Gurgling sound after coolant pump replacement
Grab our Forum Feed
+ Reply to Thread
Results 1 to 5 of 5
Thread: Gurgling sound after coolant pump replacement
  1. #1
    Join Date
    May 2017
    Location
    Cali
    Posts
    2
    Default Air pockets in heater core?
    Our Volt stopped putting out heat, so we took it to the dealer who replaced the "aux heater coolant pump". Everything is working fine except we noticed a gurgling sound when the fan first starts up (or when turning). After taking it back they said there was air in the heater core and attempted to bleed it but couldn't fully bleed it out since the "battery mode turns off when the hood is open". They returned the car with no real change and said to continue to drive it and the problem will go away on its own as the coolant circulates and draws out all the air pockets. I'm wondering if I'm being sold a bill of goods and if so, how best to push this?
  2. #2
    Join Date
    May 2017
    Location
    Cali
    Posts
    2
    Default Gurgling sound after coolant pump replacement
    Our Volt stopped putting out heat, so we took it to the dealer who replaced the "aux heater coolant pump". Everything is working fine except we noticed a gurgling sound when the fan first starts up (or when turning). After taking it back they said there was air in the heater core and attempted to bleed it but couldn't fully bleed it out since the "battery mode turns off when the hood is open". They returned the car with no real change and said to continue to drive it and the problem will go away on its own as the coolant circulates and draws out all the air pockets. Is this true? What're are my options for pursuing this?
  3. #3
    Join Date
    Jun 2016
    Location
    NEOhio
    Posts
    89
    Default
    I had battery section replaced and encountered same sounds. Almost like a toilet flushing while charging.
    As expected, it is just air pockets working their way out. It stopped after several days then the dealer topped the coolant back up to proper level and all is quiet since.
    "Never Underestimate the Power of Stupid People in Large Groups"
    2012 Cyber Gray Premium
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Jun 2016
    Location
    Rochester NY
    Posts
    573
    Default
    It will be fine. They should have ran the heat for awhil and let it circulate then topped off. That's what I did when I replaced mine.
  7. #5
    Join Date
    Feb 2016
    Location
    GA
    Posts
    74
    Default
    Just remember at some point the reservoir will need to be topped off once the air works its way out.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. coolant pump
    By yvolt4 in forum Generation 1 Volt (2011-2015)
    Last Post: 3 Weeks Ago, 04:38 PM
  2. Gurgling after Coolant heater control module replacement
    By burgandy25 in forum Generation 1 Volt (2011-2015)
    Last Post: 12-09-2016, 12:08 PM
  3. Gurgling Sound when Foot Taken Off the Pedal or Braking?
    By mattph76 in forum Chevy Volt General Discussion, News, and Events
    Last Post: 08-26-2015, 10:35 AM
  4. Coolant pump growl?
    By begreen in forum Generation 1 Volt (2011-2015)
    Last Post: 04-30-2014, 04:24 PM
  5. Electronic coolant pump failure at 750km :(
    By rodmacpherson in forum Problems/Issues, Driver Warnings or DTCs - Chevy Volt
    Last Post: 02-13-2014, 09:46 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
