Fisker’s Karma to Get 67.6 Miles Per Gallon
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
Thread: Fisker’s Karma to Get 67.6 Miles Per Gallon
  1. #1
    Join Date
    Feb 2008
    Location
    Rancho Palos Verdes, CA
    Posts
    683
    Default Fisker’s Karma to Get 67.6 Miles Per Gallon
    I just came across this article, my apologies if it's been posted already (.i.e, if it's old news).
    The company, which will show off its Fisker Karma next week at the Frankfurt Auto Show, said that the plug-in Karma will consume about 3.5 liters for every 100 kilometers of driving, according to calculations developed by the Society of Automotive Engineers. There are 3.785 liters per gallon, giving the Karma a rating of 100 kilometers per 0.925 gallons of gas, or 108.1 kilometers per gallon. In miles, that comes to around 67.6 miles per gallon. (It is unclear at the moment whether or not the figure includes the electricity required to charge the battery: We are checking.) The average car in the U.S. gets about 22.4 miles per gallon. The Karma is a serial hybrid: It drives on electricity for the first 50 miles, but a gas engine recharges the battery while the car drives.
    The Karma uses GM's turbocharged, direct-inject 2.0L four-cylinder to run its generator. The drive train produces 408 horsepower and can propel the car to 60 mph in 5.8 seconds and onto to a top speed of 125 mph.
    If the Karma can get 67.6 MPG, maybe the Volt can get 50 MPG? Of course, the article leaves a lot of unanswered questions, namely:
    1. (1) Is this City, Highway or Combined.
    2. (2) Does that value include the first 50 miles on electric (50 miles = 80 Km) -- does it use 3.5 litres to go the last 20 KM (12.427 miles/.925 Gallons = 13.4 MPG)
    Hopefully, the answer is not (2).
    Cheers!
    http://www.greentechmedia.com/articl...es-per-gallon/
  2. #2
    Join Date
    Feb 2008
    Location
    Indian Harbour Beach, FL
    Posts
    4,085
    Default
    They should put the Volt / Karma in range extender mode and run the usual mileage tests and tell us how they do.
  3. #3
    Join Date
    Feb 2008
    Location
    Posts
    683
    Default
    Quote Originally Posted by Jason M. Hendler View Post
    That would be nice wouldn't it? It will happen sooner or later (but probably later). I'm sure both manufactures will want to fine tune the S/W up to the last minute to maximize the MPG rating in charge sustaining mode for the EPA test. Thus, I'd expect them to keep the final numbers close hold until then. Still, it would be nice to know what it can achieve now with an asterisk to denote a development value! :-)
  4.
    Advertisement
  5. #4
    Join Date
    Mar 2008
    Posts
    3,689
    Default
    Quote Originally Posted by Rooster View Post
    Um, you both realize it depends on the size of the battery and the amount of that battery that they use. Right? The more millage, the shorter the life (assuming both have the same size pack) or the more the pack will cost (and weigh).
    The very expensive Karma can use the most expensive battery technology and as much of it as the vehicle dynamics allow.
  6. #5
    Join Date
    Nov 2008
    Location
    Eugene OR
    Posts
    1,830
    Default
    Well we know there is no way on earth they are going to get 67 mpg in range extender mode excluding any AER miles. This number means nothing but PR.
  7. #6
    Join Date
    Feb 2008
    Location
    Posts
    683
    Default
    Quote Originally Posted by Texas View Post
    Has that been decided -- how the EPA is going to test? Will the MPG value be based on combined EV (battery) and ICE, or will they split the two out and keep them separate. I thought the court was still out? I was referring to pure MPG in CS mode. I get the fact I won't use any fuel in the Volt if I drive less than 40 miles, and if I only drive 50 miles my equivalent MPG will be quite high (100+ MPG), but want to know the true MPG in CS mode, just because I want to know. :-)
  8. #7
    Join Date
    Feb 2008
    Location
    Posts
    683
    Default
    BTW...I understand the Karma has a larger battery. I understand it to be in the neighborhood of 22 KWh. So I also assume they are using approximately 11 KWh to get the 50 mile EV range.
  9. #8
    Join Date
    May 2009
    Posts
    1,498
    Default
    I want to see the CS mode mpg also, but at a sustained 40 mph
    Happy New Year everyone!
  10. #9
    Join Date
    Feb 2008
    Location
    Posts
    4,085
    Default
    The mileage should read 40 AER / 50 MPG CSM, so that we can calculate our own savings.
  11.
    Advertisement
  12. #10
    Join Date
    Jun 2008
    Location
    Southwest Florida
    Posts
    84
    Default
    Quote Originally Posted by hermperez View Post
    Agreed, but I'd really like to know what it does @ 80MPH, cuz that's what we drive on the interstate out here!!! (SD, ND, MT)
    If you're not tripping breakers, you're not making progress!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
