Mount Washington, take 2
Grab our Forum Feed
+ Reply to Thread
Page 1 of 4 1 4 LastLast
Results 1 to 10 of 31
Thread: Mount Washington, take 2
  1. #1
    Join Date
    May 2016
    Location
    Westford,MA
    Posts
    478
    Default Mount Washington, take 2
    I've been meaning to go up Mount Washington for the last 40 years, MountainVolt's post last week was the kick that made me do it. Went up Saturday, it was 65 degrees up top which is great for Mount Washington the record for June is 71. I drove there in Hold so that I had an almost full battery, went up in normal and down in L mode with the regen paddle. I hardly touched the brake peddle so the wheels were ice cold at the bottom. Energy consumption on the way up was mostly in the low 20KW, peaking at 33KW. On the way down the regen peaked at 14KW. I used a total of 9.4KWh on the way up, got back 4.9KWh on the way down. After Mount Washington we drove to the Mount Washington Hotel for dinner and then home. For the total trip I did 54.3 miles on battery using 14.2KWh (107 MPGe) and 309 miles on gas using 6.57 gallons (47.3 MPG). The regen returned 52% of the energy.
    My only complaint is that the regen braking occasionally let go necessitating the use of the brake peddle, but that was rare and so I hardly used the brake peddle at all.
    Start
    4 miles, 1.2 KW used
    guess_o_meter 65, 90.6 MPGe
    11.4 miles, 10.6 KW used
    guess_o_meter 7. MPGe 30.8 MPGe
    Bottom
    18.9 miles, 5.7 KW used
    guess_o_meter 47, MPGe 92.7
    End of Trip
    54.1 miles, 14.2 KW
    guess_o_meter 0
    Climb used 9.4 KW
    Descent returned 4.9 KW
    Regen returned 52%
    2017 Volt Premier
  2. #2
    Join Date
    Jul 2013
    Location
    North East USA
    Posts
    1,069
    Default
    Regen may be disabled if traction control detects rough road or loss of traction. It may also be disabled if battery and regent buffer are full, or if battery is not in optimal temp range.
  3. #3
    Join Date
    May 2013
    Location
    Seaside, Oregon
    Posts
    1,994
    Default
    Thanks for your review. Must have been a fun trip. Its nice to get regen when other regular vehicles just wear out their brakes on the way down. Also over 47 mpg just on gas is better than most of all the eco boxes would have done. You beat the EPA figures of 53 on electric and 42 mpg on gas as well. I live on the other side of the country, and I plan on doing a Hurricane Ridge Run in Port Angeles, Washington, Olympic National Park, with our 2016 Volt when we are up there visiting family. I'm not sure if I could make the entire climb with electric...
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    May 2016
    Location
    Westford,MA
    Posts
    478
    Default
    Quote Originally Posted by telveer View Post
    There were some rough patches, battery was pretty well drained by the drive up so that wasn't it.
    2017 Volt Premier
  7. #5
    Join Date
    Oct 2013
    Location
    Fighting Illini country surrounded by bean fields
    Posts
    10,503
    Default
    Quote Originally Posted by bjrosen View Post
    I experience the same thing under heavy braking in a particular part of my commute where there is a slight bump in the road. This is normal, as designed, though it can send your gut sinking as you get surprised by it. When this happens you might be able to catch a glimpse of a yellow traction icon on the dash flashing a few seconds after it happens. It'mormal, nothing to worry about with the car itself, but if you see it happening more and more, that's a sign you might need to check your tires. New tires will help, but not completely eliminate this "feature".
    I have fond memories of mt. Washington. We went there with a rental after moving my daughter into her dorm then blowing off orientation week 5 years ago. We were lucky enough to catch pictures and selfies in front of twin double rainbows (two rainbows that each cycled through the color spectrum twice, not sure what the scientific term is).
    We also stumbled onto the most wonderful bakery in horthern Vermont. Rainbow Sweets Bakery in Marshfield, VT is a must visit place, before the owner and proprietor gets too old and retires. You must get the Johnny Depp Balls. We spend $85 for a family of 4, but had try one of nearly everything because it was so delicious. The owner also tells stories of how he grew up neighbors with Ben and Jerry, another place to visit, but the urgency isn't so great as they continue to operate with the next Generation kids.
    https://www.facebook.com/Rainbow-Swe...8669924836893/
    LLninja (greenback troll #1)
    2013 Volt G1 white diamond tricoat
    If I can get the guy in the mirror under control I can be skinny and rich.
    If you don't have the money, don't buy it. Debt is hazardous to your wealth
    Hidden Content Originally Posted by doctorq Hidden Content
    "what kind of mental problem do you have? you should really get yourself checked out, are you on any type of psychotropic medications?
    R:IQ $2.2M, at $1.7M proj $4.8M
  8. #6
    Join Date
    Aug 2014
    Location
    New Hampshire
    Posts
    522
    Default
    Instead of the Mt Washington Hotel, stop at the Woodstock Inn and Brewery for a meal. They have a free charging station outside.
    2017 Mosaic Black Volt
  9. #7
    Join Date
    May 2016
    Location
    Westford,MA
    Posts
    478
    Default
    Quote Originally Posted by alfon View Post
    I usually get 47-48MPG on gas on the highway in summer so that number was to be expected. What was unexpected was that I ended up with 54 total miles on the battery even though I did the Mt Washington climb.
    Please keep track of your numbers when you do the Olympics. I've never driven then but I did hike the Olympics in 1969 when I was a kid.
    If anyone is in Silicon Valley have you done the drive from San Jose to the Lick Observatory in a Volt? I've done that drive a number of times in an ICE car in the last century and as I recall it's much more difficult than the Mt Washington drive but maybe that was psychological because of the switchbacks which we don't have in the East.
    2017 Volt Premier
  10. #8
    Join Date
    Nov 2014
    Location
    California
    Posts
    892
    Default
    I haven't done it in the Volt yet, but it might be fun. Back side of Mt Hamilton is great sports car territory. Tons of twisties.
    I have been all over Highway 9, Skyline, Page Mill, La Honda, etc though. In fact just did some of it this morning. (Went with one of my sons for a Fathers Day breakfast that "couldn't be beat" at Alices. ) The Volt does great up and down Highway 9. On the way down I used "L" all the way, hitting the regen paddle if I was about to enter curves a little too fast. Almost never needed to touch the brake pedal.
    2016 Premier - Red/brandy w/DC 1, 2, and Nav (built 10/15)
    Added: Sport pedals, Illum chg port, all weather mats, sill plates, Cruze spare tire...
  11. #9
    Join Date
    Dec 2016
    Location
    Cos
    Posts
    75
    Default
    I am tempted to try pikes peak in the volt. I would guess it won't make the top on battery since its 20 miles or so. The race is only 11 miles but it starts about half way up. I think I could charge it most of the way back up on the way down.
    Last time I drove it, we were in a SUV with an automatic. We got the brakes over 350deg even using low gear. The back brakes were cool suggesting that the brake balance was way off or set for panic stops only. I have also run across a minivan with the hub caps melted off the wheels.
  12. Advertisement
  13. #10
    Join Date
    Feb 2014
    Location
    Portland, OR
    Posts
    640
    Default
    Seems like you had a delightful trip!
    From MountainVolt’s previous description of the journey, it sounds as if descending the mountain involves careful attention to driving, rather than just putting the car into L and cruise control and letting braking regen alone maintain the appropriate speed. The paddle must have come in handy!
    Of course, the source of your Volt’s kinetic energy that enabled you to accumulate 4.9 kWh of regen energy was gravity, not previously consumed battery power, so you were capturing, not recapturing it. Still, I would think you drew very little energy from the battery during the descent, so the drop in kWh Used from 10.6 to 5.7 would approximate the amount of regen going back into the battery.
    This leads me to speculate that the regen efficiency during the ascent was very low. Did you obtain much braking regen on the way up, or was gravity a sufficient force to slow down and stop the car when needed? In both directions the kWh Used is a net figure. The descent doesn’t usually include much battery consumption in the total. The ascent might not include much regen.
    Perhaps what is remarkable is that the 54.1 Electric Miles you achieved on a full charge is very close to the window sticker rating of 53 miles of range, even though a big chunk of your electric miles involved driving up a mountain and back down again. Perhaps gravity-derived downhill regen counterbalances the extra battery energy it takes to ascend, so that, generally speaking, driving on battery power across flat terrain produces about the same AER as driving up and down hills.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. My 2017 Volt drove up Mount Washington two days ago! What a pleasure, tons of torque
    By MountainVolt in forum Chevy Volt General Discussion, News, and Events
    Last Post: 1 Week Ago, 04:19 PM
  2. Glass mount antenna
    By crowltom in forum Chevy Volt General Discussion, News, and Events
    Last Post: 10-11-2013, 02:38 AM
  3. Tesla Sedans Climb Mount Washington
    By ClarksonCote in forum Tesla
    Last Post: 08-26-2013, 01:37 PM
  4. iPad Mount Anyone?
    By Brittt1 in forum Generation 1 Volt (2011-2015)
    Last Post: 01-02-2012, 10:38 PM
  5. First Volt to Climb Mount Washington
    By ClarksonCote in forum Generation 1 Volt (2011-2015)
    Last Post: 08-04-2011, 10:42 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
