Adapter for 240 volt male / 120 volt female
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: Adapter for 240 volt male / 120 volt female
  1. #1
    Join Date
    Jan 2013
    Location
    chicago
    Posts
    774
    Default Adapter for 240 volt male / 120 volt female
    Can anyone help me with this. I did search the forum before asking however I did not find anything.
    I have a 60 feet heavy, heavy duty 240 volt cable that I run to my air conditioner. This cabe has a 6-20P female on the end of it.
    Is it possible to:
    1. Get an adapter that is 6-20P 240 volt male on one end and 120 volt female (3 prong) on the other end.
    2. Plug it into the Volts 3 prong charger cable.
    3. Receive a 240 volts 3/4 hour full charge.
    Is this possible ?
    Does anyone know of such an adapter ?
  2. #2
    Join Date
    Oct 2010
    Location
    So. Texas
    Posts
    1,265
    Default
    Look at portable level 2 chargers with a 6-20 plug or upgradeable chargers:
    http://evseupgrade.com
    Click on the FAQ link there for more info: "Will the upgraded EVSE work with the Chevy Volt?
    This used to be problematic, due to picky timing on the Volt's SAE J1772 Charging interface, but GM has since corrected this with a software upgrade in the Volt. If you have had the dealer installed upgrade, your Volt is now compatibile with our upgrade! All recent Volts are delivered with this installed from the factory now. Our unit will now properly charge a Volt at 120 or 240 volts, and in addition it is built much more ruggedly and heavier-duty than the original Voltec unit. Our unit is equipped with 12awg cable whereas the Voltec only has 16awg! (same size as standard lamp cord!)"
    Doug
    2013 CMax Energi Red (His)
    2015 Subaru Outback w/EyeSight (hers)
    2012 Jet Black Volt (sold)
  3. #3
    Join Date
    May 2011
    Location
    Delaware
    Posts
    7,968
    Default
    I have it on good authority that the GM factory EVSE will be smoked by such an attempt. As already noted, an upgraded version of the Leaf EVSE is designed to do pretty much exactly that, and has run for over a year for me with no issues. Note that they have to make some changes to it, however - a factory Leaf box will smoke, too. This is one place Tesla is well ahead of everyone else - their factory portable cord works fine on 110 and 220 - up to 10kW of power if you have the appropriate 220 plug adaptor.
    Walter
    2016 Tesla X75D delivered 8/25/16
    Hidden Content
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Jan 2013
    Location
    chicago
    Posts
    774
    Default
    Sucks.
    I just called them and discovered our 2013 Volt charger cables can only do 120V. I thought they were capable of both 120V and 240V.
    I dont think its worth it for me to spend another over 200 to be able to charge 240V.
    Thanks for helping me.
  7. #5
    Join Date
    May 2011
    Location
    Delaware
    Posts
    7,968
    Default
    Quote Originally Posted by anthonykitmcinnis View Post
    Sucks.
    A 220 charger will almost never pay for itself on a pure financial basis - pretty much the only case that would is someone doing multiple fairly long but in EV range trips a day with some time to charge in between.
    As a convenience, I felt it was worth the money. Always having the 110 cord in the trunk, never having to mess with either cord. Preconditioning with no range loss in cold weather. Charge enough for dinner out after work sometimes. And if I'd had a 2013, not having to reset to 12 amps every single time.
    Walter
    Hidden Content
  8. #6
    Join Date
    Oct 2010
    Location
    North OC, CA
    Posts
    572
    Default
    I found this website today and am very impressed with their solutions to cable management for public EVSE.
    http://evsellc.com/ev-charger-cable-management.shtml
  9. #7
    Join Date
    Jan 2011
    Posts
    355
    Default
    I recommend Clipper Creek LCS-25. They are $600 ths month
  10. #8
    Join Date
    Jun 2012
    Location
    Chilliwack, BC
    Posts
    1,115
    Default
    No, a 6-20P has no neutral, thus the only way to get 120V would be to use a 240-120 step-down transformer.
    The factory "charger" or EVSE won't like 240V - You'll let out the magic smoke...
    If you got a Level 2 EVSE you'd be able to charge up your Volt in about 4 hours from the 6-20P outlet. You could go the EVSEupgrade path as others have suggested, or perhaps a Voltec SPX or Clipper Creek LCS.
    Quote Originally Posted by saghost View Post
    Personally I've got a Sun Country Highway LCS-25 (rebranded Clipper Creek) It was on sale for $650 CDN and I got a $500 rebate from the government. I've got an L6-20P plug on it for portability, as that seems to be the most commonly available outlet 'round these parts. (I know that unit is rated for 30A, but I've yet to see a single L6-30R outlet and the Volt will never draw more than 16A) I regularly use my original EVSE as well, I carry both on the seat behind the driver along with a 30' 12ga extension cord.
    06/20/12 - ordered/deposit on 2013 Volt - Blue/Black Cloth/Comfort/Safety 1&2/Nav/Bose
    08/14/12 - 3800 - Order produced
    09/13/12 - 5000 - Delivered to dealership! VIN: D7585
    After 52 months of ownership: (average commute is 100 km / 62 mi one way)
    122,000 km total / 77,000 km electric / 45,000 km gas / 2.52 L/100km
    76,000 mi total / 48,000 mi electric / 28,000 mi gas / 93.3 mpg
    Estimated fuel savings vs. my truck: $18250
  11. #9
    Join Date
    Jun 2012
    Location
    New Hampshire
    Posts
    2,689
    Default
    You can do something like this:
    http://www.walmart.com/ip/MK-Diamond...l5=pla&veh=sem
    So you are essentially only using half the 240v circuit. Same charge time as on 120V, because you're still only using 120v.
    If you want faster charging, you'll have to buy a level 2 EVSE.
    Love My Volt!
    Blue Topaz, Black/Ceramic White Leather, Nav 2012
    New Hampshire
  12. Advertisement
  13. #10
    Join Date
    Jan 2013
    Location
    chicago
    Posts
    774
    Default
    Thanks everyone.
    emartin00, had I known about it, that cable at Walmart is precisely what I would have bought before posting here and finding out the truth.
    I would have been very disappointed.
    If Illinois had some kind of rebate like what Rampage_Rick has then I would buy one otherwise its just too expensive.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Does charging at 240 volts cost less than at 120?
    By Bill R. in forum Generation 1 Volt (2011-2015)
    Last Post: 12-12-2012, 09:33 PM
  2. Charger: 120 problem, and 240 suggestions
    By Zod in forum Electric Vehicle Batteries & Plug-In Charging
    Last Post: 10-07-2012, 06:47 PM
  3. 240 charger rates compared to 120
    By rodwed in forum Generation 1 Volt (2011-2015)
    Last Post: 09-21-2012, 10:23 AM
  4. Tesla Roadster Charger adapter for My Volt
    By Ecenteno in forum Chevy Volt Accessories and Modifications
    Last Post: 05-28-2012, 12:18 AM
  5. 240 VS 120 Charger
    By VoltMama in forum Generation 1 Volt (2011-2015)
    Last Post: 09-18-2011, 02:44 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
