Music Sort Order Alphabetical, Not By Track Number
Page 3 of 4 FirstFirst 1 3 4 LastLast
Results 21 to 30 of 39
Thread: Music Sort Order Alphabetical, Not By Track Number
    New Jersey
    1,398
    Quote Originally Posted by silyman1 View Post
    There are a few bulk ID3 editors out there. I may have to spend money. on the other side, one could highlight all the music you want to copy, while inside itunes, edit info, and then delete all the titles. Itunes won't work properly then, so you'll have to make a copy of your music, change your music library to that copy, do the work, and then change your library back. Pain in the ass, but doable, and not one-by-one. I'll try it soon and keep everyone posted on how it goes.
    It's a reasonable idea, but I am NOT going to edit every song title in ID3 from the thousands of songs I've ripped. Unless there's a bulk editor that will work (like I use a bulk conversion tool called "Switch" from NCH software, but it doesn't let you modify the ID3 fields during conversion), this approach is a non-starter for me. What I think is really in order here is a mass-appeal from the community to get GM to fix the software so we can set a preference for "Track Order" in the configuration menu.
    I have something of a line where I can MAYBE reach the Volt brand quality manager inside GM with this request. If I do, I will let you all know what I find out, but it could be a while.
    Quote Originally Posted by volt11 View Post
    It's not a matter of being able to set a preference for track order. NO ONE, and I mean NO ONE, wants their album view to be listed in alphabetical order. I told my volt adviser this, and pleaded with him to move this up the chain. I wanted to make sure that I knew he was on my side here, and he is. These volt advisers aren't the issue as you point out. GM Needs to simply change the way their system organizes its tracks. We don't need the option, we just need it changed to the way every. single. other. music playback device in the world does it.
    Also yes as far as i could tell in my research, there are bulk rename utilities that also will allow you to change the title to include album-artist-track#-title in the title field. so it is doable. But it costs money. I think GM, at the very least, should provide us with that software package.
    328
    This needs to be fixed.
    Whats the best way (nicely) to provide this input to GM? They need to hear that this is NOT acceptable to their customers.
    Stilgar
  6. #24
    Agreed. I talked to my volt advisor. I suggest you do the same. Confirm the call is being recorded. Ask them to talk to a higher up about it. Heck, perhaps done of our CAB folks might be able to take the torch here.
  7. #25
    New Jersey
    1,398
    Quote Originally Posted by Stilgar99 View Post
    Stilgar
    What makes me less than optimistic is that there seems to be the same problem across the GM lineup, so I doubt we'd be the first people complaining about it.
  8. #26
    True, but if we don't stop, perhaps we can be the last. I'm trying to use various ID3 tag editors and am having not-so-great luck. I'm messing around with a program called TriTag. Not having any luck so far bulk-shifting my file name to the id3 title, which would include track number in front of it then. The saga continues.
  9. #27
    Ok I figured out how to bulk edit individual albums through TriTag, a free program for mac. I have some screen shots for anyone interested.
    http://flic.kr/p/947ry3
    This is the main interface. Be sure the that the mode to the top left shows filename -> id3 tag.
    http://flic.kr/p/947ryE
    Drag and drop the folder for the album you want to change. Sadly, TriTag will only work with MP3 and not M4A files.
    Fill out the Artist, Album, Year, and Genre sections and force their use. In the top file name pattern, enter "%s" to indicate you want the contents of the file name to be moved to the Title field on the ID3 tag.
    http://flic.kr/p/944o8a
    Click preview to see what your song metadata will change to. The volt will read the Artist and album info as well as the title, so make sure all those fields are properly sorted. When happy, click apply, and your songs will change.
    I recommend copying the tracks away from iTunes or whatever music player you have, as they will get confused by this new info, and who in their right mind wants to have a track number in front of the title of each song. I mean only an idiot would program a system to require that sort of - oh... right.
    Hope this helps. I'll be continuing on my quest to find an easier method than album-by-album. But at least it's no longer song-by-song!
  10. #28
    17
    Default Retagging App for Windows
    Okay, for people looking for an easy way to retag their MP3s for better use on the GM infotainment system here is my experience. I used MP3 Tag Studio, which you can search for on Google. It is shareware so if you find it useful please donate, but it has full functionality as downloaded. I suggest making a backup of your media library before retagging the files.
    Once the MP3 Tag Studio is installed, run the program. Choose the directory where the MP3 files are located under the working directory dialog located in the the top left area of the main interface. In the lower half of the interface choose the tab named "Direct tag manipulation." On the left bottom side check the "Advanced mode" check box.
    In the bottom middle section there are fields to manipulate the tags. In the first box enter: "<Album>-<TrackNr>-<Title>". In the second field enter "<Title>". This setting should reset the track title tag to include the album name followed by the track number and then the original track title. Once the above is set, check "Include subdirs" for it to include all the sub-directories of your music directory and then click "Execute". Be aware that if you execute the retagging a second time it will prepend the album name and track number a second time to the track title so only perform the operation once (a good reason to create a backup of your music files).
    That should be it. Good luck.
  11. #29
    328
    Have you verified this works once copied to the Volt HD?
    Stilgar
  13. #30
    Does it work on a Mac?
