Experience with Curt Class 1 hitch
Grab our Forum Feed
+ Reply to Thread
Results 1 to 7 of 7
Thread: Experience with Curt Class 1 hitch
  1. #1
    Join Date
    Aug 2016
    Location
    Washington State
    Posts
    64
    Default Experience with Curt Class 1 hitch
    Installed the Curt 1 1/4" hitch on my 2013. Strong mount to the right side using welded nuts on vehicle but left side only mounts to the sheet metal pan. Must remove one plastic plug and drill a 2nd 1/2" hole, then use 1/4" plate spacers. Seems weak on that side. Also with 3 bolts in place the right rear flange was 1/4" from the welded nut, making the bolt too short. Replaced with a M10x1.5x40 bolt from Ace hardware.
    I only intend to use it with a bike rack so I expect it will be strong enough for that. Now I'm puzzling over where to attach stabilizer straps to the car body - everything seems to be plastic. Maybe straps thru the rear doors to the hinges? Anyone have suggestions?
  2. #2
    Join Date
    Dec 2015
    Location
    Virginia
    Posts
    1,627
    Default
    I'll be interested to see how it all works out for you. The Volt seems like one of the least "rack friendly" vehicles I've ever seen.
    A study in opposites
    1997 Jeep Cherokee
    2013 Chevy Volt "OHM-RIDE"
  3. #3
    Join Date
    May 2016
    Location
    Frederick, MD
    Posts
    33
    Default
    Solution? Buy a Torklift Ecohitch. That thing is ROCK solid.
    https://torkliftcentral.com/2011-201...ohitch-stealth
    https://torkliftcentral.com/2011-201...cohitch-invisi
    I've heard nothing but complaints and concerns about the Curt hitches on Volts.
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Mar 2017
    Location
    belfair,washington
    Posts
    75
    Default
    So what are the complaints and concerns? I have one on my 2017 Volt Premier and I have towed with it (small utility trailer) without issue, but only made one trip so far. What should I worry about?
  7. #5
    Join Date
    Jan 2016
    Location
    Maine
    Posts
    597
    Default
    The Gen2 hitch connection is far more solid than the Gen1s.
    2016 Volt Premier, C1, C2
    Hidden Content
  8. #6
    Join Date
    Dec 2015
    Location
    Kansas City
    Posts
    25
    Default
    I didnt even know what a stabilizer strap was to be honest and had to look but found this video and looks like attaching to top of the hatch on a Prius, but dont think this is plastic on the Volt. To be honest my bikerack doesnt move at all but it has a stabilizer system built in where I don't use just a hitch pin. I have to carry around a 13mm socket but no big deal to tighten down or remove when needed and it been rock solid for the 5 or so years I have used it. Its is something similiar to this but it came with my swagman bike rack
  9. #7
    Join Date
    Mar 2017
    Location
    California
    Posts
    20
    Default
    In fact there's a thread on one person's experiance with one: http://gm-volt.com/forum/showthread.php?278881-Voltruk
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Curt Hitch for Volt For Sale
    By Heb80 in forum For Sale
    Last Post: 01-15-2016, 07:27 PM
  2. Curt Hitch Install - with pics
    By Heb80 in forum Generation 1 Volt (2011-2015)
    Last Post: 12-19-2015, 04:33 PM
  3. Installed: Curt Towing Hitch
    By joetoocool in forum Chevy Volt Accessories and Modifications
    Last Post: 08-27-2015, 03:48 PM
  4. curt trailer hitch
    By emd in forum Chevy Volt Accessories and Modifications
    Last Post: 10-18-2013, 08:27 PM
  5. Has anyone actually installed he Curt Hitch?
    By torn66 in forum Chevy Volt Accessories and Modifications
    Last Post: 04-22-2012, 12:27 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
