Elevation question
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 20
Thread: Elevation question
  1. #1
    Join Date
    Mar 2013
    Location
    Amaranth
    Posts
    5
    Default Elevation question
    Hello
    We just purchased a new 2012 Volt (We pick it up tomorrow). My daily commute is about 140 km round trip. I drop over 1000 feet on my way to work and have to climb that on the way home. I was wondering if it would be best to use Mountain mode on the way to work and save the Electric for the way home as I am unable to charge while at work.
  2. #2
    Join Date
    May 2011
    Location
    Delaware
    Posts
    3,642
    Default
    Try it different ways and see what you get. Personally, I'd probably lean toward going all electric on the trip to work, which is likely in battery range given the elevation change. That way you'll only have to cold start once per day, during the trip back. You shouldn't need mountain mode on the way home for 1000 feet, unless they are in an unusually steep slope.
    Walter
    Volt FAQ
  3. #3
    Join Date
    Jan 2013
    Location
    AZ
    Posts
    339
    Default
    If you're going downhill to work don't you want to take advantage of regen to fill up the battery for your way back? Not sure what the point of doing MM on the way to work when it's down hill?
    You didn't say how long your commute is so people can get a better picture.
  4.
    Advertisement
  5. #4
    Join Date
    Feb 2013
    Location
    washington
    Posts
    98
    Default
    He said 140km round trip - we need a calculator I know
  6. #5
    Join Date
    Jan 2013
    Location
    AZ
    Posts
    339
    Default
    Quote Originally Posted by jljeeper View Post
    Oops, I missed that part (was looking for miles hehe). Anyway, whipped out my calculator (yes, I need it) and it's 87 miles. I'd still use electric with regen on the way down and MM on the way up. Why do the reverse as proposed? Don't understand that logic.
  7. #6
    Join Date
    Mar 2013
    Location
    Amaranth
    Posts
    5
    Default
    Quote Originally Posted by Volusiano View Post
    As posted, my commute is 140 km round trip. I had forgotten about the regen capability, that should at least get me all the way to work on the battery. Thanks
  8. #7
    Join Date
    Mar 2013
    Location
    Amaranth
    Posts
    5
    Default
    Hi
    I was thinking MM would use less fuel going downhill?
  9. #8
    Join Date
    May 2011
    Location
    Delaware
    Posts
    3,642
    Default
    Quote Originally Posted by cstevethompson View Post
    Hi
    Unless there's something unusual going on, with that much altitude drop I would expect that you won't use any fuel going down hill with a charged battery.
    Walter
    Volt FAQ
  10. #9
    Join Date
    Jan 2013
    Location
    chicago
    Posts
    297
    Default
    I betcha have a nice view being so high up.
    I live in flat Chicago.
    The best way to handle this is to test it out yourself. Keep a log of your gas and miles driven etc., and let us know what ended up being the best for you.
    I used MM for the first time last week on an 8 mile trip and picked up approx 13 battery miles. My regret was I did not note the amount bof miles I had in gas when I started and finsihed so I do not know how much it cost me. I have not used MM again though.
    Keep a log and report back to us.
  11.
    Advertisement
  12. #10
    Join Date
    Mar 2013
    Location
    Amaranth
    Posts
    5
    Default
    Quote Originally Posted by anthonykitmcinnis View Post
    I will definitely keep a log. It's going to take me awhile to figure out everything about this car. 12.5 hours to go until I pick it up from the dealer.
Similar Threads
  1. Make your own elevation profile!
    By davewilks in forum Software/programming/code
    Last Post: 03-30-2013, 04:03 PM
  2. Replies: 4
    Last Post: 04-25-2012, 10:20 PM
  3. Replies: 19
    Last Post: 10-31-2011, 01:45 PM
  4. Elevation Data to Help with Climbs
    By CCIE in forum Suggestions for GM
    Last Post: 04-04-2008, 12:02 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
