How Many KWh to Charge the Volt?
Grab our Forum Feed
+ Reply to Thread
Page 1 of 6 1 6 LastLast
Results 1 to 10 of 57
Thread: How Many KWh to Charge the Volt?
  1. #1
    Join Date
    Oct 2010
    Posts
    21
    Default How Many KWh to Charge the Volt?
    I am one of the Volt CAB drivers and thought I could answer a question that has come up a few times on this website. The Volt does not tell you how many kWh are used in the EV mode, but I have a dedicated TOU meter for the Volt charger so I can measure the amount of kWh’s used to charge the vehicle. As an example, during my trip to the electric car meet up in Montclair, NJ yesterday, I drove 110.2 miles total and 44.5 were in EV mode and 65.7 using the gas generator. I burned 1.6 gallons of gas during the trip. But, to answer the kWh question, when I charged the car at home in the evening, the car took 12 kWh of electricty to charge the depleted battery.
    Robert Becker
    Chevy Volt Customer Advisory Board Member
  2. #2
    Join Date
    Sep 2010
    Location
    Santa Monica, CA
    Posts
    70
    Default
    It looks like it would have cost me $0.72 to fill your tank that night.
    In the last twelve months I spent an average of $68 per month of fuel for the Prius. Seems like it will be hard to spend that much on electricity for the Volt.
    Now I have to figure out whether it would make more sense to route my solar generation through the EV meter rather than the house meter (both TOU).
    --Colin Summers, blogging and on Twitter as Voltaday.
    Member of the GM Volt Customer Advisory Board
    _________________
    Took delivery of my Captured Test Fleet Volt on November 11th 2010
  3. #3
    Default
    Quote Originally Posted by greencar View Post
    I drove 110.2 miles total and 44.5 were in EV mode and 65.7 using the gas generator. I burned 1.6 gallons of gas during the trip. the car took 12 kWh of electricty to charge the depleted battery.
    Assuming the national average of $0.12 per kWh electricity and $3.00/gallon of premium gas, you went 13.7 miles per dollar of gas and 30.9 miles per dollar of electricity.
    (I pay $0.0986 per kWh, so I would have gone 37.7 miles per dollar of electricity)
  4.
    Advertisement
  5. #4
    Join Date
    Sep 2008
    Posts
    2,487
    Default
    Your charging efficiency of ~86% perhaps is a bit lower than expected but not excessively so.
    Your TOU device, is it a smart meter or some sort of accessory at the breaker?
    What is its resolution? (ie was it 12, 12.0, 12.00 kwh? )
    WopOnTour
  6. #5
    Join Date
    May 2009
    Posts
    1,498
    Default
    Quote Originally Posted by WopOnTour View Post
    Very typical of chargers and power supplies.
  7. #6
    Default
    Robert Becker: Can you please report what the temperature was on the night that it took 12 kWh to charge the battery? Just wondering if there was much battery conditioning going on. Also, did you pre-condition the cabin temp on grid power before you unplugged? These things could explain some of the power draw, which would indicate a higher than ~86% charging efficiency.
  8. #7
    Join Date
    Oct 2010
    Location
    Graham, WA
    Posts
    218
    Default
    Quote Originally Posted by honoreitiscom View Post
    ....which would indicate a higher than ~68% charging efficiency.
    ~86% was stated
  9. #8
    Default
    Oops, good catch. I edited my post to say 86%.
  10. #9
    Join Date
    Oct 2010
    Posts
    21
    Default
    Robert Becker: Can you please report what the temperature was on the night that it took 12 kWh to charge the battery? Just wondering if there was much battery conditioning going on. Also, did you pre-condition the cabin temp on grid power before you unplugged? These things could explain some of the power draw, which would indicate a higher than ~68% charging efficiency.
    The car was parked in my garage all night while it was charged. The garage is probably around 50 degrees although I did not measure the temperature. I did not precondition the cabin temperature on grid power before unplugging.
    Robert Becker
  11.
    Advertisement
  12. #10
    Join Date
    Oct 2009
    Location
    Pine, Arizona
    Posts
    1,786
    Default
    Robert,
    It would be interesting to know how efficient the 110V charger is. Maybe you could use it one night as a comparison.
    2012 Silver Ice Volt w/ leather and polished aluminum wheels
Posting Permissions
  • You may not post replies
  • You may not edit your posts
