"May 5, 2009 Raser Technologies has begun delivering 10 megawatts (MW) of clean, renewable electricity to Anaheim, California, from its first low-temperature, binary geothermal plant, the Hatch Geothermal Power Plant in Beaver County, Utah. Traditionally, the lead time on a geothermal plant is three to five years, but the USD$33-million Raser plant has been powered up just five months after ground-breaking. To help meet such rapid construction schedules, the plant uses off-the-shelf modular components, taken from the air conditioning industry, which are essentially running in reverse.
The geothermal plant uses an organic Rankine cycle (ORC) that generates power from ground-sourced geothermal brine, at temperatures ranging from 200ºF to 300ºF (93ºC to 148ºC). At normal atmospheric pressure, water boils at 212ºF (100ºC), but under pressure, typical of a geothermal system, the temperature can increase much higher before flashing to steam. Typical geothermal plants require the temperature to be at least 360ºF (182C) to be feasible. The Raser plant uses an ORC to make use of geothermal resources, previously considered unusable. Depending on the type of organic fluid used, temperatures as low as 158ºF to 176ºF (70-80°C) can be used in an ORC to generate electricity. "
http://www.gizmag.com/raser-low-temp...-online/11612/
