Most Miles I Drove Using on Battery Mode
Grab our Forum Feed
+ Reply to Thread
Page 1 of 6 1 6 LastLast
Results 1 to 10 of 51
Thread: Most Miles I Drove Using on Battery Mode
  1. #1
    Join Date
    Oct 2010
    Posts
    21
    Default Most Miles I Drove Using on Battery Mode
    The most miles I drove on battery mode was 53.8 miles. It was 53 degrees outside during the trip. I made an effort to drive as efficiently as I could during this trip. I tried to keep the car between 40 and 50 mph and used as little braking as possible during the trip.
    Robert Becker
    Chevy Volt Customer Advisory Board Member
  2. #2
    Join Date
    Sep 2008
    Posts
    2,493
    Default
    That's excellent!
    Thanks for sharing your data with everyone.
    So in "D" or "L" ?
    WOT
  3. #3
    Join Date
    Jan 2008
    Location
    New York
    Posts
    230
    Default
    You are doing better than me Robert. I haven't really done any babying of the EV range. I seem to be getting just shy of an effective 40 on most of my vigorous highway romps. My trip to work is 30 miles and when I get there there are usually less than 10 remaining. I then recharge during the day so I dont completely deplete the battery.
    Sometimes I only charge for about 4 hours so I wind up driving back home with about 22 or 24 remaining and go into engine mode close to home.
  4.
    Advertisement
  5. #4
    Join Date
    Sep 2010
    Location
    San Diego, CA. VIN B-95
    Posts
    2,631
    Default
    Quote Originally Posted by Lyle View Post
    (and sometimes he forgets to check if his charger is plugged in, but don't tell anyone, it's a secret :-)
  6. #5
    Join Date
    Jan 2008
    Location
    New York
    Posts
    230
    Default
    Quote Originally Posted by Rusty View Post
    No really I dont...Ok maybe once
  7. #6
    Join Date
    Oct 2010
    Posts
    21
    Default
    Quote Originally Posted by WopOnTour View Post
    That's excellent!
    So in "D" or "L" ?
    WOT
    I drive mostly in "D" (probably 95% of the time). I try to anticipate when I need to slow down and downshift to "L" temporarily instead of using the brakes as much as possible. I try to use the brakes as little as possible.
    Robert Becker
  8. #7
    Join Date
    Jun 2008
    Posts
    198
    Default
    And the advantage of using the breaks as little as possible is you will most likely never have to have your pads replaced. I have almost 130,000 miles on my 2003 Prius and I've never had the break pads replaced.
  9. #8
    Join Date
    Apr 2010
    Location
    Central Long Island, NY
    Posts
    304
    Default
    When I know I'll need to use the brakes on my Accord hybrid, I try to ride them just to where the green regeration bar is max'd. It's amazing how many people are in a big rush to get to the red light and stop.
  10. #9
    Join Date
    Oct 2010
    Location
    New Rochelle, NY
    Posts
    8
    Default
    The best I have done so far is 48.8 miles on electric. Seems I am always catching up with Robert!
    Mike
  11.
    Advertisement
  12. #10
    Join Date
    Oct 2010
    Posts
    21
    Default
    Any of the other NY or DC drivers have any experience on EV range in cold weather? I have only one data point in weather below 40 degrees, but it seems like the EV range may drop by 20% in weather just above freezing. My data is very unscientific since I only have one data point, but I will continue to monitor this as the cold weather settles in.
    Robert Becker
Posting Permissions
  • You may not post replies
  • You may not edit your posts
