Default
    Well that's not good. What if you are in public and there is some dude sitting in his Volt next to you. Does that mean you can't charge?
    Also the sole notion that one Volt does not like company of its own kind is rather depressing.
  10. #8
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    15,107
    Default
    What happens when you wait a few minutes between unplugging from one and plugging in the other?
    B3320
  11. #9
    Join Date
    Oct 2012
    Location
    USA
    Posts
    3,802
    Default
    Quote Originally Posted by vdiv View Post
    No...it is the fact the GF doesn't have his fob but HERS and is trying to plug in HIS Volt...in your scenario, hopefully you have YOUR fob when you are trying to charge...
  12. Advertisement
  13. #10
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    15,107
    Default
    From my experience, you don't need a fob to charge. Perhaps the GE EVSE is creating a fault when switching cars.
    B3320
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Charge Port door sticking
    By silentguy in forum Generation 1 Volt (2011-2015)
    Last Post: 12-31-2015, 01:52 PM
  2. Anyone's Charge Port Door Pop Open While Driving?
    By PowerTrip in forum Generation 1 Volt (2011-2015)
    Last Post: 06-25-2014, 03:43 PM
  3. Charge Port Door Usually Fails To Open
    By electricfun in forum Software & Programming/Code Discussions - Chevy Volt
    Last Post: 12-05-2012, 10:13 AM
  4. Charge port door won't open...
    By Jerry Garcia in forum Generation 1 Volt (2011-2015)
    Last Post: 10-29-2012, 07:26 PM
  5. Is gas door suspose to fling open like the charge door?
    By dukecola in forum Generation 1 Volt (2011-2015)
    Last Post: 09-25-2012, 07:02 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
