Good news! In any case I would make sure you request a copy of the warranty repair order for the MIL (Malfunction Indicator Lamp) being ON, with the noted Diagnostic Trouble Code (DTC) clearly identified in case you run into any issue in the future.
If you post your DTC here we can discuss further.
Other than this little hiccup, ENJOY YOUR VOLT!
Although generally minor, I'd rather not have to deal with these niggling bugs out of the gate. Hopefully by the time I'm ready to bite the bullet, most of these issues will be worked out.
