Charge methods & ports : Handshake charging only?
OK, so it's presumably well understood that charging the volt via 110-220 is going to require a 'smart' cord that only begins charging after the handshake completes.
Is there a bypass, or any type of inverted charging port available?
i.e. for:
tow behind batteries
low voltage DC charging
drive over cradle coupling, etc...
No such port is available, but it will be a popular modification for the Nissan LEAF.
I suspect Nissan will have genset trailers for their own internal uses, to ferry LEAFS from dealer to dealer.
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
